disco_al Posted March 5, 2010 Share Posted March 5, 2010 Well i found the source of the vibration under load in my disco - rear prop doughnut was "cough" slightly worn...... slightly worn i think..... :blink: Quote Link to comment Share on other sites More sharing options...
outdoor_ian Posted March 5, 2010 Share Posted March 5, 2010 looks like you got your money's worth out of that. lol Quote Link to comment Share on other sites More sharing options...
PaulN Posted March 5, 2010 Share Posted March 5, 2010 ***kin 'ell!! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 5, 2010 Share Posted March 5, 2010 People sell worse at Sodbury Quote Link to comment Share on other sites More sharing options...
wizard Posted March 5, 2010 Share Posted March 5, 2010 Fit a 200 series rear prop and diff flange. Stupid doughnuts !!!! wizard Quote Link to comment Share on other sites More sharing options...
Adam001 Posted March 5, 2010 Share Posted March 5, 2010 Good effort! lol Quote Link to comment Share on other sites More sharing options...
LR NUT Posted March 5, 2010 Share Posted March 5, 2010 "slightly" worn I like it lol Quote Link to comment Share on other sites More sharing options...
disco_al Posted March 6, 2010 Author Share Posted March 6, 2010 got a mate in the trade who buys and breaks disco's and he's on the lookout for a 200 prop and flange to eliminate this problem once and for all. Quote Link to comment Share on other sites More sharing options...
teabag Posted March 6, 2010 Share Posted March 6, 2010 got a mate in the trade who buys and breaks disco's and he's on the lookout for a 200 prop and flange to eliminate this problem once and for all. Also tell him that the 300series V8's 96 onwards don't have donuts. Quote Link to comment Share on other sites More sharing options...
Niamh Posted April 4, 2010 Share Posted April 4, 2010 What does one need to change at the diff end to eliminate the doughnut? Niamh Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted April 4, 2010 Share Posted April 4, 2010 What does one need to change at the diff end to eliminate the doughnut? Niamh This (Click Me) from the tech archive will show what's involved Pete Quote Link to comment Share on other sites More sharing options...
Fantic Posted April 5, 2010 Share Posted April 5, 2010 Doesn't look too bad, bit of glue and it'll be good .. Quote Link to comment Share on other sites More sharing options...
Niamh Posted April 5, 2010 Share Posted April 5, 2010 And then just bolt in STC4858 instead I take it? Quote Link to comment Share on other sites More sharing options...
M&S Posted April 5, 2010 Share Posted April 5, 2010 How long was it on for? Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted April 5, 2010 Share Posted April 5, 2010 And then just bolt in STC4858 instead I take it? If thats the part number for the 200TDi diff flange the yes, however you may need a spacer as there is a couple of different length flanges. Pete. Quote Link to comment Share on other sites More sharing options...
MrKev Posted April 5, 2010 Share Posted April 5, 2010 Mine's not in too dissimilar a condition - and it's only been on there less than 8 months. Was I being too rough with it perhaps? Ok, it was a **itpart one, but even so, about 3-4k miles tops, and it's knackered. How much life should I expect from a GKN or similar OEM one? Kev Quote Link to comment Share on other sites More sharing options...
PaulN Posted April 5, 2010 Share Posted April 5, 2010 How much life should I expect from a GKN or similar OEM one? Mine's OEM and its been on for 32,000 miles and I noticed a half inch split just the other day so keeping it in mind - hope that helps! Quote Link to comment Share on other sites More sharing options...
M&S Posted April 5, 2010 Share Posted April 5, 2010 Mine is still the original and looks fine. It's done 140,000 miles. Kev, unless something else is wrong I'd be getting back in touch with your supplier... Quote Link to comment Share on other sites More sharing options...
MrKev Posted April 6, 2010 Share Posted April 6, 2010 Yeah. I'll be putting a GKN one on tonight. I don't even have a lift - if anything I've got a 20mm 'sag' (due to age!) Quote Link to comment Share on other sites More sharing options...
M&S Posted April 6, 2010 Share Posted April 6, 2010 Yeah. I'll be putting a GKN one on tonight. I don't even have a lift - if anything I've got a 20mm 'sag' (due to age!) Tell me about it Quote Link to comment Share on other sites More sharing options...
Niamh Posted April 6, 2010 Share Posted April 6, 2010 If thats the part number for the 200TDi diff flange the yes, however you may need a spacer as there is a couple of different length flanges. That's the later V8 flange kit. So is that all one needs to order? Be a bit of a pain to strip everything down and find one is missing parts for rebuilding. Niamh Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted April 6, 2010 Share Posted April 6, 2010 That's the later V8 flange kit. So is that all one needs to order? Be a bit of a pain to strip everything down and find one is missing parts for rebuilding. Niamh I don't know to be honest, I did mine 3 or 4 years ago and I can't remember which flange I got. but I had to make a spacer for it all to work. Pete. Quote Link to comment Share on other sites More sharing options...
MrKev Posted April 6, 2010 Share Posted April 6, 2010 I know you lot love photos... Here's the example. About 3k miles, I reckon. Kev Quote Link to comment Share on other sites More sharing options...
Niamh Posted April 7, 2010 Share Posted April 7, 2010 I don't know to be honest, I did mine 3 or 4 years ago and I can't remember which flange I got. but I had to make a spacer for it all to work. OK seems that the spacer 539745 isn't in the kit. Niamh Quote Link to comment Share on other sites More sharing options...
