Snagger Posted October 20, 2008 Share Posted October 20, 2008 Ok, so we all know the SIII, and most incarnations of SII, have a rubber o-ring in the groove of the ball at the bottom end to stop the stgeel ball rattling against the walls of the steel "cups" on the end of each selector rod. The problem is that these o-rings, being plain neoprene rubber, tend to wear out quickly, and the use of grease or oil to reduce the abrasion of selecting gears causes the rubber to perish. I have been trying to find alternatives. Polyurethane seems to be out because they don't make o-rings of that size as a standard - they'd need to be custom made, which would make them very expensive. PTFE has been suggested to me by a seal retailer, and they're getting back to me with a price for a minimum size order. Now, PTFE would have great longevity, but will it be to hard to prevent the stick from rattling? Apparently, it has some give in o-ring applications, but is much harder than rubber. Has anyone tried this successfully, or would anyone be interested in trying it if I have to make a small bulk order? Quote Link to comment Share on other sites More sharing options...
jericho Posted October 20, 2008 Share Posted October 20, 2008 Standard Viton o rings are oil and grease resistant,and available in just about any size.I think its abrasion that will wear anything compliant on the end of the series gear stick. Quote Link to comment Share on other sites More sharing options...
mudmuncher Posted October 21, 2008 Share Posted October 21, 2008 My gear stick rattles to i never knew you realise it had a o ring fitted !! Does anyone know where you can buy these from !!!! Cheers chris Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted October 21, 2008 Share Posted October 21, 2008 Does anyone know where you can buy these from !!!!Cheers chris You don't say which Series model you have. I see two part numbers quoted, on a Series 2 CD, 540354 for 'early' type gear change lever. FRC1387 for 'later' type gear change lever. Needless to say, the levers are NOT marked early and late, but rather 4 cylinder or 6 cylinder, sub-sectioned into Right and Left hand drive. Series 3 is just shown as FRC1387. I don't know if my S2 box is early or late, in this context, but I see I made one up, 15mm ID, 2.5mm Cross Section. I'll let you Google the part numbers. :-)) Quote Link to comment Share on other sites More sharing options...
Simon Smith Posted October 21, 2008 Share Posted October 21, 2008 The stick used to rattle on my S3. I was told by a farmer to slip a length of milking machine hose on the length of the stick. It worked a treat, presumably the extra weight changed it's resonant frequency. Quote Link to comment Share on other sites More sharing options...
Swifty oh no Posted October 21, 2008 Share Posted October 21, 2008 The stick used to rattle on my S3. I was told by a farmer to slip a length of milking machine hose on the length of the stick.It worked a treat, presumably the extra weight changed it's resonant frequency. You slipped your Landrover a length ? Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 21, 2008 Author Share Posted October 21, 2008 Well, the seal suppliers that I tried all said that the size needed wasn't available in polyurethane (the preferred option, and a possible opportunity for Polybush and the likes, I think), and PTFE o-rings would cost me £60+VAT for a minimum order of 100. I'll be sticking with standard rubber o-rings, then. The size needed for a SIII is either 14x2.5mm or 16x2.5mm The 14mm (inside diameter) is a snug fit in the groove, while the 16mm is just loose enough to rotate freely whilst being totally secure. When I bought LR replacements in the past, they were 14mm, but this time I have gone for the slightly larger size from my o-ring kit (a few pounds from Halfords). With a small application of graphite grease, it should last reasonably well - I think it was the abrasion that killed all the others over the years. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted March 10, 2019 Share Posted March 10, 2019 Did you ever sort this out Nick? Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted March 10, 2019 Share Posted March 10, 2019 My 2a stick rattled incessantly despite new oring (didn’t last long) I ended up buying a pattern s3 gearstick for little over £10 as it was fitted with nylon bush on ball instead of oring. I bent the stick to s2a shape and cut the thread in the top to fit 2a knob - works perfectly with absolutely no rattle. Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 9, 2019 Author Share Posted April 9, 2019 On 3/10/2019 at 5:22 PM, Anderzander said: Did you ever sort this out Nick? I stumbled across a gear stick with a large green plastic band, possibly the same as oneandtwo did. It worked much better until the band finally failed, but I think it's reparable. It doesn't rotate, so PU adhesive is going to be the fix. I still think that PU o-rings for the more common type sticks would work well, though. Quote Link to comment Share on other sites More sharing options...
