v8bertha Posted April 10, 2007 Share Posted April 10, 2007 The sliding windows in the back of the camel are doing my nut! They rattle so much. Has anybody on here fixed this on their defender and if so, how? I'm kinda looking for a proper solution rather than just sticking a load of gaffer tape around them! Ta Dan Quote Link to comment Share on other sites More sharing options...
russ3120 Posted April 10, 2007 Share Posted April 10, 2007 try and change the runners and the seals, sounds like they have worn out. how old is the beast? Russ Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 10, 2007 Share Posted April 10, 2007 Open them up put black silicone sealant in the runners and all up the side, squidge them shut and wipe off the excess, then put a bead up between the two sections of glass where they overlap half way along. Job done In a 90 you can also take the windows out and fit the solid (non sliding) ones out of a windowed 90 HT. I am just about to find out whether a set of these will fit in the back of a 110SW so watch this space! Quote Link to comment Share on other sites More sharing options...
v8bertha Posted April 10, 2007 Author Share Posted April 10, 2007 its a 1996 110. I've has a look on one of them LR Parts systems and it gave me the part number of a length of felt that I presume you just stuff in the gap I was hoping for something a bit more solid tho. Russ, you are correct, the runners seem to have turned into a nice green mushy type of mouldy stuff that isn't very good at holding windows in place!! Anyone know if there is an alternative to the LR strip of felt? Quote Link to comment Share on other sites More sharing options...
v8bertha Posted April 10, 2007 Author Share Posted April 10, 2007 Open them up put black silicone sealant in the runners and all up the side, squidge them shut and wipe off the excess, then put a bead up between the two sections of glass where they overlap half way along. Job done In a 90 you can also take the windows out and fit the solid (non sliding) ones out of a windowed 90 HT. I am just about to find out whether a set of these will fit in the back of a 110SW so watch this space! Cheers Bogmonster, a true Landy bodge!! I'll wait to see how you get on before covering myself in black rubber!! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 10, 2007 Share Posted April 10, 2007 Dan, you can buy the plastic window channel from various places, instead of the felt stuff which contains a steel channel which rusts and takes the self-tappers with it Quote Link to comment Share on other sites More sharing options...
jjojjas Posted April 10, 2007 Share Posted April 10, 2007 I got some adhesive velcro tap and stuck it down the leading edge of the sliding glass. You can't really see it when the windows are shut, they don't rattle, and you can still open & shut them as usual. Jas Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted April 10, 2007 Share Posted April 10, 2007 IF the felt is still good; Ease out the felt where it runs in the upright section, stuff a length of packing (ie a strip of felt or cork etc) in the channel, replace felt and with a bit of luck and perhaps some trial and error on the packing it will have tightened up the location of the locking peg. Quote Link to comment Share on other sites More sharing options...
jamesm Posted April 10, 2007 Share Posted April 10, 2007 I jammed a folded up receipt between the two panes of glass about 30,000 miles ago. I've heard no rattling since, so in my book that's a proper repair! Quote Link to comment Share on other sites More sharing options...
rob90 Posted April 10, 2007 Share Posted April 10, 2007 I jammed a folded up receipt between the two panes of glass about 30,000 miles ago. I've heard no rattling since, so in my book that's a proper repair! i jammed a beer mat in there 18 months ago job done Quote Link to comment Share on other sites More sharing options...
BLACK CAB Posted April 10, 2007 Share Posted April 10, 2007 My Cab rear window rattled, had sheep tail docking rubbers wedged between the panes and still rattled. I removed all the rotted felt and replace, a bit fiddley but dose not rattle at all now. Tip:- make sure you use a good rubber based adhesive in the bottom of the channels to prevent the felt from moving. p.s I got the felt from Bearmach. Quote Link to comment Share on other sites More sharing options...
88 Special Posted April 11, 2007 Share Posted April 11, 2007 Replaced the channel in my SIII, with aluminum channel used to make sliding shower doors. It is 1 1/2" wide. Founded the channel at a shop that fabricates aluminum windows and doors. Used some carpet padding felt to line the channel. Pic below may give a idea. Four years and no rattles! Quote Link to comment Share on other sites More sharing options...
Jen Posted April 11, 2007 Share Posted April 11, 2007 Dan's unlikely to get to the computer today, so I'll say 'thanks for all the suggestions!' , especially thanks as it drives me mad!! I've got to replace the runners on my SII windows at some stage, so thanks 88" Special, those piccies will give me something to aim for Anything will be better than the fluffy Camel jamed between the window and the Rollcage Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 11, 2007 Share Posted April 11, 2007 Anything will be better than the fluffy Camel jamed between the window and the Rollcage I like the fluffy camel! Quote Link to comment Share on other sites More sharing options...
Jen Posted April 11, 2007 Share Posted April 11, 2007 I like the fluffy camel! lol! Don't worry, he'll just join the other 2 fluffy camels positioned elsewhere in the vehicle... I'm starting to think we needed a Camel 130 to carry all the Camel related fluffy toys around! Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted April 13, 2007 Share Posted April 13, 2007 I got tired of replacing the bottom window channels on the front doors of my series 2a every year so I slit a piece of 1/4'' x 5/8'' rubber fuel hose about 1/2'' longer than the sliding pane, slipped that onto the bottom of the glass and retained in position with a dob of silastic at each end. Instead of the glass sliding in the channel, it and the length of hose slide together in the door top. It doesn't rattle, the window doesn't vibrate open or shut and the rubber hose never rots. Bill. Quote Link to comment Share on other sites More sharing options...
