Defender 90 TD5 Tribute Build
Finally! Painting time! I'm using a good quality brush and POR 15 Engine enamel from Frost. It's designed specifically to be used on engine blocks so will withstand higher temperatures and comes in a selection of colours. I've chosen Buick Green, which is as near as makes no difference to the final build colour, Pastel Green. This colour has become ever so popular recently, however, I bought mine about a year ago. Oh well, this is one Defender that isn't just following the crowd!
I know the feeling!! When I decided to go down the route of a Merc engine in my 90 I'd only heard of a couple... Since then loads have appeared on the scene :(
  • 2 weeks later...
Screen-Shot-2015-11-27-at-12.44.57-510x2
This week, I've had my better half working on the bulkhead, removing the remains of the seam sealer so the bulkhead can be sent off to the shot blasters, then to the galvanisers and back to me for painting.
Screen-Shot-2015-11-27-at-12.45.29-510x2
The filter housing corrodes on the TD5, the one we removed was unusable. I replaced it with this new part which is anodised and also took the time to spray the casting cavity with Dinitrol.
Screen-Shot-2015-11-27-at-12.47.05-510x2
Then I fitted up this bracket, ready to accept the panhard rod.
Screen-Shot-2015-11-27-at-12.49.43-510x2
I've chosen to use a heavy duty adjustable panhard rod from Terrafirma. It's well made and looks good. I had to tap it in place with a soft faced hammer.
Screen-Shot-2015-11-27-at-12.51.27-510x2
To get it to fit, I had to adjust it slightly - then use a screwdriver to align the bolt hole. Both bolts then need*torquing*down. I'm having the Defender professionally set-up and aligned at a later date, so the steering arms e.t.c will be adjusted then.
Screen-Shot-2015-11-27-at-12.54.25-510x2
Then I fitted the cross rod eye into the steering arm. This has a counter clockwise thread so it tightens opposite to what you're normally used to.
Screen-Shot-2015-11-27-at-12.56.03-510x2
Then offered up the steering arm. Unfortunately, I've lost the castellated nuts that go onto the track rods so will need to replace those, along with the split pins.
Screen-Shot-2015-11-27-at-12.57.22-510x2
Next I dropped in the new Old Man Emu steering damper. This is a very heavy duty damper, it's fairly easy to fit though I did have to file down the lower bush race slightly (mostly just the powder coat really).
Screen-Shot-2015-11-27-at-12.59.07-510x2
Moving onto the brake callipers, we were shot blasting our old ones, which brought them up a treat. But when you have 4 callipers that need blasting, painting, the seals replacing then refitting 0 the time taken quickly adds up. So, the decision was made to replace them with 4 OEM new brake callipers. We are also swapping*the standard steel*piston callipers with stainless steel replacements. In the past, I've had to rebuild the brakes almost everytime I swapped brake pads - as we cover very little miles in the Land Rover, it allows the callipers to corrode. Then when you come along to replace the pads, the callipers will not retract. Lots of people say "just force them", but if your pistons are binding, this is more friction and thus a less efficient brake.
Screen-Shot-2015-11-27-at-13.00.37-510x2
The easiest way to remove the old pistons is using an air line and blow gun. Be careful though, they fly out with tremendous force! I've had caliber pistons fly 30 feet easily! Then unbolt the calliper halves (this is not recommended by us or any brake manufacturer) but if you do so - you must have a spotlessly clean work area.
Screen-Shot-2015-11-27-at-13.03.49-510x2
This is the*stainless steel replacement, they can be picked up quite reasonably nowadays and should prevent any problems in the future!
Screen-Shot-2015-11-27-at-13.04.56-510x2
When assembling, smear Red Rubber Grease on the piston calliper. These has numerous benefits:
  • It prolongs the life of the rubber seal
  • It reduces the effects of wear from moving parts
  • It helps helps to resist*water ingress / hydroscopic action
  • It's a rust inhibitor
Once smeared in red rubber grease, the piston*should slide smoothly back into place. Repeat for the remaining pistons. When doing the calliper bolts up, it's best to do these as tight as you can.
