Evil J Guano Posted September 23, 2007 Share Posted September 23, 2007 Under the centre seat of my TDi is this curious bit of equipment, am I being tracked by MI5? Looks factory fitted, and looks like something goes down to gbox, I'm guessing some kind of Tachograph? Has various scart and din type connectors... (Looks like my 90 was first registered by 'Industrial Aggregates' or someone so I guess a Tach would fit) Second question can I remove it easily? Cheers G Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 23, 2007 Share Posted September 23, 2007 Late Tdi ECU, I think. Mo Quote Link to comment Share on other sites More sharing options...
Evil J Guano Posted September 23, 2007 Author Share Posted September 23, 2007 Hmmm... best not to snip it out then I guess Quote Link to comment Share on other sites More sharing options...
OilIT Posted September 23, 2007 Share Posted September 23, 2007 Hmmm... best not to snip it out then I guess I've got one as well - on my 98 300tdi. I believe its something to do with EGR - but no - dont cut it out ! Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 23, 2007 Share Posted September 23, 2007 Having enlarged the rather blurry photo the writing on the unit indicates it is a Diesel EGR Electronic Control Unit so that is what it is Quote Link to comment Share on other sites More sharing options...
goddstarr Posted September 23, 2007 Share Posted September 23, 2007 hi i have no middle seat on my 1997 defender so the black box is fiited straight to the pannel that covers gear box it says diesel EGR electronic control unit so its factory fitted i guess Quote Link to comment Share on other sites More sharing options...
white90 Posted September 23, 2007 Share Posted September 23, 2007 just chop all the cables to it and remove the entire EGR rubbish. remember to plug the holes on the pipe from the airbox to the turbo Quote Link to comment Share on other sites More sharing options...
western Posted September 23, 2007 Share Posted September 23, 2007 EGR ecu as ^^^^^ said above disconnect & throw it in the bin & do the same to the valve on the engine. Quote Link to comment Share on other sites More sharing options...
alantd Posted September 23, 2007 Share Posted September 23, 2007 Ignorant question: What is an EGR? Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted September 23, 2007 Share Posted September 23, 2007 Ignorant question: What is an EGR? EGR is exhaust gas recirculation. fitted for emmisions control. fine when it's working. Not so good if it isn't. HTH Pete. Quote Link to comment Share on other sites More sharing options...
western Posted September 23, 2007 Share Posted September 23, 2007 & Not required on UK diesel engined vehicles but is required in other European/overseas countries Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted September 23, 2007 Share Posted September 23, 2007 My ol 300Tdi used to have it. i unplugged it one day to see what would happen..... a big juicy fat nothing... made no difference at all, so if you want to rip it out, go for it! Quote Link to comment Share on other sites More sharing options...
alantd Posted September 24, 2007 Share Posted September 24, 2007 & Not required on UK diesel engined vehicles but is required in other European/overseas countries Thanks guys. Quote Link to comment Share on other sites More sharing options...
goddstarr Posted September 27, 2007 Share Posted September 27, 2007 hi to all you landy mad pepole might sound a bit silly but what is the egr ecu actually fitted for and are there any benefits to removing it as it actually gets in the way and looks awfull thanks to any one with info would be great Quote Link to comment Share on other sites More sharing options...
SteveG Posted September 27, 2007 Share Posted September 27, 2007 hi to all you landy mad pepole might sound a bit silly but what is the egr ecu actually fitted for and are there any benefits to removing it as it actually gets in the way and looks awfull thanks to any one with info would be great ????? I'm no Einstein, but I think you'll find you answer above. Cheers Steve Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted September 28, 2007 Share Posted September 28, 2007 hi to all you landy mad pepole might sound a bit silly but what is the egr ecu actually fitted for and are there any benefits to removing it as it actually gets in the way and looks awfull thanks to any one with info would be great Pick up a copy of this months LRO, there is a full write up on how all the EGR systems work, from Tdi, Td5, the freelander and other LR diesels. quite interesting, and no mention of Vince cobley OR scropion anywhere in the article! (Yes, i meant to spell scorpion like that...) Quote Link to comment Share on other sites More sharing options...
nas90 Posted September 28, 2007 Share Posted September 28, 2007 Under the centre seat of my TDi is this curious bit of equipment, am I being tracked by MI5?Looks factory fitted, and looks like something goes down to gbox, I'm guessing some kind of Tachograph? Has various scart and din type connectors... (Looks like my 90 was first registered by 'Industrial Aggregates' or someone so I guess a Tach would fit) Second question can I remove it easily? Cheers G Blimey! thats clean, are you sure it's a Defender Quote Link to comment Share on other sites More sharing options...
GBMUD Posted September 28, 2007 Share Posted September 28, 2007 Blimey! thats clean, are you sure it's a Defender Clean? It could be the NAS! Chris Quote Link to comment Share on other sites More sharing options...
GBMUD Posted September 28, 2007 Share Posted September 28, 2007 looks awfull OMFG! It is under the seat! Chris Quote Link to comment Share on other sites More sharing options...
