reads90 Posted June 28, 2006 Share Posted June 28, 2006 More stuff i found in Aus This paint you paint on the car and then go off roading and then peal off at the end of the day and don't have any scratches here is more details about it A revolutionary new "roll on/peel off" plastic skin paint protection has been released onto the Australian automotive market. Called Scratch Pro AP60, the Australian made product is ideal for use on four wheel drives, commercial vans, trucks and cars, to protect the paintwork from scratching, stone chips, road grime and bird droppings. It also provides UV protection to the paintwork. Scratch Pro AP60 is an aqua polymer product, meaning that it is a water based polymer which is easily applied using a 100mm roller to the sides, bonnet and sill panels of vehicles. It is applied approximately 1mm thick and will last up to two months before removal. Scratch Pro AP60 is cost effective, easily applied by the vehicle owner and can be left on the vehicle for up to two months. It is available in a 1 litre container and costs around $60. Alternatively it is available applied to the vehicle, from 4WD outlets for around $150 for large 4WDs such as Landcruiser, Patrol and Pajero Scratch Pro is a water soluble, liquid applied coating that dries to a clear non-tacky peel-able membrane used for the temporary protection of motor vehicles paintwork. Scratch Pro film is very similar to that of a skin or membrane, allowing the paint surface to out gas while protecting the paint finish. Scratch Pro is also UV resistant and therefore helps prevent UV degradation as well as environmental hazards such as stone chips, branch scratches, road grime and bird droppings. Ideal for: Recreational 4WD Vehicle storage Prestige vehicle transportation Trucks and buses Rental equipment Scratch Pro Benefits/Facts: Protects all automotive surfaces Protection cannot bake on Protection cannot fall off Water cannot be trapped behind protection and acid stain paintwork 6 months maximum protection before removal is required Removal of protection leaves no residue No chemicals are required for removal Product is environmentally friendly Aids in the prevention of stone chips, cuts and scratches No damage to paintwork caused by friction Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted June 28, 2006 Share Posted June 28, 2006 Tart film Quote Link to comment Share on other sites More sharing options...
simonr Posted June 28, 2006 Share Posted June 28, 2006 What's the betting this is just PVA glue? Si Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted June 28, 2006 Share Posted June 28, 2006 If i painted that stuff onto any of my LR's (with factory paint jobs) the paint would come off with it!! Quote Link to comment Share on other sites More sharing options...
TomG Posted June 28, 2006 Share Posted June 28, 2006 Umm.. is it available in orange? or X-tart ? Quote Link to comment Share on other sites More sharing options...
rtbarton Posted June 28, 2006 Share Posted June 28, 2006 If you peeled it off carefully and joined the edges up again you could have an inflatable bouncy Landrover. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 28, 2006 Share Posted June 28, 2006 Exmoor Beast will buy 25-gallons of it and never remove it. Les. Quote Link to comment Share on other sites More sharing options...
Andy Posted June 28, 2006 Share Posted June 28, 2006 If you peeled it off carefully and joined the edges up again you could have an inflatable bouncy Landrover. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 28, 2006 Share Posted June 28, 2006 If you peeled it off carefully and joined the edges up again you could have an inflatable bouncy Landrover You been drinking Roger? Les. Quote Link to comment Share on other sites More sharing options...
Steve King Posted June 28, 2006 Share Posted June 28, 2006 All very well but will it protect against whacking the front bumper against or rock or two or roof scrapes from the multi storey car park at Brighton Marina (found out about the last one whilst leaving my neice's birthday do at the Bowling Alley ) Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 28, 2006 Share Posted June 28, 2006 If you peeled it off carefully and joined the edges up again you could have an inflatable bouncy Landrover. Brilliant... Not required here though. Take one's wagon anywhere near a nasty scratchy tree? Perish the thought Quote Link to comment Share on other sites More sharing options...
mattD110td5x Posted June 29, 2006 Share Posted June 29, 2006 ..... near a nasty scratchy tree? Yes, saw a very good doco on the Falklands the other night on the ABC in Australia, didn't see any trees, except for some pines in town gardens. Looked for a bogmonster in the background, but no only a few old 110's and a freelander. Did see a penguin. ABC - Foreign Correspondent ttfn Matthew Quote Link to comment Share on other sites More sharing options...
rtbarton Posted June 29, 2006 Share Posted June 29, 2006 You been drinking Roger?Les. I have now..... Smear some grease on your landrover before applying the film, fasten a tyre valve on and inflate, that way you'll have a protective cushion against bumping into things, and just how pedestrian friendly would that be? an external airbag Quote Link to comment Share on other sites More sharing options...
JSG Posted June 29, 2006 Share Posted June 29, 2006 Umm.. is it available in orange? Yes, but it costs 10 times as much and only lasts for half a day. Quote Link to comment Share on other sites More sharing options...
