Soren Frimodt Posted January 13, 2015 Share Posted January 13, 2015 Nothing much at all, just something I've been wanting for several years, but not one of those things that you really need, hence I haven't done much about it, except finding out they are bloody expensive! A 'dimple die' is what it is, the last dot to complete the i, so to speak, in my many go-fast holes. They simply are not proper go-fast holes if they are not dimpled, just ask on Pirate if you don't believe me Only bought a 1" version for starters to check the quality and so forth, what I like about it is that it can be used with a through-bolt so already installed sheets on stuff can be dimpled without having to remove them. Just went and tested it on an old piece of scrap Mercedes sheet Can't wait to go all crazy with it! Quote Link to comment Share on other sites More sharing options...
ejparrott Posted January 13, 2015 Share Posted January 13, 2015 Umm..ok..so why do you need that then? Quote Link to comment Share on other sites More sharing options...
Nigelw Posted January 13, 2015 Share Posted January 13, 2015 Very nice, can see that in combination with a windy gun an spanner getting some serious dimples pressed out quick smart Any idea on how you can press out louvered vents with such a tool? Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted January 13, 2015 Share Posted January 13, 2015 Umm..ok..so why do you need that then?It adds strength Quote Link to comment Share on other sites More sharing options...
zardos Posted January 13, 2015 Share Posted January 13, 2015 (edited) Umm..ok..so why do you need that then? I thought that this type of thing is used to add strength to a flat sheet of metal. Edit ah beaten while typing Edited January 13, 2015 by zardos Quote Link to comment Share on other sites More sharing options...
elbekko Posted January 14, 2015 Share Posted January 14, 2015 That's one fast panel Quote Link to comment Share on other sites More sharing options...
Fatboy Posted January 14, 2015 Share Posted January 14, 2015 I made one of them from an old inner bearing race track, a nut and bolt and an alloy bearing press tool. (The bearing press tool came as part of a set from Northern Tool Supplies, the set cost about £15 IIRC). Not perfect, but near enough and very rewarding... Can you guess where the oil cooler has gone on my 110? Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted January 14, 2015 Author Share Posted January 14, 2015 Especially from all the weight that's been removed from rust! Yeah was hoping it would be fairly quick and easy to use with my akku-impact, just need to find a step drill with a 25mm step. The one I have goes from 24-26, and the hole really has to be exact for a decent looking result Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted January 14, 2015 Author Share Posted January 14, 2015 Looking good Donald, yeah did consider doing something myself, but at the price I found this one at on eBay in the UK I couldn't be bothered. 1 Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted January 14, 2015 Share Posted January 14, 2015 If you do it the other way around you could put treads on your bonnet so you don't slip off when your walking on it to attach your recovery rope Quote Link to comment Share on other sites More sharing options...
Fatboy Posted January 14, 2015 Share Posted January 14, 2015 Just don't get carried away.. You could turn the bonnet into a giant cheese grater. That would be messy if you hit a pigeon on the way home! Quote Link to comment Share on other sites More sharing options...
landroversforever Posted March 31, 2015 Share Posted March 31, 2015 Which brand did you buy Soren? And how thick material will they work on? Quote Link to comment Share on other sites More sharing options...
