Hybrid_From_Hell Posted October 23, 2007 Posted October 23, 2007 Right, I have a few of those "Roundtoit" jobs, the ones that always seem to be put off as something more importnant comes along I now want to sort out the Eales Rocker covers, they have about 7 coats of paint / enamel etc on them, I seriously doubt Nitromors will do much to them I wnat to get them back to ally, shot blasting will be to coarse, what are the options please ? They are "Bare" so anything can be used, and them clean off properly before doing a "LR Bling Thing*" on them Nige * "LR Bling thing" - A BBC Process on V8 Rockers Quote
Paul Humphreys Posted October 23, 2007 Posted October 23, 2007 Well Ihave been reading about this stuff http://www.bilthamber.co.uk/corrosionremoval.html Its ment to be good for rust and paint. Paul Quote
s2hotdog Posted October 23, 2007 Posted October 23, 2007 Nige Take them to a powder coaters and get them to pickle it off - worth a try will leave the alloy in a self colour - dull finish Steve Quote
Hybrid_From_Hell Posted October 23, 2007 Author Posted October 23, 2007 NigeTake them to a powder coaters and get them to pickle it off - worth a try will leave the alloy in a self colour - dull finish Steve Know anyone local to me / you / area west sussex surrye that does for £s ? Sounds the job !...but what is the "Pickle" what am I asking for them do do / shove it in ? Nige Quote
LandyManLuke Posted October 23, 2007 Posted October 23, 2007 yup, bead or walnut shell blasting will work fine on the ally i reckon. Quote
rtbarton Posted October 23, 2007 Posted October 23, 2007 Blasting may not shift powder coating, I've had to give up on several powder coated items. There are chemicals that will do it, but most seem to be in the USA. One of my customers soaks stuff in a chemical, but he's very cagey about what it is, and don't forget caustic chemicals eat ally! The way I treat ally engine parts is to blast them with very worn abrasive and then blast with glass beads, this gives a nice satin finish that isn't too bling. Then they could be polished I suppose. The guy I buy my media from suggested using Aluminium oxide and then glass beads. Quote
rtbarton Posted October 23, 2007 Posted October 23, 2007 .......walnut shell blasting will work fine on the ally i reckon. Yes but you need a blooding big nozzle Quote
Les Henson Posted October 23, 2007 Posted October 23, 2007 I did shot blasting a good few years ago now - from chilled iron particles to copper slag. Pearl beads were used for the likes of copper, brass, stainless, magnesium, and alloy. It barely marks the metal. I bead blasted the side casings on my suzuki and then polished them with Solvol Autosol and it didn't take very long. Some plastic-type coatings would smear and turn black before eventually coming off - if the coating did this we would use something more abrasive, such as oxide to remove it and then pearl beads to get the surface back. Les. Quote
white90 Posted October 23, 2007 Posted October 23, 2007 http://www.kramerindustriesonline.com/blas...lnut-shells.htm Quote
rtbarton Posted October 23, 2007 Posted October 23, 2007 Loads of stuff listed here with prices in dollars and euros Blast Media Quote
s2hotdog Posted October 23, 2007 Posted October 23, 2007 Know anyone local to me / you / area west sussex surrye that does for £s ? Sounds the job !...but what is the "Pickle" what am I asking for them do do / shove it in ? Nige Nige I have a couple of local companies near work (LA - Littlehampton!) Hourcover and Eurofinish - we use them for a lot of powder coating but I expect there are similar in Guildford/Portsmouth, if you just want to strip I expect a few quid as the setup times for PPC costs I had some VW golf ally wheels done some time ago - they dip them in an boiling acid I believe - stripped all of the lacquer but as noted left them very dull. Shot blasting is an option but is more specialist - we have a shot blasting set up at work but is designed for steelwork rather than alloy - it would be too harsh fo alloy, but Penfolds at Barnham or if they are still going Blastreat at Arundle. Hope this helps Steve Quote
nas90 Posted October 23, 2007 Posted October 23, 2007 NigeI have a couple of local companies near work (LA - Littlehampton!) Hourcover and Eurofinish - we use them for a lot of powder coating but I expect there are similar in Guildford/Portsmouth, if you just want to strip I expect a few quid as the setup times for PPC costs I had some VW golf ally wheels done some time ago - they dip them in an boiling acid I believe - stripped all of the lacquer but as noted left them very dull. Shot blasting is an option but is more specialist - we have a shot blasting set up at work but is designed for steelwork rather than alloy - it would be too harsh fo alloy, but Penfolds at Barnham or if they are still going Blastreat at Arundle. Hope this helps Steve Blastreat still in Arundel and very busy, well they were in July when I delivered some parts for coating. Crushed walnut shells are used by Parker Pen to get their burnished finish on stainless pen caps, used in a rumbler overnight apparently! Concord Lighting in Newhaven have a furnace process to remove powder coated surfaces from steel parts. However, it runs at about 700 deg C so not much left of your aluminium casting Quote
ripley Posted October 23, 2007 Posted October 23, 2007 Know anyone local to me / you / area west sussex surrye that does for £s ? Nige give Pete Collis a ring at Ambassador Coachworks, tell him i gave u his number 01484 747752, ask him for his mates number (long winded i know ) that does all the metal polishing & finishing, his mate is local to you but i dont have the number, he has all the dipping machines etc & if u want them polished geez he gets stuff like chrome cheers Graham Ps back doing paint!! Quote
FridgeFreezer Posted October 24, 2007 Posted October 24, 2007 Another one is K & N Finishers in Portchester (Portsmouth), I've used them to blast some stuff before - minimum order is £20 though, can I throw the rocker covers I got at sodbury in with yours Nige? Quote
bill van snorkle Posted October 24, 2007 Posted October 24, 2007 I work for a specialist engine reconditioner. sand blasting is too risky in a workshop around delicate components, so we use Bi Carbonate of Soda of all things for blasting alloy timing covers, rocker covers sumps etc. I don't know how well it works on multiple paint layers but it removes hard baked on paper or cork gaskets pretty good. bill. Quote