Screen-Shot-2015-11-27-at-13.07.06-510x2
We sold our 90's old wheels. These were aftermarket & oversized*alloys that wouldn't suit our build, to a fellow Land Rover enthusiast and FunRover fan. In their place, we're fitting Wolf steel rims. We're trying to stick very closely to Land Rover factory fitment options so these suit our build perfectly, whilst still giving us a more vintage Land Rover appearance. Wolf rims are also impressively strong with a high load ratings per corner. These need painting though to match our concept drawings. We've chosen the classic Land Rover wheel colour: Limestone.Screen-Shot-2015-11-27-at-13.12.32-510x2Throughly keying*off our wheels with a 3M red scotchbrite*pad, and blowing away the resulting dust. Anywhere that isn't keyed off will likely not adhere correctly with the paint.Screen-Shot-2015-11-27-at-13.13.01-510x2The whole rim was degreased. After the degreaser evaporated, it was then tack clothed.
Screen-Shot-2015-11-27-at-13.19.23-510x2
Finally, onto painting. We're using a single pack, matt finish acrylic enamel. This one uses Xylene industrial thinners, at a ratio of around 10 / 15%. However, since it's so cold in the workshop, I had to add more to suit. A light coat of paint was added for*the first layer. Subsequent layers were*medium wet. We;d been firing up the space heater prior to painting to raise the ambient temperature and burn off some of the humidity. Paints work best when applied around 20 degrees, so the closer to this mark you get, the better.
Screen-Shot-2015-11-27-at-13.22.29-510x2
The wheels will then be left to cure for a week at least before mounting the tyres. The coat here is still drying, hence the high gloss appearance.
  • 2 weeks later...
Screen-Shot-2015-12-14-at-08.30.03-510x2
This is Spray booth MK2 which I'll show in a future episode, it's working very well, cutting humidity to the low 30s and upping the air temp to a solid 20+ celsius. It means that I can get the whole car painted even if it's freezing outside and the workshop is only 1 or 2 degrees warmer.
Screen-Shot-2015-12-14-at-08.32.03-510x2
Once the wheels had been cured in the booth I took them along to a local tyre fitters
Screen-Shot-2015-12-14-at-08.32.50-510x2
I've chosen the Wolf HD rims (as seen on Heritage edition Defenders). These are tough, strong and quite cheap.
Screen-Shot-2015-12-14-at-08.32.44-510x2
Along with tubeless Goodyear MTR tyres, another factory fit option.
Screen-Shot-2015-12-14-at-08.34.25-510x2
The tyre fitter used a product known as Rim Seal that has anti-corrosion properties as well as adding lubrication for the next step
Screen-Shot-2015-12-14-at-08.35.31-510x2
The tyre fitting machine has a large guide that eases the tyre bead of the lip of the wheel.
Screen-Shot-2015-12-14-at-08.36.34-510x2
Finally, the tyres are inflated to manufacturer specifications, this helps to seat them too (watch the video too see how loud this stage is!)
Screen-Shot-2015-12-14-at-08.38.13-510x2
Here they are mounted up in daylight, the colour and finish is perfect! The SIP HVLP gun I used works well for the money!
Screen-Shot-2015-12-14-at-08.39.31-510x2
The tyre fitting guide can score the lips of the wheel, which is no real problem!
Screen-Shot-2015-12-14-at-08.42.38-510x2
I simply wiped it clean with alcohol then used an artist brush to touch in the scrapes.
Screen-Shot-2015-12-14-at-08.43.17-510x2
Whilst the repairs are drying, I dropped in the pads - EBC Green stuff to match the EBC performance disks. This Land Rover will stop on a penny if needs be!
Screen-Shot-2015-12-14-at-08.44.10-510x2
Not keen on the colour, but the wheels will cover them up!
Screen-Shot-2015-12-14-at-08.44.52-510x2
Lifting the wheels onto the longer Wolf FRC7577 extended wheel studs - expensive but designed to work with the Wolf rim
Screen-Shot-2015-12-14-at-08.45.48-510x2
Nipping the nuts up, they need to be torqued to 170NM after lowering the Landy of it's jacks.
Screen-Shot-2015-12-14-at-08.47.20-510x2
All 4 wheels fitted!
Screen-Shot-2015-12-14-at-08.48.38-510x2
Fitting up the alternator / vacuum pump whilst the engine is still on the stand
Screen-Shot-2015-12-14-at-08.51.24-510x2
This has been painted with a high temp paint to match the rest of the engine
Screen-Shot-2015-12-14-at-08.52.54-510x2
Now it's time to finally drop the engine back in the 90! This feels like it's finally getting somewhere!
