western Posted January 16, 2016 Share Posted January 16, 2016 Thought I'd have a go at finding out why my 110's rear wiper wouldn't run, removed from door, wired across a spare battery & it runs [but won't on 110 with wiper blade on the glass] so dismantled the motor part, retained all the bits, got some grease into it via motor shaft hole & park switch hole, so far so good, doing this outside in my driveway [big mistake] popped the armature/shaft back in, then the brushes which have a 'n' shaped spring clip to keep brushes on commutator, got one side in, then spring decides to go for a flying lesson, heard it 'ping' as hit the 110's rear door, can I find it, not a chance disappearded in to bit of garden alongside driveway, moved 110, swept the drive, no sign of the spring, not happy got to buy a new wiper motor tomorrow, this old one's shaft to wiper arm is almost seiezed up, so not a totally loss. my type of motor is No Longer Available [prc4612 - see photo] got to buy the later [300tdi - amr3676] & adapt my wiring to suit the new type of motor. more to come when I get to fit it. Quote Link to comment Share on other sites More sharing options...
Frax Posted January 16, 2016 Share Posted January 16, 2016 You need to get hold of a metal detector or large magnet, I hate them clips they always make a dash for it. When I fit them and "C" clips I try to cover them with a rag so they don't ping. They are a pain in the rear end. Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted January 16, 2016 Share Posted January 16, 2016 The td5/300tdi rear motor is far better than the old one anyway, there's more sealing to prevent water ingress and the spindle housing is plastic to prevent the spindle from rusting to it. 1 Quote Link to comment Share on other sites More sharing options...
western Posted January 16, 2016 Author Share Posted January 16, 2016 recovered the original wiring from old now deceased motor, wiring is cleaned & ready to live again supplying the new motor, got to source a 3 pin econoseal plug, I can get that locally too. Quote Link to comment Share on other sites More sharing options...
marktdi Posted January 17, 2016 Share Posted January 17, 2016 I have a rear wiper set up off a 200tdi in the garage if it is of use to you . It worked fine when i removed it last year . Not sure what its worth but i can post it to you Quote Link to comment Share on other sites More sharing options...
pete3000 Posted January 17, 2016 Share Posted January 17, 2016 Is the info in my link from ages ago any good to save cash on a 300tdi on one? not sure which part you have lost Western. I.e would a rr classic fit amr3957 http://forums.lr4x4.com/index.php?showtopic=55437&hl=%2Brear+%2Bwiper#entry799429 Quote Link to comment Share on other sites More sharing options...
western Posted January 17, 2016 Author Share Posted January 17, 2016 Mark, thanks for the offer would prefer a new motor & have a indy LR parts guy at other end of town, going to ring him tomorrow, Pete, cheers for the link to Quote Link to comment Share on other sites More sharing options...
reb78 Posted January 17, 2016 Share Posted January 17, 2016 Im thinking of removing my rear wiper when i change the back door. I cant see much out of it when it is clean in the daylight and in the dark all i can see is the reflection of whats in front of me anyway! Quote Link to comment Share on other sites More sharing options...
western Posted January 17, 2016 Author Share Posted January 17, 2016 recovered the original wiring from old now deceased motor, wiring is cleaned & ready to live again supplying the new motor, got to source a 3 pin econoseal plug, I can get that locally too. opened up the original motors park switch, I don't know if any one has done it before. 1st photo the internals all plain colour wires. brown green black the plug end which matches pre 300tdi vehicles has 5 wires 2 x black = earth for motor & park switch on one pin red = 12v feed to motor green = signal from dash switch to park switch brown = 12v feed from dash switch to park switch to connect to the later motor. [300tdi on] red = to motor black to motor & park switch earth green to park switch White/green brown to park switch brown/light green Quote Link to comment Share on other sites More sharing options...
western Posted January 18, 2016 Author Share Posted January 18, 2016 (edited) new motor acquired through my local LR parts supplier [had it in stock] 3 pin econoseal plug on order,need to source the 2 pin plug for the motor connections PaulMc do you know what plug I need please ? see 2nd photo,would prefer to use the correct part if possible or I'll fit 2 2.8mm female spade terminals to the motor wires.Paul, I found this thread -- https://www.landyzone.co.uk/land-rover/rear-door-wiper-connector.294166/same male plug that I need, do you still have any Edited January 18, 2016 by western Quote Link to comment Share on other sites More sharing options...
