kevrobbins Posted March 28, 2010 Share Posted March 28, 2010 What are my options on rear shafts on D90 ? go fo heavy duty (££££££££££££) or can i fit 110 of 130 shafts in my D90. running a locker & 35" silverstones.It's a detroit locker so not as strong as arb so my thinking is H/D shafts would kill the locker !! so would rather break standard shafts @ £15 or £20 a go, but if the 110 shafts where a bit stronger may they would last just a bit longer. Quote Link to comment Share on other sites More sharing options...
Aggrov8 Posted March 29, 2010 Share Posted March 29, 2010 Hi Kev you will snap after market shafts almost instantly using 35" tyres. i have a hybrid running arb's and BFG 35" mud terrains. original LR shafts are much stronger than aftermarket shafts, and i mean much stronger. email me on garysarienne@worldonline.co.za and i'll give you more details. believe me i've done what you are thinking and it cost me 2 competitions. i look forward to hearing from you. Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted March 29, 2010 Share Posted March 29, 2010 If your D90 is a 300 tdi > ie: a narrow hub type axle then the shafts/driving hubs from a 2004 > rover axled 110" will fit straight in. The long shaft from a disc braked salisbury axle will fit but the short side will be 43mm too short. Steve Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 29, 2010 Share Posted March 29, 2010 Hi Kev you will snap after market shafts almost instantly using 35" tyres. i have a hybrid running arb's and BFG 35" mud terrains. original LR shafts are much stronger than aftermarket shafts, and i mean much stronger. Well, thats put Quaffie, KAM, Ashcroft, GKN, and Maxidrive in their place hasn't it ? good of you to point out the junk these guys manufactuer compared to Genuine LR Nige Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted March 29, 2010 Share Posted March 29, 2010 If your D90 is a 300 tdi > ie: a narrow hub type axle then the shafts/driving hubs from a 2004 > rover axled 110" will fit straight in. The long shaft from a disc braked salisbury axle will fit but the short side will be 43mm too short. Steve Steve, Does this mean that the late 110 shafts are stronger than the standard 300TDi 90 shafts? Pete. Quote Link to comment Share on other sites More sharing options...
white90 Posted March 29, 2010 Share Posted March 29, 2010 And for the 2nd course here we have a dose of reality The figures show the reality. Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted March 29, 2010 Share Posted March 29, 2010 Steve, Does this mean that the late 110 shafts are stronger than the standard 300TDi 90 shafts? Pete. Yes they will be stronger than standard 90 shafts as they do away with the mushroom flange on the end. That mushroom is usually where they break. nice and easy to remove a broken shaft tho Steve Quote Link to comment Share on other sites More sharing options...
carlosbeldia Posted March 29, 2010 Share Posted March 29, 2010 Are these late 110 stornger than Salisbury? Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted March 29, 2010 Share Posted March 29, 2010 No Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted March 29, 2010 Share Posted March 29, 2010 I assume post #2 was comparing genuine LR shafts with aftermarket replacement shafts such as Sh*tpart, rather than upgraded shafts... Mike Quote Link to comment Share on other sites More sharing options...
kevrobbins Posted March 29, 2010 Author Share Posted March 29, 2010 Thanks all , but all i what to know really is can i put 110 shafts in to my D90 rear 1993 disco axle & will they be stronger than just replacing them with D90 shafts. Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted March 29, 2010 Share Posted March 29, 2010 If your D90 is a 300 tdi > ie: a narrow hub type axle then the shafts/driving hubs from a 2004 > rover axled 110" will fit straight in. The long shaft from a disc braked salisbury axle will fit but the short side will be 43mm too short. Steve Thought the above answered that A 93 disco 'should' have narrow hubs so you'll be ok there, but you will need to have a 24 spline diff in there tho. Steve Quote Link to comment Share on other sites More sharing options...
Mark90 Posted March 29, 2010 Share Posted March 29, 2010 The other thing to consider is the tendancy to bugger detroits when a shaft goes under load. So don't think just sacrificing shafts will keep the diff safe, it may not. Quote Link to comment Share on other sites More sharing options...
90200tdi Posted March 29, 2010 Share Posted March 29, 2010 A word of caution for you kevrobbins if you snap a shaft with a detroit locker wave goodby to your locker because the sudden release of torque destroys it internally. There is little difference in strength of LR shafts just because there from a 110/130 means sh#t. Save your money and buy once and buy right, heavy duty half shafts with a 5 year warranty from Ashcroft (sorry kamdiffs steve) I have been running ashcroft shafts front and back with detroit truetrac front and detriot locker in the rear since 2000 and never had a problem, and its not for the want of trying. Fully kitted HT 90 200TDI running 35" simex, weighing in at 2.5 ton. Quote Link to comment Share on other sites More sharing options...
smokinv8 Posted March 29, 2010 Share Posted March 29, 2010 Well when I had my v8 hybrid I managed to break both rear shafts at the same time with my detroit in. Didnt damage the locker though. When I bought my 90 with ARB's in, it had H/D shafts front and rear but the rear axle was drum braked so....when I changed it to a disk braked axle I lost the shafts (different splines)and now have just standard shafts but so far these have proved fine(touches wood and prays they will be ok now he said so). Quote Link to comment Share on other sites More sharing options...
kevrobbins Posted March 29, 2010 Author Share Posted March 29, 2010 Thought the above answered that A 93 disco 'should' have narrow hubs so you'll be ok there, but you will need to have a 24 spline diff in there tho. Steve Thanks steve it is 24 spline so thats ok, just though if i didn't have h/d shafts it would save the locker a bit but it dosen't seam so (ref 90200tdi below ) have herd that detroits are not so strong these days, got mine second hand with only 2 play days under it's belt for about half price so had to have it. Would like to keep it for a bit without smashing it to bits. I was allmost vertical coming out of a ditch with one front wheel airbourn when the shaft went so lessons must be lernt. Quote Link to comment Share on other sites More sharing options...
