TD5 has been under water, what to expect?
stobbie
Hi,
I can buy a 1999 LR90 TD5, it has been under water. Only to the level of the seatbases. They have removed the ECU and opened it and it is broken. They say they have tried the car with a replacement ECU and it was running fine.
What sort of problems cab I expect if I'll buy this car, will it just be this ECU (ofcourse I can't read the injectorcodes from the old ECU because it's broken) or will there be a lot of other problems like gearbox, clutch, other electrics?
it's not a private sale, I own a land rover business and I am buying from a damaged car sales company.
Will it run on a random ECU to test if the motor is ok, without any programming? i.e. can I just take an ecu out of a discovery and try it?
Guest diesel_jim
Porny will be your man on this one! but i don't think a disco ECU will run with a defender, and either way, it certainly won't run just by plugging it in, you'll need to change the alarm codes to suit the defender.
I think, from what he's said (Ian = Porny) that the engine will run with the wrong injector codes, just not very well. the codes are on the top oif each injector, its a 5 digit letter code,
As Jamie has stated.... not just a case of plugging a replacement ECU in....
Although not ideal, any Td5 ECU (disco or defender spec) will run any Td5 engine - however the ECU needs to be coded to the Defender's 10AS alarm unit. (unless you have one of my 'special' ECU's that have all the alarm/immo set-up removed!!! ;) )
In the actual car, running a Disco spec ECU on a Defender (for example) will cause numerous faults - and cause the temp gauge to work the wrong way round.
The engine will run with the wrong injector codes, but as mentioned not the best - but OK for a trial.
The other interesting factor.... does the Defender come with Keys and Alarm fob (depending on which state the 10AS unit is set to)??
If the key and fobs are missing (and the car is set to see them) not just a case of hotwiring the ignition.
(not hard to get around though - have done this a few times lol)
Any where near the Midlands(ish) and I could lend a hand if needed.
The other helpful thing would be to plug diagnostic kit in when (and if) the engine is running and have a look at the cylinder compensation and a couple of other things.
Also....
Just re-read your post:
They either have diagnostic kit, a spare ECU and a matching 10AS unit - or are lying lol ;)
Ian
Thanks, but I live in the Netherlands :-)
Ian
That's the first thing I thought, but I don't know too much about these electronics, so I wasn't sure.
I know a TD5 specialist here in Holland, unfortunately he's far away from me. Maybe I can ask him to program a NNN*** ECU without the alarm to test the engine, or better, maybe he could come to me to view the car...
It is rather cheap though, and it's a very very nice CSW, and I do have a spare engine laying around here...(as a spare for my own disco)..
You can't program any Td5 ECU without the Alarm or Immobilser.... :( You need an extra little bit of kit to do that.
The ECU basically looks to either the 10AS alarm ECU or the Disco BCU for a code... if the code it sends back is the same as the one stored in the ECU the car will be allowed to start. If its not, the engine will run for two seconds (if that) and cut out. You can not - using 'any' diagnostic kit - stop the ECU doing this.... I can though ;)
One way around that is to take along a matched Engine ECU and a 10AS unit, then just swap the ones on the car for your matched pair.
You could get your mate to set the 10AS alarm ECU into it's most basic state - that way, if the Defender doesn't have keys you can just hotwire it.
Isn't far on a plane lol.... have travelled to Greece for someone in the past....
Ian
gearbox and T box and axles if poor seals or no breathers.
How long was it in water? silty or not?
if it wa sonly in the seatbox then i doubt that it got inside the engine as the air intake is a bit higher.
im in the salvage and busines smyself and on water damaged cars on oil change is obligatory.
i regularly sink my td5 with water all teh way up2 the dash and its srunning fine. the breathers r extended i got a snorkel and moved the ecu, but all the rest in teh car is ok with water really...
even my velocity 140 sub mounted in teh erear footwell...
JJ
But when the water gets to your already raised ecu, you get problems don't you jj. But WD40 does work wonders just like on a V8.
Back on topic. Is this salvage vehicle, from flood damage. Was it flooded so parked up when the water damage occured, as in not running, as there is likely to be less damage to the engine.
Jon
Jon
yes but thats another story...
i shall further waterproof that little box a trix 4 the rematch with the puddle hahaha
JJ
Then why on earth are you asking us? :rolleyes:
Because I'm used to buying and selling early one-ten's (see my website in Holland One-Ten Land Rovers) and these don't have fancy Ecu's and stuff, I'm also not used to buying damaged cars (other than rust damage :huh: )
I don't know what has happened to this car and how long and it what kind of water this has been, I hope to have enough time today to go view it again and ask them some more questions about it!
I wasn't expecting the tune! sitting at work and thought I would go to the link and lo and behold some classy dutch music fired across the office! :D
Well I have bought the car for a good price (I hope). Didn't have time to collect it yet, I'm travelling between Holland and the UK this week. Today London, Tomorrow and Thursday around Liverpool.
I've taken the ECU already and sent it to my td5 expert, he is going to try to repair the old one....
I'll keep you informed on the progress.
Is there anything worse then websites that play music? :rolleyes:
Chris
I agree most of the times, still I wanted music on this one. But it can be turned off!
Yes, Traders who make a profit plundering the knowledge of those who give it to a community for free (mention no names sting in the tail). However, as he is Dutch and therefore a cool person, I'm inclined to forgive :D
:) I'm only a very small trader, since only one year. Started as a hobby, so didn't start it for the money or something (ofcourse nowadays have to make some money on it, it takes 100 hours a week and I have to eat.. ;) ) My Land Rover hobby started just 4 years ago, so I'm learning every day. A lot on dutch forums, but I also read this one almost every day. Didn't post too much myself yet. But one day I'm an expert too, and may be able to post some usefull info.
  • 2 weeks later...
I have the TD5 here now! I also have a brand new NNN ECU here. I'm just waiting for my Nanocom (Paddockspares is closed until januari :( )
I just plugged in my new ECU to see what happened, I didn't expect the car to start without programming the ECU.
When I turn on the ignition I only here a lot of clicking noises from the ECU (or the relais near the ecu) and the check engine and hazard lights warning lights keep flashing. Is this normal behaviour when plugging in a non programmed ECU?
