ianmayco68 Posted August 6, 2017 Share Posted August 6, 2017 Hi all I've got a 200tdi 110 11L engine and I think my actuator on the turbo is on its way out, I've adjusted it for extra boost and its virtually got no thread showing on the rod and still not got 1bar and if I put a pair of mole grips on the end of the rod I can push the waste gate open with my thumb and its not much of a struggle. So I thought I'd replace the actuator found the part number STC960 but only places I can find them for sale is Britcar and LR Direct at over £200 a pop ouch . So does anyone know were I can get one cheaper or know if one of another turbo like a 300tdi will fit as I can find loads for a 300tdi on ebay. Thought I'd ask on here to see if anyone can help before I start sending emails to every turbo rebuilders in the uk when most proberbly won't even bother replying . cheers Ian Quote Link to comment Share on other sites More sharing options...
western Posted August 6, 2017 Share Posted August 6, 2017 300tdi parts book doesn't even list the wastegate actuator as a seperate part, RTC6543 is for the older 2.5 TD engine, it fits the same way as the 200tdi defender spec version. might be possible to use one of these instead. this one is for a 300tdi, it might fit/work, the seller maybe able to supply the exact item to match your existing actuator, got to be worth a email or phonecall http://www.ebay.co.uk/itm/Wastegate-Actuator-For-Land-Rover-Defender-Discovery-Range-Rover-2-5-TDI-/112209435420?epid=725185190&hash=item1a20341b1c:g:LYgAAOSwiONYMEvI some info in this thread from 2010 might help a definite diagnosis Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted August 6, 2017 Author Share Posted August 6, 2017 Cheers western that's the one on ebay I'd looked at £32 sounds a lot better than £200 and it looks the same in the photo , just had a quick read of the thread seems to imply that when connected it should be quite stiff which is what I thought from reading other threads about adjusting it for extra boost I can open mine with my thumb with mole grips will drop them an email and see if they can help. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted August 6, 2017 Author Share Posted August 6, 2017 Just emailed them then noticed there address on the bottom , in China so fingers crossed I get a reply I understand. Quote Link to comment Share on other sites More sharing options...
western Posted August 6, 2017 Share Posted August 6, 2017 try turbo technics as well Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 6, 2017 Share Posted August 6, 2017 Noone will supply one. Been here myself. Im running one from a 19j turbo on my 200tdi turbo and it works just fine. The spring preload is slightly different i think but you wont notice the difference as long as it opens and releases the excess pressure. 1 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted August 7, 2017 Author Share Posted August 7, 2017 Cheers reb78 Is it a straight swap ? And did you buy a new one ? If so were did you get it from and last but not least do you have a part number ? Cheers Ian Quote Link to comment Share on other sites More sharing options...
western Posted August 7, 2017 Share Posted August 7, 2017 actuator part number fitted to the 19J TD engines is in my reply above Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted August 7, 2017 Author Share Posted August 7, 2017 sorry just noticed as I scrolled down . cheers Ian 1 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted August 7, 2017 Author Share Posted August 7, 2017 That's even more painful nothing on eBay so googled it over £300 new ouch. Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 7, 2017 Share Posted August 7, 2017 I managed to get a secondhand one on ebay for £15 I think. I emailed everyone that supplied turbos about it, but no-one could (maybe would is a better word) supply a 200tdi part (even though many companies will put new ones onto their reconditioned turbos. There are aftermarket options, but I wasn't sure of the way to match up the spring pre-loads etc, so I went for the 19J version as its quite similar in application. Seems to have worked well. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted August 7, 2017 Author Share Posted August 7, 2017 Have emailed the people in the link that western put in his reply above when they get back to me I'll let you know what they say. cheers Ian Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 7, 2017 Share Posted August 7, 2017 That is insane prices... so I wondered, what is the actual turbo model? A quick search got me to Garret TB02, then another quick search for 'Garret TB02 actuator' gives me loads of hits, and part from around the £60 mark. Perhaps if you start your enquiries with 'I have a Garret TB02 turbo, with a dead actuator, can you help me?' It may well be that the parts are much more generic than most LR places are telling you. e.g. https://www.turborebuild.co.uk/webshop/cat_913296-Mechanical-Actuators.html Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted August 7, 2017 Author Share Posted August 7, 2017 Cheers Bowie69 just emailed them will see what comes back Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted August 7, 2017 Author Share Posted August 7, 2017 Well both have replyed and both can't help, so back to the drawing board. Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 7, 2017 Share Posted August 7, 2017 7 minutes ago, ianmayco68 said: Well both have replyed and both can't help, so back to the drawing board. This is what I found when mine went. I emailed/rang round loads of places. Some just wanted to sell me a new turbo. The frustrating thing is that the damn things must be available as new/recon turbos come with new actuators, but I couldn't find a source!! Quote Link to comment Share on other sites More sharing options...
