MogLite Posted November 7, 2005 Share Posted November 7, 2005 The CB for MogLite turned up on Friday Its got a PA function !! That got me thinking about how much fun a PA horn would be. I'm assuming the CB will have an output of about 4w - the same as its transmit power ?? Anyway there is a 1/2 decent PA horn in Maplins for £20 which 30W. So is there a simple power amp I can use that will up the output to match the power of the horn ? Cheap is good, as is being able to be encased in a plastic box or potting compound, the ability to run a second horn for the rear might be useful. Quote Link to comment Share on other sites More sharing options...
white90 Posted November 7, 2005 Share Posted November 7, 2005 I have much fun with my PA on th CB I have no power amp just the speaker from Thunderpole plugged straight in plenty loud enough to issue instructions/insults etc as req Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 7, 2005 Share Posted November 7, 2005 Andy, The audio output power will be whatever it puts out through the internal speaker - the transmit power is the RF bit not audio. You shouldn't need an amplifier. Let me put that another way: You shouldn't need an amplifier. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 7, 2005 Share Posted November 7, 2005 Kin Hell "Andy"... "Needed" and "Amplifier" are not words oftyen seen in the same sentence. Can you get radio mikes with built in 'Anti-Anglosaxon' filters ? Nige Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 7, 2005 Share Posted November 7, 2005 For Andy that would just be a continuous "beeeeeeeeeep" Quote Link to comment Share on other sites More sharing options...
western Posted November 7, 2005 Share Posted November 7, 2005 I've got one of those 30 watt PA horns on my truck, it's weather proof and seems to work very well, more than loud/clear enough to be heard at large events, just run it from the CB rig, you'll need a 3.5mm jack plug & some speaker cable to connect it to the rig. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted November 8, 2005 Share Posted November 8, 2005 Andy and an amplifier!!!! My ears are still bleeding from Slindon!!!! and that was in July!!!!!! Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 8, 2005 Share Posted November 8, 2005 Can you get radio mikes with built in 'Anti-Anglosaxon' filters ?Nige You could connect the PTT switch on the mike, to the horn circuit? For some reason I am thinking of the 2004 Slindon video at this point Quote Link to comment Share on other sites More sharing options...
will_warne Posted November 8, 2005 Share Posted November 8, 2005 You could connect the PTT switch on the mike, to the horn circuit? For some reason I am thinking of the 2004 Slindon video at this point I think we all are Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 8, 2005 Share Posted November 8, 2005 Blotted out the memory of the 2005 one then Will? Quote Link to comment Share on other sites More sharing options...