Screen-Shot-2015-12-14-at-08.53.40-510x2
The engine needs to be lifted over the front crossmember between the dumb irons. The engine crane is an extremely useful tool, I love it! It's also useful to have 2 people here, one to jack and watch the near side, whilst the other guides in the engine from the other.
Fitting an engine to a rolling chassis is great, there's nothing in the way! Takes about a minute!
Screen-Shot-2015-12-14-at-09.01.44-510x2
And that's it for this week, need to get cracking now as I would still like to hit my deadline of January 1st XD
Hi Winton I noticed you did not check the oil cooler on the engine while it was out. This is common to fail due to corrosion then oil mixers with water. I would suggest you check this. Here in SA we have local more durable aluminium units we replace the oem one with.
  • 2 weeks later...
Wow, love what you are doing. Your attention to detail is fantastic. Great choice on wheels and tyres, does this now mean there will be a nice set going in the for sale page, cough cough. (Y) keep up the good work.
He mentions they were sold in one of the posts.
I wondered about that - but I expect he's trying to keep the budget under control. Leaving nothing untouched is expensive.
The oil cooler is covered in orange corrosion, I hadn't thought anything of it, however, it may be worth buying a repair kit now as you say
Unfortunately, they sold very quickly!
so did'ya make it? its the first...... :ph34r:
In a word, no... but I'm just going to keep building and get it done as soon as I can!
I'm not sure what to do with this now, I can still easily get access to it, but it's yet more money :wacko:
The rear tub is in need of some minor repairs. The tub cappings will be removed and sent off for galvanising. Everywhere else, we have replacement repair sections.
Screen-Shot-2015-12-24-at-10.31.33-510x2
Using a 6mm drill bit, we're drilling into the rivet head, which typically shears off.
Screen-Shot-2015-12-24-at-10.32.03-510x2
Then the crush section of the rivet can be tapped out, this is the quickest way to remove rivets.
Screen-Shot-2015-12-24-at-10.35.19-510x2
There are quite a number of rivets all told on the cappings
Screen-Shot-2015-12-24-at-10.37.53-510x2
In addition to rivets, the cappings are typically held on with some mild adhesives / foam tape and can then be lifted away. Those will be going to the galvanisers along side the bulkhead and will be fitted unpainted to the 90 for that classic Land Rover appearance.
Screen-Shot-2015-12-24-at-10.31.21-510x2
Cappings gone, you can see the Zinc Phosphate primer applied at the factory. Over the primer, the tub is currently overcoated in 2 pack (Chawton White). We'll be going to the classic (and now rather popular) Pastel Green, a Series 1 colour
Screen-Shot-2015-12-24-at-10.38.59-510x2
These seatbelt mount brackets panels came from YRM Metal Solutions. They've been laser cut, CNC folded and galvanised. The result is excellent tolerances and a lasting repair!
Screen-Shot-2015-12-24-at-10.39.45-510x2
Fitting is easy, the old seat belt mount bracket is removed.
Screen-Shot-2015-12-24-at-10.41.42-510x2
And any flaky aluminium corrosion is stripped away with a wire wheel.
Screen-Shot-2015-12-24-at-10.42.33-510x2
We applied Dinitrol cavity wax to the tub, before offering up the repair section.
Screen-Shot-2015-12-24-at-10.49.04-510x2
It's supplied in 2 pieces (otherwise it wouldn't fit), there are a few holes that have captive nuts so bolts were installed to hold the panel in place, along with a G clamp.
Screen-Shot-2016-01-07-at-08.46.50-510x2
Before drilling the holes for each fixing.
Screen-Shot-2016-01-07-at-08.48.16-510x2
There are a total of 48 M8 bolts required. Once secured, these panels are very strong! There's zero movement and the whole lot will be overcoated with stone chip for further protection.
Screen-Shot-2016-01-07-at-08.52.59-510x2
Moving onto the strike plate, this often corrodes where the tub fits to the sill rail, due to bimetallic reaction. The aluminium turns to a powder and is completely unusable.
