Yolandi Posted March 9, 2016 Share Posted March 9, 2016 Hi again, im looking into new injector lines and was wondering if i could make some up using stainless steel braided hose and AN connectors, does anyone know the max pressure in the lines to the injectors? Quote Link to comment Share on other sites More sharing options...
Maverik Posted March 10, 2016 Share Posted March 10, 2016 I'm sure it probably tells you in here... http://gnarlodious.com/vanagon/bosch_pump/Bosch_VE_Pumps.pdf Quote Link to comment Share on other sites More sharing options...
Yolandi Posted March 10, 2016 Author Share Posted March 10, 2016 Thanks, little confused, under VE pumps, max nozzle pressure says 1,200/350 bar, what does this mean? Quote Link to comment Share on other sites More sharing options...
western Posted March 10, 2016 Share Posted March 10, 2016 I would suggest staying with the original or new original spec pipes, they will have been pressure tested at manufacture to ensure a good safety margin. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted March 10, 2016 Share Posted March 10, 2016 The pressure of the fuel as it's sprayed in to the combustion chamber at a guess, that's where the nozzle is Quote Link to comment Share on other sites More sharing options...
Yolandi Posted March 10, 2016 Author Share Posted March 10, 2016 Right, the hose im looking at is max operating 1000psi and 3000 burst, would this be suitable? Quote Link to comment Share on other sites More sharing options...
western Posted March 10, 2016 Share Posted March 10, 2016 Thanks, little confused, under VE pumps, max nozzle pressure says 1,200/350 bar, what does this mean? Defender workshop manual states injector working pressure as 1st stage 200atms & 2nd stage 280atms, as theses are 2 stage injectors made by bosch. 200 atmosphere [standard] = 2,939 pound/square inch 280 atmosphere [standard] = 4,114pound/square inch IIRC these pressures are within the injector body. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 10, 2016 Share Posted March 10, 2016 What are you expecting to gain by this? Quote Link to comment Share on other sites More sharing options...
Yolandi Posted March 10, 2016 Author Share Posted March 10, 2016 Ah i see, probably see if i can get some chromed injector pipes or something like that then, this was simply to improve the look of my engine bay Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted December 5, 2020 Share Posted December 5, 2020 Resurrecting an old post.. Can you just remove the pipes to injectors or are they pressurised?? Looking to get injectors either replaced or cleaned up thanks Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted December 5, 2020 Share Posted December 5, 2020 Found this thread because you responded. I am curious about the result. In my eyes it doesn't work, because any hose will be to soft. You can easily remove the lines. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted December 5, 2020 Share Posted December 5, 2020 8 hours ago, Chambo110 said: Resurrecting an old post.. Can you just remove the pipes to injectors or are they pressurised?? Looking to get injectors either replaced or cleaned up thanks Yes just unscrew. They are full so they will drop. 1 Quote Link to comment Share on other sites More sharing options...
Chambo110 Posted December 5, 2020 Share Posted December 5, 2020 Great stuff cheers Vulcan Quote Link to comment Share on other sites More sharing options...
