Gromit Posted March 24, 2006 Share Posted March 24, 2006 It's so quiet in here all your Defenders are either working perfectly, or ye are all outside swearing under them. Quote Link to comment Share on other sites More sharing options...
white90 Posted March 24, 2006 Share Posted March 24, 2006 the latter after making a new rear exhaust section and fitting : new wheel bearing brake pads painting the chassis in between making some doors for the house. Quote Link to comment Share on other sites More sharing options...
western Posted March 24, 2006 Share Posted March 24, 2006 (edited) Mines just had a clutch change,picked it up today. just finished reloading all my rally recovery kit & radio's ready for a rally on Sunday near Chepstow. Edited March 24, 2006 by western Quote Link to comment Share on other sites More sharing options...
Ajlorton Posted March 24, 2006 Share Posted March 24, 2006 I'm still tweaking the clutch pedal following a slave cylinder change. Quote Link to comment Share on other sites More sharing options...
muddyplugger Posted March 24, 2006 Share Posted March 24, 2006 I've been out looking for Fords on lanes in County Durham! Quote Link to comment Share on other sites More sharing options...
LR90 Posted March 24, 2006 Share Posted March 24, 2006 Got a bit of wiring to finish on mine this weekend and maybe a hub seal if I feel lucky. Meantime its running Quote Link to comment Share on other sites More sharing options...
OilIT Posted March 25, 2006 Share Posted March 25, 2006 Trying to find the motivation to test glow plugs and fit new X-ENG handbrake Quote Link to comment Share on other sites More sharing options...
jjojjas Posted March 25, 2006 Share Posted March 25, 2006 just fitted new hinges to the new doors on the 110 and made the doors fit properly. Unlike the clowns who fittted it the last time on the insurance job. Muddyplugger - you in a club of some sort in Durham? Jas Quote Link to comment Share on other sites More sharing options...
JST Posted March 25, 2006 Share Posted March 25, 2006 just snapped the cam belt so thinking about doing something about it, i have already kicked it............... but that didn't owrk either, prob something to do with having two flats as welL! Quote Link to comment Share on other sites More sharing options...
muddyplugger Posted March 25, 2006 Share Posted March 25, 2006 just fitted new hinges to the new doors on the 110 and made the doors fit properly. Unlike the clowns who fittted it the last time on the insurance job. Muddyplugger - you in a club of some sort in Durham? Jas No mate, well yes (NE4x4) but have a brother in law (Onions, on this forum) who has a Land Rover, and have both parents and in-laws with Landys so I suppose its a family thing!! If you need anything regards lanes etc give me a shout! (The last lane, pictured is in Eggleston, when me and Onions went out checking some lanes we'd never driven, got a bit lost in the Stang forest!!!, but bagged two new ones) Anth. Quote Link to comment Share on other sites More sharing options...
LR90 Posted March 25, 2006 Share Posted March 25, 2006 Well made good progress with the wiring but hub seal is still on the todo Quote Link to comment Share on other sites More sharing options...
T-Rex Posted March 26, 2006 Share Posted March 26, 2006 Running fine thank god ( touch wood).... Quote Link to comment Share on other sites More sharing options...
widget Posted March 27, 2006 Share Posted March 27, 2006 was out finding myself a new Landy. Quote Link to comment Share on other sites More sharing options...
Mark Jenkins Posted March 27, 2006 Share Posted March 27, 2006 Just had four new pistons fitted (thank you Les Henson) and am gently running them in. Now need timing re-adjusted. Trying to stop the 'clunk' in the transmission - probably the gearbox we now think but have dismantled and re-assembled the rear differential and tightened any play up. New starter motor solenoid fitted. I need to fix my doors too... Quote Link to comment Share on other sites More sharing options...
Gromit Posted March 27, 2006 Author Share Posted March 27, 2006 dismantled and re-assembled the rear differential and tightened any play up. Did you do this on a Salisbury diff? Didn't know that that was possible. How easy a job is it? Mine's got a fair bit of play and is pretty clunky. Quote Link to comment Share on other sites More sharing options...
Mark Jenkins Posted March 27, 2006 Share Posted March 27, 2006 Did you do this on a Salisbury diff? Didn't know that that was possible. How easy a job is it? Mine's got a fair bit of play and is pretty clunky. Right then first I don't have a Salisbury differential on my 90. Second, sorry it wasn't a complete disassembly of the differential but I removed it from the rear axle: 1 undid rear prop 2 removed drive shafts 3 undid 10x diff case bolts 4 removed diff (HEAVY) - but then did not dismantle the diff beyond that point- only tightened the bearing adjusters to reduce the backlash between the pinion and the crown wheel. This itself was not too tricky, just tighten one side X-amount while slackening the other side equal amount to take up slack. Third: I don't really know what I am doing, I just follow orders from Les Henson and undo the bolts I am told to! cheers M Quote Link to comment Share on other sites More sharing options...