Screen-Shot-2016-01-07-at-08.51.46-510x2
So to repair we'll fit new strike plate sections from YRM too. These are pretty simple to fit, and once prepared and painted, it should be as good as new.
Screen-Shot-2016-01-07-at-09.20.51-510x2
We're starting by marking off where we'd like to cut off the strike plate.
Screen-Shot-2016-01-07-at-09.21.16-510x2
And using a spot weld drill to remove the spot welds and rivets below the line, including on the seal retainer.
Screen-Shot-2016-01-07-at-09.21.51-510x2
Then, using a bolster chisel and a scraper, we can begin to prise the 2 skins apart
Screen-Shot-2016-01-07-at-09.32.33-510x2
Finally, we scored a mark with a Dremel multi tool along the line. Then we were able to fracture the corroded part off, with a clean break formed along our score.
Screen-Shot-2016-01-07-at-09.54.22-510x2
I'll be fitting the new sections in another video, shown here is the exposed rear skin.
Screen-Shot-2016-01-07-at-09.56.09-510x2
The floor too has suffered with some corrosion and needs replacing. The dome rivets need to be ground down, others will need to be drilled and others still, cut with a grinder.
Screen-Shot-2016-01-07-at-09.57.17-510x2
The floor has adhesives applied in key areas, so it can take some time with a breaker bar & hammer to separate the floor from the supports.
Screen-Shot-2016-01-07-at-10.08.24-510x2
After all rivets have been drilled out, the floor will lift out
Screen-Shot-2016-01-07-at-10.09.35-510x2
Now's a good time to assess the condition of the tub supports. We can also throughly rust proof these whilst they're exposed.
Screen-Shot-2016-01-07-at-10.33.43-510x2
Finally, my plumber wife kindly began brazing some of the redundant holes in my tub, using the excellent Lumiweld from Frost.co.uk. You can check out the results at the end of the video, it's impressive stuff! And is formulated to work on Birmabright!
I've ordered a replacement, thanks for the input, it really helps me try to pre-empt any issues down the line ;)
Screen-Shot-2016-01-08-at-13.16.35-510x2
One of the many brilliant things about YouTube is that we can get feedback directly from our viewers. Some of these these comments are very useful (in fact*we read and respond to every single one). One fan told us a woeful story when he had to remove his gearbox for a 2nd time after forgetting*to change the rear crankshaft oil seal on a high mileage TD5. So a replacement was sort from LR Parts.
Screen-Shot-2016-01-11-at-08.19.40-510x2
Once the*new item was in place (see video for fitting), the spigot bush was pressed into place. This had*been soaked in engine oil for a few days. This is an old school trick I read about that helps sintered bronze bushes (which are supposedly*porous) to add extra lubrication to a material that is already self-lubricating. I've read of premature spigot bush failings and figured it was worth a shot. The rear of the engine block was cleaned up too.
Screen-Shot-2016-01-11-at-08.35.05-510x2
Once cleaned off, the gearbox shim plate / cover and DMF were fitted up. You can purchase a flywheel holder to fasten down the 2 stage bolts, or simply get someone else to hold it. The bolts are tightened up by*diagonal selection (star pattern).
Screen-Shot-2016-01-11-at-08.41.07-510x2
The clutch cover (and flywheel) were*cleaned up using Brake & Clutch cleaner.
Screen-Shot-2016-01-11-at-08.46.20-510x2
Using a clutch alignment tool (these are available on eBay at a good price), the clutch plate was offered up and correctly positioned.
Screen-Shot-2016-01-11-at-08.46.48-510x2
And the 3/8 torque wrench broken out to secure down the clutch cover
Screen-Shot-2016-01-11-at-08.48.48-510x2
Moving onto the transfer box, this needed to be reunited with the reconditioned R380. I toyed with the idea of fitting a Discovery transfer box, with it's preferable ratio that offers lower revs at cruising speeds. *On balance, I decided against fitting the disco box as I*rarely go on substantial motorway trips to warrant such a change. This was most easily achieved by standing the gearbox on end, then square lifting the transfer box onto the output*shaft of the gearbox.
Screen-Shot-2016-01-11-at-08.52.33-510x2
Torque settings can be found in the manual. We'll re-finish the hand brake drum once the gearbox is in place, as it will undoubtedly get scratched during fitting.
