Troll Hunter Posted December 15, 2013 Share Posted December 15, 2013 I'm planning to fit new rubber valve stem seals (part no. ETC8663) but can't find anything in the Tech Archive that covers this operation. Have I overlooked something? It doesn't look too difficult a job, if you have a valve spring compressor. Are there any special precautions I should take, or any tips anyone can give me? Any recommendation on type of spring compressor, since I still have to buy one? Many thanks in advance. Mike Quote Link to comment Share on other sites More sharing options...
Lewis Posted December 15, 2013 Share Posted December 15, 2013 You can get valve spring compressors that attach directly to the top of the head, eliminating the need to remove it, I'd get one of them, even if the head is already off this time it might save you some work next time Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted December 15, 2013 Share Posted December 15, 2013 This video might be of use Quote Link to comment Share on other sites More sharing options...
toenden Posted December 15, 2013 Share Posted December 15, 2013 Hi. Last time I did one, i forgot to borrow a spring compressor.. The head was of at the time, but i reckon it would have been the same with it still attached to the engine. I put some 10mm flat iron between two of the rockercover bolts and using the ring end of an 22mm spanner compressed the springs in a breakerbar way. I did have the help of a friend though. If you make sure the the piston on the cylinder you are working on is in tdc, then it should be doable this way. Regards mads. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted December 15, 2013 Share Posted December 15, 2013 There's a drawing for a simple in situ compressor here. With that you can do them without removing the head. When you put the new ones on, make sure they are a tight fit, as they tend to blow off the top of the guides. http://forums.lr4x4.com/index.php?showtopic=82893 Quote Link to comment Share on other sites More sharing options...
western Posted December 15, 2013 Share Posted December 15, 2013 I don't remember where I found this, not sure if it was from a fellow member on here, 300tdi valve tool.pdf Quote Link to comment Share on other sites More sharing options...
cackshifter Posted December 15, 2013 Share Posted December 15, 2013 Credit where it's due, Ralph's file is the one in my link, submitted to this site by Cotleigh Crasher Quote Link to comment Share on other sites More sharing options...
western Posted December 15, 2013 Share Posted December 15, 2013 Thanks for the confirmation on who the file owner is. Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted December 17, 2013 Author Share Posted December 17, 2013 Many thanks all for your replies,especially to Lewis and Dailysleqaze. Tomorrow, I make the valve spring compressor as detailed above. \Mike Quote Link to comment Share on other sites More sharing options...
