Simon_CSK Posted December 29, 2016 Share Posted December 29, 2016 I have a 12 spline bolt stuck in the head of a V8 block. The block is out of the car and is one of the exhaust manifold bolts. Unfortunately the splines have stripped. Can someone give me a step for a hint as to how I can get it out. have thought about cutting the manifold but not sure how this will help. Quote Link to comment Share on other sites More sharing options...
Fatboy Posted December 29, 2016 Share Posted December 29, 2016 Irwin bolt removers are excellent. They have a left hand flute in them and the set has various sizes. If there is anything proud of the fastener you want to remove, they are worth a try. Otherwise, weld a nut on and proceed as per normal? Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted December 29, 2016 Share Posted December 29, 2016 I did a full set of head studs on a stag v8 once in situ by welding a couple of nuts to the stud then winding them out Otherwise heat them up or get a screw extractor set? Quote Link to comment Share on other sites More sharing options...
reb78 Posted December 29, 2016 Share Posted December 29, 2016 Irwin extractor or weld a nut on as above. My experience of the screw extractors is they snap! Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 29, 2016 Share Posted December 29, 2016 I've had good results times over with the Irwin nut extractors, you have to chap them on then twist and sometimes a bit more chaping before you really put your weight into it. I've removed countless stuck calipers bolts this way. These shouldn't be confused with the "tap" type reverse helical extractors, in which I've never had any success... Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted December 29, 2016 Share Posted December 29, 2016 I'd personally weld a nut on..... then lots of wd in an attempt to save the thread in the head and undo it gently..... Quote Link to comment Share on other sites More sharing options...
rebel_eddie Posted December 29, 2016 Share Posted December 29, 2016 Bolt extractor is the way to go. Drill the bolt first but before you insert the extractor. 1. Heat the bolt to a dull red with a blow torch. 2. Use a can of Wurth Rustoff ice spraying the hot Bolt. This with thermal shock the bolt and allow the Rustoff ice to creep into the threads. 3. Use the extractor to unwind the bolt. The Urwin extractors are ok but I have had them slip. The better ones are the Snap-on paraellel extractors. But they are pricy. If you don't have any Rustoff Ice go buy some you will not regret it and there are loads of uses on a landrover. If you cannot get any you can use WD40 but I have had mixed results with WD40. Good luck. Ed Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted December 29, 2016 Author Share Posted December 29, 2016 Thanks guys for some reason I had a total mental blank. I have no access issues and have bolt extractors so will try and find them to use if not will go for the weld. The block it on the floor and can put it on its side to get good purchase my fear is snapping off the head of the bolt. Quote Link to comment Share on other sites More sharing options...
duncmc Posted December 31, 2016 Share Posted December 31, 2016 Did you get that bolt out Simon? I would personally do the weld thing too. Bolt extractors don't work very well for me either. Just google Keith fenner easy out and look on Youtube for the "So you broke it off in your hole". Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted January 2, 2017 Author Share Posted January 2, 2017 On 12/31/2016 at 11:15 AM, duncmc said: Did you get that bolt out Simon? I would personally do the weld thing too. Bolt extractors don't work very well for me either. Just google Keith fenner easy out and look on Youtube for the "So you broke it off in your hole". Dunc Hit a few snags one of which is I cannot find my welding rods so have ordered some new ones. Will get back to it later this week hopefully. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 3, 2017 Share Posted January 3, 2017 I wouldn't weld a nut on as a first attempt - if it shears you have an even bigger problem trying to remove what little you have left. Use an Irwin extractor first and if it fails, then you still have a rounded thread to then weld a nut to. Les. Quote Link to comment Share on other sites More sharing options...
Simon_CSK Posted January 7, 2017 Author Share Posted January 7, 2017 Nightmare over Bought Irwine bolt extractors but they failed to find a grip because the splined head was too badly rounded. So opted for the welding method. Having not been able to find a nut quite big enough to go over the splines I decided to drill out the thread of the nut which also cleaned the zinc coating I then welded. My welding is not that great but after two attempts I got the bolt moving until it snapped off. More welding and a little coaxing and it eventually came off. Tomorrow I can now switch the two engines over and hopefully by next week have by beloved P38 back in use..........Then I can think about doing the same to the Disco As usual thank for your help guys. Quote Link to comment Share on other sites More sharing options...
duncmc Posted January 7, 2017 Share Posted January 7, 2017 Well done! Result. Quote Link to comment Share on other sites More sharing options...
02GF74 Posted January 23, 2017 Share Posted January 23, 2017 Awesone, its one of those situation that if it goes wrong, the problem gets more difficult. Must google these irwin extractors. Quote Link to comment Share on other sites More sharing options...
