TJ101 Posted July 12, 2006 Share Posted July 12, 2006 Morning All Before i start searching, anyone knows where the best place for HD bushs to fit the cranked rear arms on the Hybrid, Looks like 7 Sisters finishes them off, a bit too much play now on the axel ends !! Thanks all Quote Link to comment Share on other sites More sharing options...
JST Posted July 12, 2006 Share Posted July 12, 2006 i use Bearmach blue, easy to fit, quite cheap and lasted well (so far) Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted July 12, 2006 Share Posted July 12, 2006 SuperPro - last longer and get more flex OEC do them but Richard Fearn www.superpro.eu (or some such is only at Westonzoyland/Middlezoy If you ask him nicely then he may sell you some of his new design front ones as well... Quote Link to comment Share on other sites More sharing options...
TJ101 Posted July 12, 2006 Author Share Posted July 12, 2006 Thanks David,, that joged the grey matter,, I remember him, tied up with Neil Revington with the TR's out the back end of Othery !! Quote Link to comment Share on other sites More sharing options...
Petergg Posted July 12, 2006 Share Posted July 12, 2006 i use Bearmach blue, easy to fit, quite cheap and lasted well (so far) I have been told that Superpro make bearmach bushes, not sure if it is correct. I use superpro and they are fine from Specialist Leisure. Peter Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted July 12, 2006 Share Posted July 12, 2006 Thanks David,, that joged the grey matter,, I remember him, tied up with Neil Revington with the TR's out the back end of Othery !! That's the bloke! Nice collection of Triumphs - I do like a well turned out TR Quote Link to comment Share on other sites More sharing options...
darthdicky Posted July 12, 2006 Share Posted July 12, 2006 http://devon4x4.com/forum/viewtopic.php?t=1741 Quote Link to comment Share on other sites More sharing options...
TJ101 Posted July 12, 2006 Author Share Posted July 12, 2006 Thanks Richard,, Well spotted , interesting , will mention it when i see the man from SuperPro Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted July 12, 2006 Share Posted July 12, 2006 I had a chat with the 'man from SuperPro' about it about two weeks ago. Interesting response - I will leave you to decide Take a set of Bearmach bushes with you though Quote Link to comment Share on other sites More sharing options...
LR90 Posted July 12, 2006 Share Posted July 12, 2006 What makes these better than the orig Polibush (in whatever colour) or even OEM for some applications? Quote Link to comment Share on other sites More sharing options...
white90 Posted July 12, 2006 Share Posted July 12, 2006 easy to fit I guess? I just use standard genuine L/R ones all round now after my supply of slotted ones ran dry Quote Link to comment Share on other sites More sharing options...
LR90 Posted July 12, 2006 Share Posted July 12, 2006 Are the superpro easier to fit than polybush? I assume(?) all polybush like bushes are easier to fit than OEM. Sam's still got slotted bushes hasn't he? Quote Link to comment Share on other sites More sharing options...
white90 Posted July 12, 2006 Share Posted July 12, 2006 Sam is too busy building rock crawling buggies at present to do any more bushes. he told me he had some modifications (in the compound) for the next sets Quote Link to comment Share on other sites More sharing options...
LR90 Posted July 12, 2006 Share Posted July 12, 2006 Could be timely thought my current set have been holding up very well. On the polybush Q and back OT I also am looking at replacing worn rear trailing arm bushes (currently red polys as best I can tell). OEM is a strong fav for these (but harder to fit), alternatively I was considering blue polys but should I be considering bearmarch or superpro? Quote Link to comment Share on other sites More sharing options...
SteveG Posted July 13, 2006 Share Posted July 13, 2006 Thanks Richard,, Well spotted , interesting , will mention it when i see the man from SuperPro Tim did you see Simon's comment, in the link DD posted, on Wolf bushes for the rear radius arms being tougher. May be worth trying these. I've seen a number of comments on using polybushes on the rear radius arms that other than 'Comfort' ones they tend to reduce flex as they are significantly harder than LR OEM ones. Might be worth giving the Wolf ones a go. Cheers Steve Quote Link to comment Share on other sites More sharing options...
TJ101 Posted July 13, 2006 Author Share Posted July 13, 2006 Mm, going to pull the arms off, and pop over to superPro, as i guess i have 110 rear arm (sal axle) etc also got to replace the 3 link arm rose joints, !! Quote Link to comment Share on other sites More sharing options...
Mark90 Posted July 13, 2006 Share Posted July 13, 2006 My understanding is that Simon uses the Wolf bushes on the chassis end only, and it's the axle end that Tim's replacing, but if it is chassis end to then it might be worth going the wolf ones ago. Tim 110 rear arms are no different to 90/RRC/Disco ones. Quote Link to comment Share on other sites More sharing options...