Screen-Shot-2016-01-11-at-08.59.44-510x2
The gearbox and transfer box are joined once more! Incidentally, I've been making use of some carpeted plywood panels as assembly mats. We removed them from the 90*on disassembly, but they've proven useful at preventing newly painted components from getting marked and scuffed*up.
Screen-Shot-2016-01-11-at-09.00.47-510x2
We next fitted the clutch release bearing guide (of which I now have 3, thanks to ordering one part that was completely wrong and losing my original one and then finding it a few days later). The clutch fork, push rod and clips such as this one above that prevent the whole lot from*dislodging and destroying the clutch plate, were secured also. Molybdenum grease was used in appropriate areas.
Screen-Shot-2016-01-11-at-09.01.26-510x2
The engine ready to receive the gearbox /transfer box assembly.
Screen-Shot-2016-01-11-at-09.07.19-510x2
An engine crane is worth it's weight in gold here. A second pair of hands (thanks Phil, he always brings biscuits!) make lighter work of aligning the box, as does a high lift*trolley jack to fine tune positioning. Strap the gearbox to the crane as though the bell housing wasn't present as this weighs almost nothing. Try go diagonally across the gearbox casing and transfer box to get as level*a lift as possible.
Screen-Shot-2016-01-11-at-09.08.27-510x2
Reconditioned gearbox meets the engine for the first time! Meshing the splines together was a little tricky and took a while, but once done, it's very satisfying! Need to fire some oil in both of those now. I'm going to run some cheap oil*through both to flush them out (just in case)
Screen-Shot-2016-01-11-at-09.09.39-510x2
Took the chance to renew the gearbox mounts whilst I had access. These are OEM replacements.
Screen-Shot-2016-01-11-at-09.10.28-510x2
The slave cylinder and associated pipes were looking worse for wear. It was decided to replace them as the cost isn't particularly prohibitive and it's an easy job.
Screen-Shot-2016-01-11-at-09.11.19-510x2
The only original parts saved were the bracket and the nuts (albeit,*cleaned up on the wire wheel and the bracket was sanded and painted). I've popped a pen lid on there to stop any dirt from the ceiling dropping in (there's a shop*above mine and when they walk around, tiny specs of chipboard*dust fall everywhere)
Screen-Shot-2016-01-11-at-09.37.03-510x2
Once that's sorted, I can put my new props on. In the end, the decision came down to either reconditioning the old ones, replacing them with large and expensive HD ones or just purchasing new OEM ones. I chose OEM ones from Britpart as I've been told these are produced by Hardy Spicer (well, GKN as they bought out HS apparently). Time will tell if this was the right decision. Fitting the props is made easier if you jack up one wheel, allowing the transmission to freely rotate.
Screen-Shot-2016-01-11-at-09.37.50-510x2
I'll grease those UJs and props again before running the vehicle, once offered up, fixings were lightly greased to prevent seizing up, and torqued down to 48nm. A propshaft socket is very handy here, you'll also need a 9/16 spanner*(some owners make a 14mm combination*work, though this isn't quite the right size and can cause nut rounding)
Screen-Shot-2016-01-11-at-09.39.38-510x2
Props in place
Screen-Shot-2016-01-11-at-09.54.33-510x2
I've fitted the oil cooler, however some owners have contacted me suggesting an upgrade to this area - will feature that in a coming episode.
Screen-Shot-2016-01-11-at-09.58.08-510x2
I managed to accidentally format my SD card the other week, losing a lot of engine re-assmebly clips! And a rather humorous one of me putting the inlet manifold into a dishwasher, before the dishwasher began to spew diesel and oil*bubbles all over the kitchen. The wife, needless to say, wasn't impressed.
Screen-Shot-2016-01-11-at-10.06.19-510x2
Inlet manifold and fuel cooler in position.
Screen-Shot-2016-01-11-at-10.22.08-510x2
The painted turbo and exhaust manifold, we used grey POR 15 high temperature*manifold paint from Frost.co.uk.
