FridgeFreezer Posted July 27, 2022 Share Posted July 27, 2022 I used foil-backed closed-cell foam from CAR insulation on eBay and it works very nicely; GlassMAT HR was the type. Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted July 27, 2022 Share Posted July 27, 2022 https://www.carbuilder.com/uk/embossed-aluminium-heat-shield-500mmx500mm?gclid=EAIaIQobChMI5KKh7-SY-QIVQeztCh0i6AIuEAQYAyABEgJ8H_D_BwE Ive used this a fair bit - works well. Fitted as described by Bowie Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 27, 2022 Share Posted July 27, 2022 Yep, used the same on my Audi, @Nonimouse. 1 Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted July 28, 2022 Share Posted July 28, 2022 On a different tack I need to get some heat wrap of some sort to insulate the fuel pipes on the '43 Jeep. It's all standard but every wartime Jeep I've had has has issues with modern fuel vapour using to a greater or lesser extent. The steel pipe runs from the tank under the driver's seat up to a standard big bowl filter on the right side of the bulkhead. From there it runs down to a flexible connection between chassis and engine, over to the engine, around the front of the block to the fuel pump on the left of the block fairly close to the manifold's. From the pump the steel pipe runs up to the Carter carburettor. The whole lot gets hot so in summer fuel vapourisation and vapour locks can be an issue. Obviously I can reroute the pipework but I prefer to keep original vehicles as original as possible. So some kind of unobtrusive insulation wrap would be good. I think some of the French M201's (licence built Jeeps) had an insulation for the engine bay pipes ...but fitting postwar Hotchkiss bits goes against the grain a bit.  Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 28, 2022 Share Posted July 28, 2022 This sort of thing works quite well: https://www.ebay.co.uk/itm/393503839307 No direct experience with that product, just first result, I'm sure there are other British companies selling the same, e.g. Merlin etc. 1 Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted July 31, 2022 Share Posted July 31, 2022 Thanks for the suggestions. I might have another way forward as I have a lot of spare Silent Coat sheets and isolator foam that it seems is ok for engine bay areas. In some ways I'd prefer that as it can be fixed in smaller sections around a complex shape, I wish I'd though about this with the engine and gearbox out as I don't know how I'd get rigid aluminium sheets in there. I do want to check with manufacturer before committing to this, though. If not, I'm curious how others made the neceesary standoff required for the aluminium sheet. I don't want to drill loads of holes to secure it through whatever I would use as the spacers. Â Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 31, 2022 Share Posted July 31, 2022 Unless you have original fixings you will either be drilling and bolting, or welding studs in place, neither sound ideal in your case, and also why most shields are affixed to the component which normally has fasteners you can use. If you do find body fasteners to use, then a nut threaded on before the shield material goes on works well, or rubber tap washers also work great, though less clearance obviously. That car builder solutions material is very flexible, so you would be able to get it in place pretty easily. Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted July 31, 2022 Share Posted July 31, 2022 You're right of course, I'd like to just go with heat shields over the hot bits but there's so much ambient heat from the engine, it makes sense to treat the effected area instead. I have just ordered the exhaust wrap and some heat shield material for things like the clutch slave cylinder, while I have the exhaust off I might as well give the underfloor/bulkhead area some attention. I think the wrap will halve the heat at least as the sweat levels are directly proportionate to engine load. There isn't really anywhere to cleanly bolt through apart from the floor plates so I'll have to go with something self adhesive. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 31, 2022 Share Posted July 31, 2022 1 hour ago, ThreePointFive said: I think the wrap will halve the heat at least as the sweat levels are directly proportionate to engine load. Yep, this feels familiar, while driving the little green thing, also with headers. Quote Link to comment Share on other sites More sharing options...
JeffR Posted July 31, 2022 Share Posted July 31, 2022 (edited) 55 minutes ago, Bowie69 said: Yep, this feels familiar, while driving the little green thing, also with headers. Keep an eye on the prop ujs, my v8 headers (Double S) used to boil the grease out of the ujs when sat in traffic even after they were wrapped. Â Sounded like an angry budgie. Â Lost my temper and binned the buggers Edited July 31, 2022 by JeffR Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 31, 2022 Share Posted July 31, 2022 3 hours ago, JeffR said: Keep an eye on the prop ujs Yeah will do Jeff, amongst everything else that's going on I'm not sure I would hear them But worth a shot at squeezing some fresh grease in there. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 2, 2022 Share Posted August 2, 2022 I know a V8 can kick out heat but this feels like it's straying into serious overkill - the ambulance has the aforementioned 20mm foiled foam under the tunnel and Wright Offroad mats and that's about it, I wouldn't say it's noticeably uncomfortable sitting in traffic in hot weather. Are you doing this because you've found the vehicle does get too hot or because you're worried it might? Interested to hear @JeffR's problems with headers, I'll add it to my list of reasons headers suck Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted August 2, 2022 Share Posted August 2, 2022 The underbonnet temperatures are definitely high and I'm getting the sweats in even normal weather. The tune is part of that but it's also the exhausts, they are pretty famous for getting hot, hence Jeff's discovery. Quote Link to comment Share on other sites More sharing options...
JeffR Posted August 3, 2022 Share Posted August 3, 2022 13 hours ago, ThreePointFive said: The underbonnet temperatures are definitely high and I'm getting the sweats in even normal weather. The tune is part of that but it's also the exhausts, they are pretty famous for getting hot, hence Jeff's discovery. Once I swapped back to cast iron manifolds and range rover/discovery downpipes, I never had that problem again Quote Link to comment Share on other sites More sharing options...
