Bigj66 Posted March 18, 2020 Author Share Posted March 18, 2020 I spoke to Dave and his recommendation was to stick with the Disco 1.2 LT230 and the 3.54 diffs as that’s what the 50th Anniversary 90 has. If it turns out to be a bit sluggish on acceleration then there’s always the option of their 1.301 gear kit or even swap to a Defender 1.4 LT230 (which I threw in the skip a few weeks ago) 🙈 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 18, 2020 Share Posted March 18, 2020 I somehow doubt a 4.x V8 in an 88 will be sluggish 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 18, 2020 Share Posted March 18, 2020 Well indeed.... Rocket ship springs to mind. Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted March 18, 2020 Author Share Posted March 18, 2020 I think I have most of the main components sourced now so looking forward to making a start on it when everything settles down. If the auto box doesn’t fit then I have the conversion kit for the series box so either way I can proceed. Quote Link to comment Share on other sites More sharing options...
Landrover17H Posted March 18, 2020 Share Posted March 18, 2020 I can answer quite a few of these Qs: 1) I have a Roverdrive (not Roamerdrive) from 2003. I paid about £700 for it. Very good, getting a tad noisy now but fair do's... I use it. Still far better than any Fairey effort. 2) I run a Heystee PAS off my 2.5 17H PAS pump. Again fitted in 2003ish. 3) ACR's manifold is good. Moves power down by 2-300 rpm. Sadly mine's rotted-out, but again, it's 18 odd years old. I know a bloke about to make these in S/S. Seems to be serious about making at least a small batch. It won't be cheap, nonetheless I'm in the queue. When the time comes... Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted March 18, 2020 Author Share Posted March 18, 2020 1 hour ago, Landrover17H said: I can answer quite a few of these Qs: 1) I have a Roverdrive (not Roamerdrive) from 2003. I paid about £700 for it. Very good, getting a tad noisy now but fair do's... I use it. Still far better than any Fairey effort. 2) I run a Heystee PAS off my 2.5 17H PAS pump. Again fitted in 2003ish. 3) ACR's manifold is good. Moves power down by 2-300 rpm. Sadly mine's rotted-out, but again, it's 18 odd years old. I know a bloke about to make these in S/S. Seems to be serious about making at least a small batch. It won't be cheap, nonetheless I'm in the queue. When the time comes... You’ll notice that my threads have a habit of wandering away from the initial post 🤣 and in this case the thought was to uprate the 2.25 however this has now moved on to the installation of a ZF auto behind a V8 and try to shoehorn it into the SWB. The V8 will have the power I’m after and the PAS pump so no issues there and a P38 steering box will be fitted as part of the project. The diffs will be changed to 3.54s whichever way I go with the gearbox. Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 19, 2020 Share Posted March 19, 2020 21 hours ago, Bigj66 said: You’ll notice that my threads have a habit of wandering away from the initial post 🤣 and in this case the thought was to uprate the 2.25 however this has now moved on to the installation of a ZF auto behind a V8 and try to shoehorn it into the SWB. The V8 will have the power I’m after and the PAS pump so no issues there and a P38 steering box will be fitted as part of the project. The diffs will be changed to 3.54s whichever way I go with the gearbox. I’m pretty sure there is no way to do that without a Stage1/Defender front end and moving a cross member or two - the ZF is very long compared to a long stick LT77 or stumpy R380. Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 19, 2020 Share Posted March 19, 2020 On 3/18/2020 at 1:18 PM, Bigj66 said: I might have a chat with Ashcrofts about the ratios. It might be easier to uprate the LT230 with the 2WD mod and the 1.1 gear ratio and keep my 4.7 diffs rather than change to 3.54 diffs. 3.54 gears are quite a lot stronger than 4.71. I think the half shafts are still going to be the weak link, unless you get updated shafts, but I think you’d be better off with the 3.54 diffs and lower transfer box for the diff resilience. The 4.71s and LT230 would make your low range extremely low, too, probably far lower than ideal. Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted March 19, 2020 Author Share Posted March 19, 2020 53 minutes ago, Snagger said: 3.54 gears are quite a lot stronger than 4.71. I think the half shafts are still going to be the weak link, unless you get updated shafts, but I think you’d be better off with the 3.54 diffs and lower transfer box for the diff resilience. The 4.71s and LT230 would make your low range extremely low, too, probably far lower than ideal. Agreed and I’ve sourced a pair of 3.54 diffs now. The only thing I’m waiting on is to find a decent engine or donor vehicle. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted March 19, 2020 Share Posted March 19, 2020 Gears are stronger. Halfshafts and differentials are not. Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 19, 2020 Share Posted March 19, 2020 25 minutes ago, Red90 said: Gears are stronger. Halfshafts and differentials are not. I think all the 10spline shafts are comparable, so a 3.54 diff will be stronger than a 4.71, but shafts remain weak unless you get specials. Easy for the rear, but not for the front on Series axles. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 20, 2020 Share Posted March 20, 2020 You can go CV and up rated shafts on the front. Expensive, but possible. The big expense is the stub axles from a series 1v8, but I think someone is gearing up to remake these. Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted March 20, 2020 Author Share Posted March 20, 2020 I’ll probably uprate the rear shafts and take my chance with the fronts as 4 WD will only be used very rarely. Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 20, 2020 Share Posted March 20, 2020 So, you’ll be doing the part time 4wd conversion to the LT230? Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted March 20, 2020 Author Share Posted March 20, 2020 7 hours ago, Snagger said: So, you’ll be doing the part time 4wd conversion to the LT230? Yes. IF the autobox can be made to fit otherwise I’m going Old School V8 to series box conversion kit with 3.54 diffs. And I’ve just got myself a decent 4.0 Thor engine today too 👍 1 Quote Link to comment Share on other sites More sharing options...