Screen-Shot-2016-01-11-at-10.23.08-510x2
You might*remember that our manifold had warped and snapped studs. This is a common issue on Td5's. The easiest fix (and most cost effective) is to remove the manifold and have it skimmed true and dewebbed. The theory is that the casting*has warped and shouldn't warp again. Once it's been engineered back to acceptable tolerances, you can fit longer studs from AliveTuning or similar with spacers to help prevent the studs from snapping again. We purchased a set of 16mm stainless steel spacers from eBay, along with an extended stud kit and then painted the whole lot*to match the turbo. It shouldn't ever shift*again and the cost was preferential to that of a custom stainless or ceramic coated manifold.
Screen-Shot-2016-01-11-at-10.28.01-510x2
Removing broken studs: you can try stud extractors (didn't work for me), drilling and retapping, drilling and helicoiling or welding a nut onto the end of the stud and removing that way.
Screen-Shot-2016-01-11-at-10.28.26-510x2
This works well as the heat from welding helps*free up*the threads*and the whole stud*should simply*wind out.
Screen-Shot-2016-01-11-at-10.29.59-510x2
The manifold skimming*cost £90 in the end from a local machine shop. This was considerably cheaper than £500+ for a stainless part.
Screen-Shot-2016-01-11-at-10.31.52-510x2
These M8 16mm spacers were purchased from eBay and match our Wurth extended studs nicely.
Screen-Shot-2016-01-11-at-10.39.13-510x2
The kit also includes a washer and copper flashed nut, helping avoid*corrosion issues.
Screen-Shot-2016-01-11-at-10.32.47-510x2
Here's the manifold in place, complete with it's spacers. It certainly looks the part and shouldn't warp again. I also fitted 2 gaskets because when I removed it, there were 2 gaskets - probably a service bulletin fix from a dealer!
Screen-Shot-2016-01-11-at-10.36.46-510x2
Next time, we can fit up our stainless exhaust system, weld the bulkhead and sort out the brake pipes.
  • 3 weeks later...
Latest video is here:
Screen-Shot-2016-01-22-at-13.05.28-510x2
First job of the week was removing old waxoyl and factory applied stone chipping material. When perusing the workshop manual, I noticed that Land Rover recommend dealers use an air powered scraper. These things are superb! Probably my favourite tool at the moment, the whole tub was stripped in under an hour, ready for a reapplication of stone chipping.
Screen-Shot-2016-01-22-at-13.17.56-510x2
With that done, I moved my attention to the injector loom harness. On the TD5, oil eventually wicks along the wiring into the ECM - this had happened with our vehicle. Hopefully, we've caught it in time. The ECM has been drained and cleaned.
Screen-Shot-2016-01-22-at-13.22.46-510x2
After removing the rocker cover, it's simply a case of removing the electrical connects for each injector.
Screen-Shot-2016-01-22-at-13.23.59-722x3
And then prizing out the main connector for the harness. The new harness drops into place in the same manner. All told, with no body on the vehicle - this takes around 5 minutes.
Screen-Shot-2016-01-22-at-13.26.59-722x3
Dropping the rocker cover back onto a new gasket.
Screen-Shot-2016-01-22-at-13.29.17-722x3
One of the great things about building a Land Rover in the manner we have, involving a huge community of Land Rover owners, is that we can get real time feedback. One viewer asked us to show how to replace this cylinder head coolant plug. So the exhaust manifold was removed again, and a 12mm allen key sourced.
Screen-Shot-2016-01-22-at-13.29.37-722x3
A set of hex sockets are useful to have in the toolbox.
Screen-Shot-2016-01-22-at-13.31.32-722x3
As you can apply more force to the socket handle than a humble allen key. The new plug winds in quite nicely.
Screen-Shot-2016-01-22-at-13.32.56-722x3
Following the advice of another viewer, we removed the oil cooler housing to replace the internal cooling block. The rotor oil filter housing needed to be removed.
Screen-Shot-2016-01-22-at-13.32.44-722x3
And the whole thing is lifted clean off.
Screen-Shot-2016-01-22-at-13.33.33-722x3
After stripping it down, we found ours to be in good condition, if not slightly tarnished from coolant / rust.
Screen-Shot-2016-01-22-at-13.36.28-722x3
The cooling block is secured by 2 banjo bolts (internally relieved fixings). Thee are not overly tight and so easy to undo.
Screen-Shot-2016-01-22-at-13.37.35-722x3
The old coolant block.
Screen-Shot-2016-01-22-at-13.37.55-722x3
And the new one dropped in
Screen-Shot-2016-01-22-at-13.38.09-722x3
Along with the 2 supplied replacement banjo bolts. An internally rubberised washer sits under the head.
