Dave 63 Posted February 11, 2014 Share Posted February 11, 2014 Gents, I've just ordered some chequer plate wing tops from Rebel, but I notice that you can get gaskets to go between the plate and the wing. Is there a DIY method where you can fabricate your own gaskets ? Ideas please Quote Link to comment Share on other sites More sharing options...
western Posted February 11, 2014 Share Posted February 11, 2014 something like neoprene sheet & draw around the item & cut to shape, or just use a weather proof sealant. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted February 11, 2014 Share Posted February 11, 2014 You can use 40mm self adhesive neoprene strip around all the edges to stop getting muck getting under the chequer plate. Have a look on eBay. HTH Mo Quote Link to comment Share on other sites More sharing options...
Maverik Posted February 12, 2014 Share Posted February 12, 2014 I use this stuff for all sorts of body banel sealing, comes in different sizes if you do some searching for similar items, I used it to put my wing and bonnet chequer plate on, just one tip, you need it to be thinner than you think. i.e 1.5mm will do you. http://www.ebay.co.uk/itm/5m-Black-Single-Sided-Foam-Tape-10mm-Wide-x-1-5mm-Thick-/270700990096?pt=UK_Crafts_Cardmaking_Scrapbooking_Glue_Tape_EH&hash=item3f07094e90#ht_339wt_1049 Quote Link to comment Share on other sites More sharing options...
JeffR Posted February 12, 2014 Share Posted February 12, 2014 None setting butyl strip (10mm wide) from caravan/truck builder does the job, but you need warm weather. Failing that, the stuff you put under wood flooring is pretty good as its a closed cell foam- keep an eye out in the B&Q/Homebase/Wickes bargain bins. Quote Link to comment Share on other sites More sharing options...
ukspike Posted February 12, 2014 Share Posted February 12, 2014 I fitted black alloy panels to my truck, and sealed them with black silicon that you would usually use to seal truck/car windows with, worked really well as it will follow irregular (Defender) panels well, Quote Link to comment Share on other sites More sharing options...
Blackfiesta123 Posted February 14, 2014 Share Posted February 14, 2014 I reckon if you put rubber under them and under bonnet chequer plate it would reduce engine noise abit. Quote Link to comment Share on other sites More sharing options...
Dave 63 Posted February 21, 2014 Author Share Posted February 21, 2014 Plates arrived at last, though not cut for the Ariel hole on os wing . Do I cut hole in black powder coated plate, or relocate the Ariel on the roof? Quote Link to comment Share on other sites More sharing options...
Dave 63 Posted March 2, 2014 Author Share Posted March 2, 2014 Gone with the tape and drilled the plate for the aerial, looks mint Thanks for your help lads Quote Link to comment Share on other sites More sharing options...
TheKeymeister Posted March 2, 2014 Share Posted March 2, 2014 Plates arrived at last, though not cut for the Ariel hole on os wing . Do I cut hole in black powder coated plate, or relocate the Ariel on the roof? I had the same dilemma, and decided to cut the black plate, just about got it right. Ran a bit of silicone along the bottom, and round all the rivet holes. The Defenders at work all have the chequer plate sealed round the edges as well, and they're all fitted by an (allegedly) professional company. I didn't do it like that as I only had white silicone and it'd look carp...but I will tidy it up when I get hold of some black. Quote Link to comment Share on other sites More sharing options...
