roamingyak Posted December 17, 2018 Share Posted December 17, 2018 Rebuilding my 200TDI dash and wondering if there is a better solution than the standard heater demister pipe? Asking as they seem too short and wiggle out of place - but assume you need something vaguely heat resistent etc Did later models use something better? (imagine nicked from lrseries.com!) Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 17, 2018 Share Posted December 17, 2018 I seem to remember taping mine on with duck tape. That seems to have held up very well... 1 Quote Link to comment Share on other sites More sharing options...
miketomcat Posted December 17, 2018 Share Posted December 17, 2018 Have you still got the rubber grommet that fits in the top of the lower dash rail. If that's missing they will fall out for a pastime. Mike Quote Link to comment Share on other sites More sharing options...
mat2495 Posted December 17, 2018 Share Posted December 17, 2018 I bought a length of this: https://www.ebay.co.uk/itm/FLEXIBLE-DUCTING-AIR-INTAKE-INDUCTION-HOSE-COLD-AIR-FEED-PIPE-VENTILATION-TUBE/301742462766?ssPageName=STRK%3AMEBIDX%3AIT&var=600569937242&_trksid=p2060353.m2749.l2648 which solved the length issue. I don't think the heater blows hot enough to cause any problems Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 18, 2018 Share Posted December 18, 2018 I did as Anderzander too, bit of electrictians tape around the base of the rubber gromet thing and the hose seems to have worked for the past 10yrs ok. Quote Link to comment Share on other sites More sharing options...
roamingyak Posted December 18, 2018 Author Share Posted December 18, 2018 11 hours ago, miketomcat said: Have you still got the rubber grommet that fits in the top of the lower dash rail. If that's missing they will fall out for a pastime. Mike Yes, but it needs retiring as well... Quote Link to comment Share on other sites More sharing options...
roamingyak Posted December 18, 2018 Author Share Posted December 18, 2018 11 hours ago, mat2495 said: I bought a length of this: https://www.ebay.co.uk/itm/FLEXIBLE-DUCTING-AIR-INTAKE-INDUCTION-HOSE-COLD-AIR-FEED-PIPE-VENTILATION-TUBE/301742462766?ssPageName=STRK%3AMEBIDX%3AIT&var=600569937242&_trksid=p2060353.m2749.l2648 which solved the length issue. I don't think the heater blows hot enough to cause any problems Thank mate, what size (mm) if you remember please? Quote Link to comment Share on other sites More sharing options...
mat2495 Posted December 18, 2018 Share Posted December 18, 2018 I got the 40mm ID, it was a bit tight, but i think 45 would be too big 1 Quote Link to comment Share on other sites More sharing options...
Oakmaster Posted December 21, 2018 Share Posted December 21, 2018 There is some good stuff on here (somewhere) about adapting the ducts to vent onto the side windows too, the main problem (to me) seems to be that the actual volume of air is nowhere near enough to heat and de-mist. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted December 21, 2018 Share Posted December 21, 2018 Retroanaconda has a good guide, I think posted on here originally: http://www.retroanaconda.com/landrover/2011/11/defender-side-window-demisters/ Biggest issue with the volume of air is leaks. Heater box to bulkhead being the main culprit. 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 21, 2018 Share Posted December 21, 2018 Another big leak is the foot well/demist flaps, which need a foam pad on their bottom faces to seal against the inside of the lower fascia when demist is selected, but the foam LR used perishes and crumbles away so most are long gone. 3mm neoprene works well, as would thin camping mat, secured with impact adhesive. It's a simple fit, needing nothing more than the removal of the foot well nozzles (two screws each) and a little cleaning of the surface before applying the glue. Quote Link to comment Share on other sites More sharing options...
