Lockylockwood Posted January 15 Share Posted January 15 Hi all, I am replacing the lock barrels on my defender 90 and I can’t prize the retaining sleeve from the old lock barrel. I have drilled the clip out (which was stuck) but it has all oxidised together. Any advice? either that, or does anyone know where I can get a new one from? Quote Link to comment Share on other sites More sharing options...
Peaklander Posted January 15 Share Posted January 15 Have you warmed it and used PlusGas with a careful twist too? Quote Link to comment Share on other sites More sharing options...
Junglie Posted January 15 Share Posted January 15 The sleeve is plastic so shouldn't oxidise... But mine just fell apart. Quote Link to comment Share on other sites More sharing options...
Lockylockwood Posted January 15 Author Share Posted January 15 39 minutes ago, Junglie said: The sleeve is plastic so shouldn't oxidise... But mine just fell apart. Mine is metal. The instructions above are for a TD5 which they changed to plastic. Probably for this very reason Quote Link to comment Share on other sites More sharing options...
Lockylockwood Posted January 15 Author Share Posted January 15 50 minutes ago, Peaklander said: Have you warmed it and used PlusGas with a careful twist too? When you say warm it what do you mean? Blow torch? I have some WD40 but no plus gas. Would that work? Quote Link to comment Share on other sites More sharing options...
Mutley Posted January 15 Share Posted January 15 (edited) @ Lockylockwood iirc I think there is a very small pin hole and you need to stick a pin in it and push down a spring loaded pin and pull back on the cover at the same time!?! But I have been known to be WRONG!.....The wife tells me often!!! Oops just seen where you said you have drilled it out!.....Not good as it won't locate on the new barrel I fear!?! Edited January 15 by Mutley Quote Link to comment Share on other sites More sharing options...
Mutley Posted January 15 Share Posted January 15 Right have now got fingers FULL of splinters from scratching my head!?!... I remember changing my locks a few years ago and remember sadly they DON'T sell that part as a separate item!?!......You HAVE to buy the whole F***ing outer door handle!?! As it comes as a unit. Sorry Quote Link to comment Share on other sites More sharing options...
Peaklander Posted January 15 Share Posted January 15 5 hours ago, Lockylockwood said: When you say warm it what do you mean? Blow torch? I have some WD40 but no plus gas. Would that work? Yes just a little bit - it's a very small mass. The WD should just shock it cold again. That ought to work... Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted January 16 Share Posted January 16 when the ball is drilled out you can apply force, it is sticked straight in. The barrel is gone anyway. Quote Link to comment Share on other sites More sharing options...
Lockylockwood Posted January 17 Author Share Posted January 17 Hi all, a little update i soaked it in WD40 for a night and then just used a hammer and chisel. It’s currently looking like this. I’ll give it another soak and try again. I wish I had a vice. Might buy one 🤣 Quote Link to comment Share on other sites More sharing options...
Junglie Posted January 17 Share Posted January 17 My vice is Land Rover ownership, apparently... 1 Quote Link to comment Share on other sites More sharing options...
Troll Hunter Posted January 19 Share Posted January 19 Most of us have at least one 🥳🤡! But never mind your vice, forget about the vise and try soaking in vinegar or some other acid. This should dissolve the rust which has “welded’ to the plastic without damaging the plastic. Just a thought, but I hope it helps. Mike 1 Quote Link to comment Share on other sites More sharing options...
Mutley Posted January 19 Share Posted January 19 Think you will find that part is also metal guys albiet cast metal??? Soak it in Diesel or buy cheap door handle off the Bay and Rob the new part off that!?! Quote Link to comment Share on other sites More sharing options...
Paul C Posted January 20 Share Posted January 20 Pretty sure mine were alloy. White vinegar is what I use to dissolve corrosion now, Dad always used Coca-Cola when he was restoring antiques. Quote Link to comment Share on other sites More sharing options...
Mutley Posted January 20 Share Posted January 20 @Paul C yeah Coke used to do a job but since they changed the formula it's not as effective as it once was, used to be the case if you put a tooth in a glass of coke it would dissolve in 24hrs!?! Another cleaning household trick used to be HP Sauce, smother the metal for a day then clean up like new!?! Good ol' days when we had proper food stuff! 😂 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 20 Share Posted January 20 The stuff in coke was/phosphoric acid, cheap to buy in bulk and great for the garden once you have used it! Quote Link to comment Share on other sites More sharing options...
Snagger Posted January 20 Share Posted January 20 1 hour ago, Mutley said: @Paul C yeah Coke used to do a job but since they changed the formula it's not as effective as it once was, used to be the case if you put a tooth in a glass of coke it would dissolve in 24hrs!?! Another cleaning household trick used to be HP Sauce, smother the metal for a day then clean up like new!?! Good ol' days when we had proper food stuff! 😂 HP, like ketchup, has vinegar - that is what is doing the cleaning. Quote Link to comment Share on other sites More sharing options...
