landyliam Posted August 6, 2005 Share Posted August 6, 2005 should i put parabolics on my series 3 or save a couple of hundred pounds and stick with standard springs well someone had to ask it! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 6, 2005 Share Posted August 6, 2005 I've got to fit a set of parabolics on an 88" S3 next week. I also had them on catflap (109) big difference and worth it in my opinion. Les Quote Link to comment Share on other sites More sharing options...
ironman Posted August 7, 2005 Share Posted August 7, 2005 Les After you have kitted the 88" out you can compare paras to Ltwt springs. Several folk have said that I may as well stick with std as Ltwt ones are virtually as good as paras. Not having experienced paras I would not know. Chris Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 7, 2005 Share Posted August 7, 2005 No problem, I'll post as soon as it's done Les. Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted August 7, 2005 Share Posted August 7, 2005 LesAfter you have kitted the 88" out you can compare paras to Ltwt springs. Several folk have said that I may as well stick with std as Ltwt ones are virtually as good as paras. Not having experienced paras I would not know. Chris parabolics but not the cheap balck ones from paddocks the green ones are the best try procomp for kits Quote Link to comment Share on other sites More sharing options...
Mark Posted August 7, 2005 Share Posted August 7, 2005 I have green ones on the lightweight, and blue ones on the IIa. Both are very much worth the money, although the blue ones do seem a bit more flexible. (Blue = TIC and Green = Rocky Mountain) Cheers Mark Quote Link to comment Share on other sites More sharing options...
landyliam Posted August 8, 2005 Author Share Posted August 8, 2005 so just to add to the dilema i see i now have to decide on what type of parabolics to fit, sod that, i think i'll stick with the standard springs and buy my wife new curtains with the money i'll save (as if ) Quote Link to comment Share on other sites More sharing options...
02GF74 Posted August 17, 2005 Share Posted August 17, 2005 I have green ones on the lightweight, and blue ones on the IIa. Both are very much worth the money, although the blue ones do seem a bit more flexible.(Blue = TIC and Green = Rocky Mountain) Cheers Mark ... so anyome make pink ones? depending on what you read, don't British springs make the TIC ones? And they also supply Paddocks; not sure if they'll be the same as the very cheap Paddocks ones ... and again depending on what you hear, Paddocks are good or bad. Rememebr you need to fit longer shocks, again procom es3000 (?) are good but better are es9000, slightly more expensive but harder to find, again opinions vary here, some suggerst (like CPercect?) using es1000. and opinions from otheres is that properly maintained leafs that are not rusted to bu88ery like most are after 30 years, are pretty good too..... Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 17, 2005 Share Posted August 17, 2005 <blatant plug mode> www.gon2far.co.uk Sell springs, procomp shocks, shackles, bushes... </blatant plug mode> Quote Link to comment Share on other sites More sharing options...
Greg S Posted August 17, 2005 Share Posted August 17, 2005 The improvement with Parabolics is so great, why would anyone even consider putting normal springs on? I replaced my 1 year-old regular springs with Rocky Mountain Para's (and new shocks) and couldn't beleave the IMPROVEMENT. Greg S 1970 109 SW (with Para's) Quote Link to comment Share on other sites More sharing options...
OrbitalPear Posted August 17, 2005 Share Posted August 17, 2005 Why consider it? Because a new set of standard springs can be had for £40 if you know where to look. And at the end of the day, I'd rather spend the defecit on fuel. Quote Link to comment Share on other sites More sharing options...
Greg S Posted August 18, 2005 Share Posted August 18, 2005 I found Para's such an improvement that I'd happily pay the extra for the springs and wouldn't care anymore if the price of fuel went up. Quote Link to comment Share on other sites More sharing options...
02GF74 Posted August 18, 2005 Share Posted August 18, 2005 I found Para's such an improvement that I'd happily pay the extra for the springs and wouldn't care anymore if the price of fuel went up. yeah but you aslo need to get longer travel shocks to reap the benefit. (this is one of my long term changes but not sure if the increase in hieght will mean I can no longer drive under my garage door.) Quote Link to comment Share on other sites More sharing options...
landyliam Posted August 18, 2005 Author Share Posted August 18, 2005 £40 , where do I start looking ? Quote Link to comment Share on other sites More sharing options...
Drongo Posted August 19, 2005 Share Posted August 19, 2005 Liam.. I put para's that Andrew got me along with Monro Shocks and Poly bushes onto my old Tiger and it was completly different, for the better...!!! Go on, change them... Alot more fun for your money than curtains...!!! Oh, and nice to see you around here... Drongo Quote Link to comment Share on other sites More sharing options...
landyliam Posted August 19, 2005 Author Share Posted August 19, 2005 Hiya Phil, do you what make the springs were? Quote Link to comment Share on other sites More sharing options...
Millsy Posted August 19, 2005 Share Posted August 19, 2005 I've got green ones on my 2A 88, much better then the standard ones I've had on my old Series 3 88. Quote Link to comment Share on other sites More sharing options...
Drongo Posted August 19, 2005 Share Posted August 19, 2005 Hiya Phil, do you what make the springs were? Duno.. They were Green, I know that... What ever Andrew had lying on his floor... Quote Link to comment Share on other sites More sharing options...
series3_mad Posted August 20, 2005 Share Posted August 20, 2005 go one www.chrisperfect.com and there are parabolics spring sets on there Quote Link to comment Share on other sites More sharing options...
landyliam Posted August 22, 2005 Author Share Posted August 22, 2005 had a wee peek over at chris perfect but at £478 for the full kit i think i'll give it a miss, if i was driving the series every day it'd be worth it but i'm only using for off roading. And who would pay nearly £800 for power steering!!! Quote Link to comment Share on other sites More sharing options...
Tonk Posted August 23, 2005 Share Posted August 23, 2005 And who would pay nearly £800 for power steering!!! hmmmm, that'd be me then i only got the ram so it was only about 600 IIRC. anyone here run rocky mountain paras? Quote Link to comment Share on other sites More sharing options...
Mark Posted August 23, 2005 Share Posted August 23, 2005 Yup. Got RM's on the Lightweight, and TIC on the IIa. IMHO the TICs are a bit more flexible than the RMs. Mark Quote Link to comment Share on other sites More sharing options...
Tonk Posted August 23, 2005 Share Posted August 23, 2005 i'e had TI's on mine and currently have CP's, got any pics of RM's articulating? how heavy is your l/weight? Quote Link to comment Share on other sites More sharing options...
Mark Posted August 23, 2005 Share Posted August 23, 2005 Sadly, got no pictures of the RM's articulating. I can try and get some, but it will be a few weeks before I get a chance. The lightweight (by it's nature) is heavier than a standard 88" series 3, and it has a Gas tank and a roll hoop added. I would still not call it a heavy truck though it still has it's orginal (if modified) 2286 petrol. It is on Procomp Shocks too, whereas the IIa is on Standards on the rear, and Koni adjustables on the front. I will see what I can do about pictures... Cheers Mark Quote Link to comment Share on other sites More sharing options...
Tonk Posted August 23, 2005 Share Posted August 23, 2005 anyone heard anything good or bad about groundhogs? Quote Link to comment Share on other sites More sharing options...
