Steel prices
ciderman
I had a letter from my steel stockholder this week telling me that steel prices are going up and predicts that by April they will be £100 per ton more than the Dec 2007 prices .
So best buy know .
I help a mate fabricate farm buildings and we worked out this price increase based on 7" by 4" RSJ steelwork.
The price increase worked out at 12.8%
When you consider that steel prices have increased by 20% over the last 2 years before this new increase it is extortionate!
Guest mortus
the price of scrap has gone through the roof at the moment,
ive taken over 700 quids worth this month
been clearing out all the farm sheds :D
I sorted-out my scrap alloy and weighed it in two weeks ago - all clean cast alloy. I got £120 for it, which was very nice :)
Finished my new work bench last Sunday (cue inventing shed porn piccy). I decided to cover it with 5mm steel and phoned for a price for an 8x4 sheet of it - £151.20p - bluddy Nora!
On the plus side, I have 5 - engines to weigh in - all that pig iron must be worth a few quid :)
Les.
And there saying it's very unlikely to be going down.
good if you've got scrap to sell
not so good if you've got steel to buy
i'm lucky i've got scrap needing to go just don't like having to put white deisel in to my tractor.
I'm trying to buy scrap lead at the moment (to cast bullets with) , and the retail price is incredibly high. Does anybody know where I might get some wholesale from? Before anybody suggests it, I don't like heights so church roofs aren't really an option. I wonder how much the post office charge for delivering large lumps of lead????
Les.
A nice clean tidy bench Les. For how long I wonder will it be tidy....... :o;)
Troddenmasses
I used to tour the tyre companies on a Saturday morning. See if I could have some old wheel weights. Super for making model boat keel weights. Now I understand like fishermen lean is a no no.
mike
Try was Lord Mayor of London. Can't died in the workhouse.
Guest mortus
Uhmm.... explain why you have to put white in your tractor?
your moving agricultural waste, you not doing anything wrong by running on red...
especially just running to the scrap yard.
Les.
Nice bench Les, but wouldn't the vice be better at one end, then it won't get in the way so much.
Not 100% Sure but is there a mileage distance limit you can travel using Red deisel ?
I've tried the same - I got some old wheel weights from the local quick fit and they looked like lead so I put them into my cast iron pan and heated them up with a propane burner. Unfortunately, they wouldn't melt - they just glowed. It seems that wheel weights are now mostly zinc. Unfortunately, Zinc melts at 420 degrees C so isn't much use to me.
there is indeed a maximum mileage for red diesel which also applies to livestock and all cropped produce
plus, carting scrap is as far as im aware, NOT an agreed agricultural practice. it comes under waste management and disposal. just like a farmer requires a special dispensation from the EA for burning ANY waste, organic or otherwise, which still does not cover for everything we once burnt. We also have our scrap 'collected' when it amounts sufficiently (in old 500gal tanks with the top cut off)
there are very fine yet ever more defined lines to what is and what is not an accepted agricultural practice, contractors have it even worse, but farmers still struggle to keep right side of the fence on logistical issues
but back on topic, this doesnt bode well for me when i need some steel to bend up a new HD rear bumper
Carting scrap IS an agreed agricutltural practise, so long as that scrap was created by an agricultural practise (if you take a car etc. on top of a trailer load scrap you will probably get stopped). Agricultural scrap is actually classed as an agricultural product so wont be treated any differently to a trailer load of wheat, grass or stock.
If you sit down and read all the publications on red diesel exemption it actually is fairly simple. It usually idle chat and banter that add alot of the confusion to the whole thing!!!!!
discojmz can you fing anything written in stone about the whole limited milage abd red diesel??? we can only find limited operators licencing coming in on a milage from base type scenario.
(we run a fleet of fastraxs on red diesel and have been stopped but never fined or impounded)
James
i'll do my best to dig it out but you might have to bear with me. i wont be able to find it til next time im home from uni. something about any product not being able to be delivered over 15miles from base, and a limit on working distances applicable to agricultural and forestry practices (but i think that may have been with regards the fitment or not of digital tachometers and/or licencing)
of course the next thing will be we wont be able to stockpile our scrap, just like we already arent supposed to have a pile of rubble in the yard.
anyway, thats getting more and more off topic
Try Phelps Bros scrapyard in Gloucester, they will sell scrap back out- at a profit!
How much lead do you need?I may be able to help.
Try asking your local Water utility contractor , or just one of the gangs . They are always carrying out lead pipe replacement for Polypipe .
The gangs / crews tend to just weigh it in .
We run our Unimog and tractor on red, neither are anything to do with agriculture but both are forestry related, hence the crossover, agriculture, silviculture and horticulture.
I have read lots of bits and peices about red diesel and some of it is mind boggling, but from what I can find from 30 years of looking is, there is no milage limit for red providing the work you are doing is connected with your profession. However, if a farmer moves a load of corn for his neighbour he is then a contractor and is governed by a different set of rules and will need to use white, possibly even a tacho depending on the milage. We are tacho exempt within 30 miles of base, over that we need one (if we are on the road).
One little gem that applies to everyone with no exceptions is, anyone taking scrap to a scrap yard or any where else will need to have a waste transfer licence (unless your a pikey then your exempt). I think its around £150 for your first which last's three years then its £90 each renewal.
If I take a tree down in your back garden I can sell the woodchip for mulch and the timber for firewood and that is re-cycling no problem - if I do the same on a building site it is waste, no matter what the final outcome :blink: .
I thought thats what I said :P .
Sounds like they increased the milage. I keep a copy of the relevant legislation in the unimog so the lads can show plod/vosa when the are stopped, its such a grey area.
Seems everyone knows a bit but very few know it all.
Correct, IIRC its £142, I have to have one to move end of life vehicles,, 202 feet from my property to the scrapman's property !!!
How can i apply to be a Pikey :huh:
Here you go mate , Print this off and stick it in the cab .
http://www.vosa.gov.uk/SCRIPTS/texis.exe/w...id%3D47d37d5f18
