ianmayco68 Posted October 10, 2020 Share Posted October 10, 2020 Can someone please put my mind at ease one way or the other, as speaking to a someone has got me worrying . When I rebuilt the engine on the project it’s a 90 300tdi with auto fitted I lined up all the marks on the inside of the timing case and fitted the fuel pump timing pin for setting the timing belt and fitted the belt ( as there’s no place in the fly wheel for the pin ) turned engine over a few times all seems fine , this chaps saying it could be out and I think I’ve done it correct . Please stop me going mad . cheers Ian Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted October 10, 2020 Share Posted October 10, 2020 @darthdickyyou've done this a lot recently. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted October 10, 2020 Author Share Posted October 10, 2020 What timed an automatic or thinks he’s going mad @Ed Poore. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted October 10, 2020 Share Posted October 10, 2020 It was both at the time 🤣 Mo 2 Quote Link to comment Share on other sites More sharing options...
darthdicky Posted October 11, 2020 Share Posted October 11, 2020 Certainly was! To be honest I don’t know how it’s done, I ended up taking it to someone who knows what they’re doing who mentioned using a DTI to do it properly. As far as I could tell there is no marking where the flywheel would be to lock in place, so you can make sure cylinder 1 is at TDC and just rely on the marks in the timing case. If it seems to run fine then it shouldn’t be a problem. Mine ran fine but had very little power, high EGT’s and terrible fuel consumption. Re-calibrating the injection pump and setting the timing properly has made a big difference to mine, but I don’t know how much of that was down to the timing. Richard Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted October 11, 2020 Author Share Posted October 11, 2020 Cheers Richard , it's on my project so hasn't run yet which is the worrying bit , I fitted the pump timing pin and lined up all the arrows in the case I then turned it over a good few times to see if the belt ran true and it seemed fine I only need to get the wiring in and she can be fired up . I would imagine that if something was seriously out the engine would have locked up when I turned it over by hand , looks like it's be brave time . Quote Link to comment Share on other sites More sharing options...
darthdicky Posted October 11, 2020 Share Posted October 11, 2020 If it all spins round fine then it should be okay, but as I’ve found they do seem quite tolerant of running however they are set up. If you do find a way to make sure it’s spot on, please do let me know! 1 Quote Link to comment Share on other sites More sharing options...
Sheffield Posted October 11, 2020 Share Posted October 11, 2020 If I recall correctly the 300TDI on autobox vehicles has a cover plate at the rear of the engine. This is a small plate held by two unequal size boltrs. Remove the plate and fit tool LRT-12-044 into the larger bolt hole to lock the flywheel. This tool is different to the manual gerabox tool 1 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted October 11, 2020 Author Share Posted October 11, 2020 Cheers ,I’ll check tomorrow when back from work . cheers Ian Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted October 12, 2020 Share Posted October 12, 2020 When timing a 300 with EDC you need to 'refine the timing' by removing the pump gear cover, loosening the bolts and turning the timing gear a snadge to the clockwise. All the EDC sensors need to be clean and working and adding an extra earth to the engine is a good idea Quote Link to comment Share on other sites More sharing options...
darthdicky Posted October 12, 2020 Share Posted October 12, 2020 I took the little plate off the back of mine and spent a lot of time trying to work out where the bolt goes in, but came to the conclusion mine doesn’t have whatever hole or Mark is meant to be in there. Looking with a mirror is worth a try as mine is far from standard! Quote Link to comment Share on other sites More sharing options...
Sheffield Posted October 16, 2020 Share Posted October 16, 2020 The plate is held by two bolts, one larger diameter than the other. The pin screws into the hole vacated by the larger bolt. If you use the other hole to fix a bit of spring plate to bear on the head of the pin, it will push the pin into the whole in the flywheel as you slowly turn the engine. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted October 16, 2020 Author Share Posted October 16, 2020 Sorry I haven't got back on this yet but works gone mad again and we're doing plenty overtime in the week , but I'm not in tomorrow and will be looking to see if I can find said hole in mine tomorrow and I'll post up whether it's there or not . Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted October 17, 2020 Author Share Posted October 17, 2020 Findings , think I found the hole on the flywheel , pic from underneath, which means that the timing is 180 degrees out , so using the markings on the timing case is this possible? Before I take it all apart to redo it. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted October 17, 2020 Share Posted October 17, 2020 Turn it over another revolution is it correct then? Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted October 17, 2020 Author Share Posted October 17, 2020 If I turn it so the fuel pump timing is correct then the hole in the flywheel is not correct, so my question is does the crankshaft do 2 revolutions to the pumps one? This is what the bloke told me that said it might be wrong and put the doubt in my mind . The pin went in with a good click. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted October 17, 2020 Share Posted October 17, 2020 2 minutes ago, ianmayco68 said: so my question is does the crankshaft do 2 revolutions to the pumps one? Yes. If you think about it on a 4 stroke engine the pump only injects fuel on every other stroke of the piston as one is the compression stroke (inject fuel) and one is the exhaust stroke. Also the pump pulley is twice the diameter of the crank so you have to have some gearing there. PS I meant another turn off the crank pulley not the pump. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted October 17, 2020 Author Share Posted October 17, 2020 Yes mate I understood that bit , I set it so the pump pin was correct first , couldn’t find said hole in the flywheel so removed the pin the turned her over by hand . The timing pin clicked in when the pump had done half a revolution . Cheers Ed got it straight in my head now so will step it down and redo it , oh my head hurts hahaha. Digressing slightly, did you get your gates sorted ? And there is a hole in the flywheel to set the timing for anyone else having trouble. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted October 17, 2020 Share Posted October 17, 2020 Fundamentally everything is with respect to TDC on No 1 (compression stroke I think) so that's what you need to find. If the pumps etc are not in line at that point then somethings out of whack. Gates - not quite, just ordered some steel for the H frame to form the gate posts. Been chasing my tail on other stuff at the moment. 1 Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted October 17, 2020 Share Posted October 17, 2020 If it helps I've got a spare 300Tdi on the floor in the blacksmith barn (albeit with a snapped crank) but could take some piccies because I know that was timed up correctly. But it is a manual. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted October 17, 2020 Author Share Posted October 17, 2020 Thanks Ed but I think I’ll be fine, haven’t got any coolant in yet so I’ll take it apart and reset the timing with the pump pin in and the one in the flywheel and that should be fine, hopefully . I will hopefully start her up then in a week or two, should finish the dash shortly then off to the trimmers. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted October 17, 2020 Author Share Posted October 17, 2020 So just to clarify for everyone , locked pump , took timing belt off turned crank and bang on top pin locked in , so just need to bolt everything back up , thank #### that’s done ✅ , hopefully I’ll post a pic up of the timing pin @darthdickyfor you in case there’s a next time. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted October 17, 2020 Share Posted October 17, 2020 how many times have you had this belt on and off. If more than once get a new belt Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted October 17, 2020 Author Share Posted October 17, 2020 Only once, and the engines never been run yet . Quote Link to comment Share on other sites More sharing options...
western Posted October 17, 2020 Share Posted October 17, 2020 Good to see you confirmed the timing marks/FIP position. as you've found, once the timing is set, the book of words says rotate engine through 2 full revolutions Then recheck timing marks & pins fit. Quote Link to comment Share on other sites More sharing options...
