western Posted January 10, 2015 Share Posted January 10, 2015 Air intake [Raised/snorkel] Safari snorkel template [300tdi onwards] Axles/Diffs/Driveshafts Axle refurbishmentBrakes X-Brake servicing/overhaulX-Brake fitting to 110 RR or Discovery 1 handbrake lever fit to a 90 or 110 Defender [1983 to 2016 only] Clutch & Gearbox Fitting a 300tdi Clutch pedal springElectrical & Instruments Substitute driving light switch for TD5 center console Td5 instrument pack fitting to older 90/110 modelsIntermittent front wiper relay change & mod for older vehiclesHeadlight wiring upgrade 1Headlight wiring upgrade 2step by step to wiring spotlightsroof mounted front lightbar wiringlow coolant level alarm 1low coolant level alarm 2Replacing cigarette lighter with USB socket (wiring)Defender Triple Wiper Upgrade front screen washer upgrade 1front screen washer upgrade 2Heated Washer Jetsclear lens headlights 1clear lens headlight 2LED sidelights and indicatorsHow to fit a Dual Din to a TD5 dash consoleIgnition Systems MS-Megasquirt/JoltReversing camera & dash camera Reversing camera kit Reversing CCTVIn Cab Video Recorder Suspension & Steering Discovery drop arm on DefenderFitting PAS to a SeriesLR using standard LR parts 2 Link to comment Share on other sites More sharing options...