PaulMc Posted January 18, 2016 Share Posted January 18, 2016 Paul, I found this thread -- https://www.landyzone.co.uk/land-rover/rear-door-wiper-connector.294166/ same male plug that I need, do you still have any Ralph, Yes, I still have those connectors They are £0.60 + postage. I'll reply to your PM with my PayPal details. Cheers, Paul. 1 Quote Link to comment Share on other sites More sharing options...
western Posted January 18, 2016 Author Share Posted January 18, 2016 Thanks very much, you should see a paypal message & a PM reply. Quote Link to comment Share on other sites More sharing options...
western Posted January 22, 2016 Author Share Posted January 22, 2016 using my original rear wiper harness & with the new connectors, I've made my own conversion harness [same as STC1825 but at a lot less expense, photo 1 below] for the new wiper motor. connected & tested on my 110, it works so happy so far, just waiting on the outer nut,grommet,washers to arrive then I can get it fitted to the rear door. my converted harness fitted to new motor, photo's 2,3,4. Quote Link to comment Share on other sites More sharing options...
western Posted January 30, 2016 Author Share Posted January 30, 2016 finished the new rear wiper motor fit today, had to adjust the rear door wiper spindle holes as the new motor shaft is thicker than the old original motor & sort a hole for the motor anti twist screw, straight into door frame. this new motor is a 300tdi item AMR3637. got to source the trim cover & screws, think that'll be a ebay job. Quote Link to comment Share on other sites More sharing options...
PaulMc Posted January 30, 2016 Share Posted January 30, 2016 If you fit the latest type of rear wiper arm - LR033006 It uses the same wiper blades as the front wipers - DKC000110PMD . Quote Link to comment Share on other sites More sharing options...
western Posted January 30, 2016 Author Share Posted January 30, 2016 I used this wiper arm http://www.ebay.co.uk/itm/281507238945?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT hook type end & this blade to match http://www.ebay.co.uk/itm/271856254490?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITboth fitted & work fine, my old arm had a side pin fitting to wiper blade Quote Link to comment Share on other sites More sharing options...
PaulMc Posted January 30, 2016 Share Posted January 30, 2016 I used this wiper arm http://www.ebay.co.uk/itm/281507238945?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT hook type end & this blade to match http://www.ebay.co.uk/itm/271856254490?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT both fitted & work fine, my old arm had a side pin fitting to wiper blade That's the one PRC8558 ↓ Superseded by DKB000370PMD ↓ Superseded by DKB000371PMD ↓ Superseded by LR033006 . 1 Quote Link to comment Share on other sites More sharing options...
western Posted January 30, 2016 Author Share Posted January 30, 2016 the actual bit that fits on wiper motor shaft is the same shape/size as my old wiper arm but different fitting to the blade. Quote Link to comment Share on other sites More sharing options...
PaulMc Posted January 30, 2016 Share Posted January 30, 2016 I fitted one of the later arms to my 110, which still has the original 1989 wiper motor. As you say, the newer arm fits without problem. I was having trouble finding the original side-pin rear wiper blades, other than Genuine from a main dealer. . Quote Link to comment Share on other sites More sharing options...
western Posted January 30, 2016 Author Share Posted January 30, 2016 think I had a bit of a search for the last side pin arm luckily my local LR parts outlet had them in stock, so saved the day, next time it'll be easier to replace. Quote Link to comment Share on other sites More sharing options...
western Posted February 5, 2016 Author Share Posted February 5, 2016 new motor has had it's work load increased over the last few days, also obtained the correct trim cover for the motor, but I think I need to re-orientate the assembly to get the cover brackets on the horizontal level, as the cover isn't siting square to the rear window. also a few years ago I bought one of simonb's rear wiper intermittent wipe/wash relay kits, that is still working fine & means the new motor isn't running continuously in bad weather. Quote Link to comment Share on other sites More sharing options...
western Posted February 13, 2016 Author Share Posted February 13, 2016 sorted the motor position & trim cover all sat square to the door frame/glass now, so that job is complete. Quote Link to comment Share on other sites More sharing options...
western Posted August 25, 2018 Author Share Posted August 25, 2018 further to the above rear wiper motor swap, is the wiper arm drive spindle able to be removed ? mine seems to be partly seized, it will work but on if moved by hand, will be having another go this week,Oh & I broke the washer above the back door when refiting the nut after making sure it wasn't blocked up, so got to buy a new rear washer jet now, Quote Link to comment Share on other sites More sharing options...
western Posted August 31, 2018 Author Share Posted August 31, 2018 further to the above question, no the wiper spindle & its plastic tube is not easily removeable, the tube is clipped/locked into the metal body, so I'm looking at another motor now cos this on is dead, so off to ebay or ring my local LR parts man in morning to see if he has one in stock. not a very productive afternoon, But I did fit the new rear screen washer jet, so that bits fixed at least. Quote Link to comment Share on other sites More sharing options...
western Posted September 1, 2018 Author Share Posted September 1, 2018 wiper motor installed & working, this one is LR part LR078424 it supersedes AMR3676 & it a direct replacement, the small 2 pin connector on this new motor only has one wire + positive to it, but the wiring for the amr3676 motor doesn't need any changes. Quote Link to comment Share on other sites More sharing options...
