landroversforever Posted July 30, 2014 Share Posted July 30, 2014 I'm after some recommendations of galvanisers in the south, preferably near to Oxford. Anyone got any suggestions? I've googled, but would rather have some recommendations. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
tacr2man Posted July 30, 2014 Share Posted July 30, 2014 Back in mid 70s I used Ideal casements to do a chassis for me , they were in Reading . Not there anymore ! When I needed a bulkhead , and other stuff doing recently , I ended up using Wedge , up in Wednesfield nr Brum as they were about the nearest , and they did a real good job at a good price . HTSH Quote Link to comment Share on other sites More sharing options...
landroversforever Posted July 30, 2014 Author Share Posted July 30, 2014 Thanks :-), they're one of the ones I've contacted. Quote Link to comment Share on other sites More sharing options...
studmuffin Posted July 30, 2014 Share Posted July 30, 2014 Wedges are an old established galvanisers and have a good reputation. Wednesfield is pretty much a suburb between Bloxwich and Wolverhampton and is handy for the M6/M5 and M54. Barry Quote Link to comment Share on other sites More sharing options...
miketomcat Posted July 30, 2014 Share Posted July 30, 2014 I've used Wessex galvanizers in Southampton very helpful however the finish is a little agricultural. But I would happily recommend them for stuff you don't necessarily see mind I could of just of had a rough batch. Mike Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted July 31, 2014 Share Posted July 31, 2014 Wedge also have a place in hull that I use, around £1 / kilo with a minimum of £30. Their work has always been fine but they can be picky with second hand stuff. Quote Link to comment Share on other sites More sharing options...
Daan Posted July 31, 2014 Share Posted July 31, 2014 I've used Wessex galvanizers in Southampton very helpful however the finish is a little agricultural. But I would happily recommend them for stuff you don't necessarily see mind I could of just of had a rough batch. Mike This are my findings as well, but probably the closest to you. East anglia galvanizers in peterborough is were I had my chassis done, and their finish is better by a mile I'd say, it looked mirror finish almost. Shame their forklift driver messed it up by throwing it in a corner and bend a bracket. Daan Quote Link to comment Share on other sites More sharing options...
LiftedDisco Posted July 31, 2014 Share Posted July 31, 2014 Pillar Wedge as already detailed... they have recently just done a project for me that involved 847 tonnes of steel and which then won the Galvanisers Association Award for best use of galvanised steel in an engineering project! Depending on where you are in Oxford, you could also drop into WIG Engineering (just outside Bicester) and ask for John or David - see if they have anything going through somewhere local that you could 'tag onto' Cheers Rob Quote Link to comment Share on other sites More sharing options...
Boris113 Posted August 5, 2014 Share Posted August 5, 2014 I have used Premier Galvanising in Peterborough and found them to be good, although that was not for small LR parts. A mate had a winch bumper done by a place in Bristol and that came out well. I know neither are particularly close, but IIRC the Bristol one will collect/deliver. Quote Link to comment Share on other sites More sharing options...
