diggervan Posted August 19, 2015 Share Posted August 19, 2015 Hi there as title says passenger won't open from outside or inside so question is does anybody have any ideas how to open it without damaging door card to muchThanks bob Quote Link to comment Share on other sites More sharing options...
miketomcat Posted August 19, 2015 Share Posted August 19, 2015 Have you tried holding the key in the unlock position whilst pressing the button and or holding the lock up inside whilst leasing the button. Sometimes if it's maladjusted or the push rods have bent it snaps back into the locked position as you press the button and then won't open. Mike Quote Link to comment Share on other sites More sharing options...
diggervan Posted August 19, 2015 Author Share Posted August 19, 2015 Yes tried versus things with the keys in /out button up/down to no avail just feels like there's nothing there Bob Quote Link to comment Share on other sites More sharing options...
dave88sw Posted August 19, 2015 Share Posted August 19, 2015 Just had this on mine. The exterior door handle button sticks (not the actual plastic button, the bit behind), with it stuck in the pushed in position, it won't allow the door to unlock. I took the lock button surround off and the interior door handle, pulled the top of the door back a couple of inches then pushed the back of the button back with a long screwdriver. Quote Link to comment Share on other sites More sharing options...
diggervan Posted August 19, 2015 Author Share Posted August 19, 2015 Thanks Dave I'll try something like that tomorrow and see what happens Bob Quote Link to comment Share on other sites More sharing options...
diggervan Posted August 22, 2015 Author Share Posted August 22, 2015 Still can't get the dam thing to open so does anyone have any ideas no matter how daft Bob Quote Link to comment Share on other sites More sharing options...
Anderzander Posted August 22, 2015 Share Posted August 22, 2015 Take the hinges off the bulkhead ? Quote Link to comment Share on other sites More sharing options...
diggervan Posted August 22, 2015 Author Share Posted August 22, 2015 Take the hinges off the bulkhead ?could do but wouldn't the catch still hold door shut on the piller Quote Link to comment Share on other sites More sharing options...
Scotts90 Posted August 22, 2015 Share Posted August 22, 2015 Take off the outer waist seal and with a long piece of welding wire/coat hangar....go fishing. If you know the rudimentary operation of the catch then you'll know what and where to aim for....use the drivers side one for reference if need be. Sounds as though the linkage has popped off the mechanism. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted August 23, 2015 Share Posted August 23, 2015 could do but wouldn't the catch still hold door shut on the piller You're right - I was thinking you might be able to leaver it off, but there must be a less destructive alternative. Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted August 23, 2015 Share Posted August 23, 2015 I had this too - I was able to use a hacksaw and a load of time to cut the keeper. Wind window down, seat forward and cut through the nylon spacer and the bolts inside it. Takes a while but does not make a huge mess. Then fix door problem, replace nylon block and bolts. Sorted. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 23, 2015 Share Posted August 23, 2015 It sounds like the lock operating rod has become detached. If you undo the hinges, and detach the check strap, then the door will pivot open far enough for you to remove the card. Support the bottom of the door, or it'll hang down and get damaged. Les. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 23, 2015 Share Posted August 23, 2015 Or get an axe ... Mo Quote Link to comment Share on other sites More sharing options...
diggervan Posted August 23, 2015 Author Share Posted August 23, 2015 Or get an axe ... Mo that idea is looking more likely managed to pull door card down from the top to see wots wot all linkages as they should be you can see & hear them trying to work but nothing so looks like catch its self so new parts needed and I'll cut though nylon block and bar and replace that as well Quote Link to comment Share on other sites More sharing options...
miketomcat Posted August 23, 2015 Share Posted August 23, 2015 Can you drag the seat forward a cut/grind the nut plate off the back at least it's only nuts and bolts then. Mike Quote Link to comment Share on other sites More sharing options...
diggervan Posted August 23, 2015 Author Share Posted August 23, 2015 Can you drag the seat forward a cut/grind the nut plate off the back at least it's only nuts and bolts then. Mike I'll have a look at doing that tomorrow but idohave a home made Bulkhead right close to seats so not a lot of room Quote Link to comment Share on other sites More sharing options...
