boost pressure
stripy
what sort of max psi or bar should i be looking for on a 200tdi defender without doing head gaskets or running hot ;) on the turbo that is
cheers john
AFAIK, they run at .8bar in the defender and 1 bar in the disco, so the defender can be pushed to 1 bar safely anyway.
200Tdi in a defender is about 0.8-0.85, 300Tdi is 1.05 bar. Wasn't aware of any difference between defender and disco. Several people on here run 200Tdi defenders at 1.05/1.1 without any problems but it does depend if the injection pump has been tweaked (more boost and more fuel means higher EGT....) With standard fuelling 1.1 should be ok.
I run just over 1 bar with a mahusive Alisport 'cooler and tweaked pump, it's a Disco lump rather than a Defender lump. It runs a snadge over 150bhp and 270ft/lb. Oil flow to the turbo has been improved. I get an avergae 0f 33mpg but can get 37mpg if I pootle.
An exhaust gas temperature guage
plumb it in a bit like a Lambda sensor
waste of time but looks good, they where a bit of a 'must have' accessory a while back but it is much easier to use a SUN diesel tuner/rolling road and set it up properly the first time as EGT can be measured then and there OR if you talk to Andy Walker at Alisport and follow his instructions to the letter you will have no problems.
If you get your pre boost fueling/post boost fueling/air flow wrong it will up your EGT a bit like a petrol engine that is badly tuned, will get hotter.
If you cane the ar*e of a tuned diesel it will run hotter anyway, the idea behind tuning is to reduce the gear changes and make driving easier.
200Tdi's respond better to tuning than 300Tdi's, don't know why, they just do. I run both and I work with both, in the long run I prefer the 200 but it is only marginally better than the 300. Both my Tdi's run bigger coolers and have pump tweaking...
Oddly enough the 300 seems to respond better than the 200 to exhaust mods.
A 300 with a 200 turbo runs the same as before as long as you tweak the boost.
20mpg :( or worse
20mpg ………. I would be over the moon with that :lol:
Since I keep stuffing ponies into the motor ………….. 16mpg if I drive carefully (65/70) …………14mpg if I am in a hurry (80+) …………. 12mpg if I drive it real hard :rolleyes: …………and 6 – 8 mpg in low box off road :blink: ……….but of course, this is a real engine, 8 cylinders of petrolhead porn ………….. and no boost needed, for 200 ponies .........none of yer 4 pot deep fat fryers here ya know …. :P:lol:
Ian
Hmm all tweeks done by myself being a tight skint sort of bloke , i have tweeked to the max and it go's like stink, but i think i need to know what how hot the exhaust gasses are before she blows ( again )
does this look about right
sensible-570c
hot-682c
limit-720c
EGT guages arnt cheap are they :( not even any on e-bay
When you say tweaked to the max what do you mean? What did you do?
BTW the 200Tdi/300Tdi turbos are very crude and will not run high boost for long without going pop. About 18psi is the limit and will still shorten turbo life.
I wll try and dig out what my EGT levels were, but Les B and Tony C both run on board EGT guages
There is info in the tech archive about fitting EGT gauge if anybody is interested
Thermoguard EGT Gauge
EGT Response Times thread
Max EGT I have registered since fitting is 618*C (std fuelling, std intercooler) but rarely goes much above 550 unless you are caning it flat out up a long hill
Must get around to that Allisport intercooler one of these days :)
egt can be easily fitted yourself, its normaly a probe into the exhaust manifold which just runs a guage
sorry, yes, meant the price of parts. ETG looks to be about 30 quid. How much do the digital gauges run to?
