Jimmy Two-Jacks Posted July 3, 2010 Share Posted July 3, 2010 Hi just stripped the hub down again to do the hub seal as its leaking and couldnt get the lock nut off as I must have put it on too tight last time! I was improvising as I havent got a socket or box spanner big enough does anyone know the size required? Quote Link to comment Share on other sites More sharing options...
crclifford Posted July 3, 2010 Share Posted July 3, 2010 Hi just stripped the hub down again to do the hub seal as its leaking and couldnt get the lock nut off as I must have put it on too tight last time! I was improvising as I havent got a socket or box spanner big enough does anyone know the size required? Measuring my hub nut spanner the ID is 52mm from face to face. Does that help? Chris Quote Link to comment Share on other sites More sharing options...
tweetyduck Posted July 3, 2010 Share Posted July 3, 2010 i think its 52mm, or 1 1/4" whitworth. one of the grown-ups will confirm Quote Link to comment Share on other sites More sharing options...
Dave K Posted July 3, 2010 Share Posted July 3, 2010 52mm Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted July 3, 2010 Author Share Posted July 3, 2010 52mm Cheers Quote Link to comment Share on other sites More sharing options...
western Posted July 3, 2010 Share Posted July 3, 2010 James get a box spanner for these from http://shop.difflock.com/land-rover-spanner-plain-p-33.html or your nearest LR independent part supplier. Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted July 4, 2010 Author Share Posted July 4, 2010 James get a box spanner for these from http://shop.difflock.com/land-rover-spanner-plain-p-33.html or your nearest LR independent part supplier. Thanks. Just got one coming from ebay found 52mm spanners for £28-32.00!!!! And then searched for 52mm Hub Box Spanner and got one for that exact purpose for £5.99 Quote Link to comment Share on other sites More sharing options...
jbs Posted July 4, 2010 Share Posted July 4, 2010 Here's a quick one for you-If you weld a flat plate onto the end of the box spanner leaving the holes either side of the box spanner for you to put a bar through to loosen the lock nut's, you can then weld an old 1/2 inch socket on it to be able to use a torque wrench to get the correct tightness as I have done with mine at home Work's a treat too HTH John Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted July 4, 2010 Author Share Posted July 4, 2010 Good tip thanks Quote Link to comment Share on other sites More sharing options...
davie Posted July 4, 2010 Share Posted July 4, 2010 Quick hijack on topic here, does anyone know when the defenders went accross from the usual arrangement on front bearings, ie can be done with hub nut spanner and a screwdriver through it to tighten bearing in, onto the current one where its torqued up with the shims? I have to do my front brakes shortly and dont fancy buying a new socket to do it cause i am not entirely sure on whether i have old or new method. Its a 2003 td5 90 csw. Many thanks all Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 4, 2010 Share Posted July 4, 2010 I believe they changed to the spacer/shim arrangement for the Td5 vehicles wasn't it? Microcat lists the coloured spacers from VIN XA 159807. You can revert to the earlier (and much simpler) setup quite easily, just need to get some locknuts, a keyed thrust washer, and a tab washer, for each side I think Quote Link to comment Share on other sites More sharing options...
Ex Member Posted July 4, 2010 Share Posted July 4, 2010 2-1/16" as was Jeep, back in the day, along with most light trucks...... Quote Link to comment Share on other sites More sharing options...
