Towing question - how wide?
GBMUD
I know there are some trailer and towing experts on here:
Following on from a recent towing related disaster, I am looking for a new trailer for my day to day occasional towing needs - collecting firewood, visiting the tip/recycling centre and the like. With an eye to the future I am looking at a lightweight trailer with a MGW of 2000kg which I can legally tow with a Freelander or a small camper van and possibly use to collect building materials. The trouble here is that the trailer I have in mind is 5' 5.75" wide, and occasionally I have to tow a load 6' wide.
Is there a maximum permissible overhang from the side of a trailer? I know it is only 3" either side but I would prefer to be 100% legal. The maximum permissible width for a trailer towed by a car is 7' 6", is it likely that one can legally overhang the sides to a maximum overall width of 7' 6"? NTTA only mentions rear overhangs.
TIA
Chris
Maximum Trailer Dimensions
Length (excluding the coupling and drawbar) for a four or more wheeled trailer. 7 meters or 12 meters if towed by a vehicle over 3500kg GVW.
Length of towing vehicle and trailer combined 18 meters.
Maximum overhang of load from rear of trailer 3.05 meters.
Marking of rear overhang:
Between 1 metre and 2 metres, ensure the end is clearly visible by attaching a piece of cloth or similar.
Between 2 metres and 3.05 metres, a marker board as defined in the regulations must be fitted and must be illuminated at night.
If the overhang exceeds 3.05 metres, the police must be notified before commencing the journey.
"Long Vehicle" marker plate
Not a legal requirement, though for longer combinations, particularly where the towing vehicle is over 7500kg gross weight, it is advisable to fit a plate in the interests of safety. Details can be found in the Road Vehicle Lighting Regulations, Schedule 18.
Width 2.3 meters or 2.55 metersfor a trailer towed by a vehicle over 3500kg GVW.
Loads must not project more than 305 mm either side of the trailer.
Loads over 2.9 metres in width are classed as abnormal loads, and the police must be notified before commencing a journey.
Height no limit stated.
Recommended maximum height 3m or 1.7 x wheel track.
Regularly carry 6 big bales on my 12' x 6'10" trailer. They are each 4' wide so I have a load of 8 ft width with an overhand each side of about 7". What strikes me is that I really need mirror extensions! I have often wondered just how legal this load might be but seems everyone round here does it without any hassle.
Regularly carry 6 big bales on my 12' x 6'10" trailer. They are each 4' wide so I have a load of 8 ft width with an overhang each side of about 7". What strikes me is that I really need mirror extensions! I have often wondered just how legal this load might be but seems everyone round here does it without any hassle.
305 mm is 12", which is why you have no hassle (and probably no cyclists in the bale-moving season) :-)
Cheers.
My Dad used to own a sailing boat called an E-boat which was 2.8m wide at largest point and we used to tow that behind a 4WD and even the car once. I guess it was probably still legal as the trailer was thinner so the wide parts of the boat were classed as overhangs. looks like it was pretty close to needing a Police escort though and we always just scraped through the road works without a phone call as the limit there was 9ft6 and we were basically 9ft.
Was a great little racing boat but very odd as 9ft wide but only 21ft long!