monkie Posted August 7, 2017 Share Posted August 7, 2017 Never used them, but how about contacting this place? http://www.turbodynamics.co.uk/technical/diagnostics/wastegates-and-actuators/ Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted August 7, 2017 Author Share Posted August 7, 2017 Now what you mean reb78 suppose it's a way of making more money out of you, cheers monkie just sent them an email. Will let you know how I get on. cheers Ian Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted August 8, 2017 Author Share Posted August 8, 2017 Nice one monkie unfortunately they haven't any in stock neither has there supplier but the very kind gent supplied me with the part no for said actuator a quick search through up a few in Europe as they were priced in euros at 69euros , so just in case anyone else has the same problem the garret part number for the actuator for a 200tdi 11L engine is 430819-0095. And he did say that normally they would only supply complete turbos for land rovers. cheers Ian 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 8, 2017 Share Posted August 8, 2017 I reckon that is a good result, yes? Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted August 8, 2017 Author Share Posted August 8, 2017 Very good also helps anyone else in the same predicament as you can now search for the garret part number and it might mean you won't get fobbed off. Quote Link to comment Share on other sites More sharing options...
reb78 Posted April 10, 2018 Share Posted April 10, 2018 Stupidly, I didnt buy one of these actuators when they were in stock. Now everywhere seems to be completely out of stock. Does anyone know where we can find the specs for them? Presume a spring rating and some idea of movement required should enable us to buy one of the more generic ones that roughly fits the bill. My 19J TD actuator seems ok, but i cant help but think i should have something I know for sure is more suited to the turbo in there. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted April 10, 2018 Author Share Posted April 10, 2018 I managed to get a new one from Spain in the end Richard if you put the part number from the earlier post in google it should come up with the company , worked out to about £100 I think . Quote Link to comment Share on other sites More sharing options...
lo-fi Posted April 10, 2018 Share Posted April 10, 2018 There's nothing special about the turbo on a tdi, so have a look for something generic that looks "about right" for physical fit. Anything for a T2 / T25 ought to be promising. You're inside the "normal" pressure range for a small turbo, so spring rating isn't biggest deal - you'll need to adjust it in for desired pressure anyway. However, beware that there are aftermarket actuators that are designed to have a soft spring and the pressure adjusted via a bleed valve, though these will mostly be sold as "tuning" parts. I have a feeling the oem actuator is spot welded to the mounting bracket, but drilling the spot welds out and opening up the holes ought to allow fitting something like this, which looks promising: https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F112205240454 Quote Link to comment Share on other sites More sharing options...
reb78 Posted April 11, 2018 Share Posted April 11, 2018 23 hours ago, ianmayco68 said: I managed to get a new one from Spain in the end Richard if you put the part number from the earlier post in google it should come up with the company , worked out to about £100 I think . Hi Ian. I can’t find it. Any chance of a link? Quote Link to comment Share on other sites More sharing options...
