CrewCab Posted November 5, 2007 Share Posted November 5, 2007 Small son's white 110 has eaten yet another diff ................ this will be number 4 within the last 18 months ............ OK I know it's a "high maintenance" hobby ......... but is this "fubar'd" or is it repairable ............. my gut instincts tell me we should just be looking for another yet diff ............... it's a 24 spline in a 300Tdi Defender Thanks for any input guys. Oh ................ anyone got a 24 spline diff surplus to requirements ................ or even two, methinks we need to keep a spare in stock CC Quote Link to comment Share on other sites More sharing options...
western Posted November 5, 2007 Share Posted November 5, 2007 Yep, I'd say he's fubarred that totally I've just replaced my front 10 spline for another one from Crown Diffs bought a modified 2 pin. Quote Link to comment Share on other sites More sharing options...
Litch Posted November 5, 2007 Share Posted November 5, 2007 My first question would be what is he doing to it to break so many so often? I am sure many of us have broken a diff or two in out lifetimes but four in eighteen months, sounds like something fishy is happening to me. Also I take it this is the front diff we are talking about as it should have a Salisbury on the rear and that looks like a normal Rover diff? He isn't running vastly oversized tyres or dropping the clutch on tarmac to pull wheelspins is he? How are the CV joints and prop UJ's standing up? Quote Link to comment Share on other sites More sharing options...
CrewCab Posted November 5, 2007 Author Share Posted November 5, 2007 Litch ............. it's a bit of a long story ........ Perhaps I exaggerate slightly ................ The 110 in question was bought by my son about 18 months or so ago on a limited budget, it was "cheap" by Defender standards but for obvious reasons, a quarter of a million miles and quite obviously a hard life, but ........... it was also a good leaning curve for him to be fair. We realised most mechanical parts would need to be replaced and thought over a year or two that would be fine, unfortunately the "White Witch" had other idea's and within 6 months we replaced the front diff followed by the engine, gearbox and transfer box, then the front axle and shortly after the rear axle ....... interspersed with the front prop, lots of bushes, steering box, radius arms, several wheel bearings and the obvious things like pads and a disc or two ................. all in all it would have probably been cheaper and certainly much easier to buy a lower mileage defender ........ but he's learnt a lot about mending land rovers so I do consider it worth while :lol: As for the Salisbury axle ............. another long story ........... as his 110 does a lot of offroading and the Salisbury is like a plough we opted for a Wolf TD5 replacement, what turned up was a 90 rear axle, which we eventually fitted using a spacer for the rear prop and for 12 months it's been fine. He's learnt a lot about driving off road over the past year and to be fair I think he was somewhat unlucky last weekend at Tong, he followed me up a small, but steep hill with a bit of a steep / rocky exit, he stalled just before getting over the top and then rolled back a few feet .............. followed by an "expensive" bang ........... the diff obviously Anyway, this is purely for information and also so you can have a laugh at our leaning curve ................ and as always we're here to learn so please keep it coming Dave Quote Link to comment Share on other sites More sharing options...
western Posted November 5, 2007 Share Posted November 5, 2007 that's one heck of a learning curve Quote Link to comment Share on other sites More sharing options...
muddy Posted November 5, 2007 Share Posted November 5, 2007 I would look at fitting 4 pin diffs as these should cure your breakages (well the difs at least ) but i would put the sailsbiry back on, not sure how a 90 axle likes life under a 110. Quote Link to comment Share on other sites More sharing options...
DaveB Posted November 6, 2007 Share Posted November 6, 2007 Didn't they fit Rover axles to the later 110 Td5s? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 6, 2007 Share Posted November 6, 2007 Didn't they fit Rover axles to the later 110 Td5s? Yes, they don't have a good rep from what I've seen. You can shave the bottom off a salisbury to give the same or better clearance than a Rover. For a back axle IMHO they're a no-brainer. Quote Link to comment Share on other sites More sharing options...
Litch Posted November 6, 2007 Share Posted November 6, 2007 I don't think the replacement rear axle on later vehicles is a normal Rover type however much it may look like it from the outside. I believe I am correct in saying the casing & internals are all uprated and it is at least as strong as the Salisbury it replaced. Forget the ground clearence issues and get a Salisbury back on it straight away, they aren't weight rated for the 110 (your insurance company would have something to say if they found out) and as you have found out, the Rover axle is nothing like as strong. I suffered with broken rear diffs & halfshafts (usually off-road) when I was running my SWB S111 V8 c/w 9.00x16's but after fitting a Salisbury (never standard on the SWB) I had years of trouble free motoring. They have been well proven over the years and while it is quite possible to break one, it is a lot less likely to happen than with a Rover axle. Yes they sit a little lower but I can't believe it is worth all the agro for 1-inch less clearance. Quote Link to comment Share on other sites More sharing options...
CrewCab Posted November 7, 2007 Author Share Posted November 7, 2007 Forget the ground clearence issues and get a Salisbury back on it straight away, I'd prefer to go down the route of fitting a TD5 110 Wolf axle, just got to find one first. Cheers for the help and info. Dave Quote Link to comment Share on other sites More sharing options...
SteveG Posted November 7, 2007 Share Posted November 7, 2007 Yes, they don't have a good rep from what I've seen. Interesting as I haven't heard about this. Got any more info FF? Thanks Steve Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 7, 2007 Share Posted November 7, 2007 What's a TD5 110 wolf axle ? As far as I know Wolf is the name given to the current military Land Rover but they didn't have TD5 engines so is this some kind of new axle ? What's uprated on it ? Mo Quote Link to comment Share on other sites More sharing options...
western Posted November 7, 2007 Share Posted November 7, 2007 IIRC the current Td5 & XD/Wolf rear axle is a version of the 2nd gereration RR aka P38. not sur if it's made in house or bought in ready to fit. all the in service Wolf's have this axle not a Salisbury on the rear. Quote Link to comment Share on other sites More sharing options...
CrewCab Posted November 7, 2007 Author Share Posted November 7, 2007 IIRC the current Td5 & XD/Wolf rear axle is a version of the 2nd gereration RR aka P38. AFAIK It's made by Dana, if I'm not mistaken it's a 4 pin diff and is equally as strong as a Salisbury, but a little smaller, ARB do a locker for it as well. Dave Quote Link to comment Share on other sites More sharing options...
robhybrid Posted November 8, 2007 Share Posted November 8, 2007 My opinion. keep the 300 tdi axle and replace the diff with an ARB diff. As for the load rating issue where is the proof? There is a 10mm? difference in the spring mounting point centers between 90 and 110 axles this is to compensate for the larger diameter springs that are fitted to 110 vehicles. The 300 tdi half shafts are the same diamiter as salisbury shafts, the hubs are the same with the same bearings I believe. The arb is 4 pin so will withstand far more abuse than a standard 90 one. plus you get to have the chance of locking the rear axle with the addition of a compressor. If you need to strengthen the dif even more then look into getting the diff "pegged" Quote Link to comment Share on other sites More sharing options...