Screen-Shot-2016-02-05-at-08.09.46-510x2
The gaskets on the oil rotor to sump pipe are also replace
Screen-Shot-2016-02-05-at-08.10.36-510x2
As we're nearing the point where I'd like to drop the main belt on, I decided to bolt up the power steering pump. This had been reconditioned.
Screen-Shot-2016-02-05-at-08.14.02-510x2
Now it's time to fit the exhaust. As we're fitting a few tasteful performance upgrades, we've gone for a stainless steel straight through exhaust (with an end silencer). When combined with the Td5, this produces a lovely, throaty burble - with the added benefit of long term corrosion resistance.
Screen-Shot-2016-02-05-at-08.27.04-510x2
Starting at the turbo, we dropped a new gasket onto the down pipe and bolted the exhaust to the lower face of the turbo outlet. The 10P Td5 doesn't have a CAT or DPF, instead it has a braided flexi joint.
Screen-Shot-2016-02-05-at-08.27.18-510x2
I took the time to replace all the exhaust mounts. Unfortunately, one of them was only available as a genuine part - pricey stuff! This is the mount for the mid pipe.
Screen-Shot-2016-02-05-at-08.31.36-510x2
The rear silencer section can be carefully rotated into place without the need for removing any parts
Screen-Shot-2016-02-05-at-08.32.57-510x2
Time to bust out the welder. I've been using Hobby Weld 5, it's a superb gas to weld with for, well, hobby welders! There's no canister fees to pay and there are dealers all over the country. Hobby Weld 5 is perfectly suited to MIG welding thin metal, which we are about to do, when we repair the bulkhead.
Screen-Shot-2016-02-05-at-08.33.30-510x2
If you are hobby welder, or weld infrequently, Hobbyweld shielding gases are very cost effective. I also spent a bit of time replacing the torch wire liner, fitted some new tips and shrouds and it's transformed my welds!
Screen-Shot-2016-02-05-at-08.34.00-510x2
The bulkhead had some pitting that was revealed after blasting. I also stored this in the workshop for a while, which isn't the driest environment, so further rust formed on the surface. Only slightly worse than mill scale though.
Screen-Shot-2016-02-05-at-08.35.13-510x2
This area too had some corroded metal. Fortunately, there are companies who now produce replacement sections for commonly rusted out areas. Namely YRM Metal Solutions. In this case, I decided to have a go at localised repairs, using pieces that I'll fabricate myself.
Screen-Shot-2016-02-05-at-08.46.22-510x2
First, the corroding areas were marked and cut out
Screen-Shot-2016-02-05-at-08.52.12-510x2
I wanted to get back to sound metal to weld my repairs to
Screen-Shot-2016-02-05-at-08.56.00-510x2
Then I made a cardboard template, this works really well for getting a perfect outline of the repair section to be made
Screen-Shot-2016-02-05-at-09.26.56-510x2
I picked up a Clarke sheet metal folder to use in matching our repair piece to the form lines of the bulkhead.
Screen-Shot-2016-02-05-at-09.46.14-510x2
Then MIG welded the repair section in. I tacked the panel every inch or two, to try prevent warp, before filling in sections randomly.
Screen-Shot-2016-02-05-at-09.47.57-510x2
The end result is a sound repair piece, even if my welds required a lot of grinding. Then, we shipped the whole lot off to the galvanisers.
Making some good progress there. I'm keen to see how the retro dash turns out, and how you manage to hide all of the TD5 wiring in it.
Thanks Dave! It's an experiment, but one we are committed to making work. Some of the wiring will be hidden behind false panels, others in what appear to be demister pipes
Wouldn't it be best to shim the bulkhead position before fitting the sills? You need to bolt up the back end of the tub (leave the front loose for vertical adjustment to align with the curve in the side of the bulkhead), and then set the door aperture length by using washers between the bulkhead feet and outrigger. Once that is set, you can accurately and finally position the sills, using washers if necessary, to set their longitudinal position accurately to match the wheel arch position and to be symmetrical. If you don't do that, the gaps around the door edges will be uneven and the sills won't end at the same relative positions from one side to the other.
  • 2 weeks later...
  • 1 month later...
