MrKev Posted November 25, 2017 Share Posted November 25, 2017 Nice. It's been a while since we did this - good to see it's proving useful! Kev Quote Link to comment Share on other sites More sharing options...
TSD Posted November 27, 2017 Share Posted November 27, 2017 So as Kev previously found, the checksum byte will always be one of four values (0x50, 0x70, 0x90, 0xB0) minus the XOR sum of the high byte and low byte of the speedo calibration value. The first value is a bit difficult to explain but so far it follows the procedure below :- for speedo rate settings (RATE) below 4096 : CHECK WORD = ((int(RATE/16) % 4) * 2 + 5) * 16 for values of 4096 or above CHECK WORD = (11 - (2 * ((int(RATE/16)+2) % 4))) * 16 (% is the modulus operator) This screams out for further simplification if anyone can be bothered, but it seems to work for all the values tested thus far (every value from 2000 to 5556). It's easy to see the pattern once plotted on a graph... I think that completes the geekery, back to the oily bits instead Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 27, 2017 Share Posted November 27, 2017 That's excellent work TSD, like you say it can probably be simplified further as well. Thanks for completing the puzzle for us all It's interesting how the graph flips at 4096. How did you come up with the algorithm once you established the pattern? Quote Link to comment Share on other sites More sharing options...
TSD Posted November 27, 2017 Share Posted November 27, 2017 (edited) 3 hours ago, CwazyWabbit said: How did you come up with the algorithm once you established the pattern? More or less by inspection TBH. I simply wrote a function that generates the required number... Checkword changes every 16 values, so (n/16). We know it is one of four values, so (n/16)%4 to generate the remainder, 0,1,2,3. Write down the binary values of the check word, and you can see they are = 2x + 5 for x in 0..3 Then the * 16 simply moves it into the high nibble, so 0x05 becomes 0x50 I can see there is probably a 'bit twiddling' route to simplification, but I can't immediately see what it is. The obvious clue being the 2's complement binary representation of -11 has the same bit pattern as +5. Edited November 27, 2017 by TSD 1 Quote Link to comment Share on other sites More sharing options...
MrKev Posted November 27, 2017 Share Posted November 27, 2017 (edited) I'm kind of trying to get my brain switched back on to this, but it's been a while @TSD: I think you're basically right with the observation that -11 is the equivalent of +5. The /16 (or shift 4 places) does seem to tie up with the "4096" thing, as the top bit may become the sign/carry flag for an 8 bit micro: i.e. 4096 <<4 = 256 or 0 with carry. Kev Edited November 27, 2017 by MrKev 1 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 27, 2017 Share Posted November 27, 2017 Lordy ! Brain mangle. Mo Quote Link to comment Share on other sites More sharing options...
MrKev Posted November 27, 2017 Share Posted November 27, 2017 I meant 4096 >> 4 That better? Kev Quote Link to comment Share on other sites More sharing options...
TSD Posted November 27, 2017 Share Posted November 27, 2017 Once I've finished messing about with this, I thought I'd write a small Python script that could be run on a Raspberry Pi by anyone who can temporarily solder small wires onto the speedo. So no real need to understand what goes on behind the curtain. Quote Link to comment Share on other sites More sharing options...
TSD Posted November 28, 2017 Share Posted November 28, 2017 This could get repetitive... added a further wrinkle CHECK WORD = (11 - (2 * ((int((16383-RATE)/16)+2) % 4))) * 16 for values > 8192. Expecting another one at 12288 much? Quote Link to comment Share on other sites More sharing options...
MrKev Posted November 28, 2017 Share Posted November 28, 2017 Ok, i think its simpler to start with this: Take RATE, right shift 4 (/16), then logical AND with 0xFF, or 256 before wrapping the rest of the equation. I haven't got a piece of paper handy, to work out the rest at the moment! I think this will lead to a general rule for all rates, and satisfy the below 4096 case at the same time. Kev Quote Link to comment Share on other sites More sharing options...
TSD Posted December 1, 2017 Share Posted December 1, 2017 I think I finally have a general solution... tmpval = (RATE >> 4) & 0x0003 signbit = RATE & 0x1000 offset = RATE >> 12 if signbit: checkword = ((((offset - tmpval) * 2) % 8) + 0x05) << 4 else: checkword = ((((offset + tmpval) * 2) % 8) + 0x05) << 4 This could be a general solution in fixed width signed binary, but less obvious in a high level language. The speedo works over the range RATE = 2000 to 19542, so very possibly out to 32767, buts that's as far as I've tested. It would take another week to check all the values further up and I'm getting bored of the sound of the power relay clicking I think I will try to write the R-Pi script and then call it done. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted December 1, 2017 Share Posted December 1, 2017 Just to be a pain in the ass...you should probably figure out the setting for 200000 as that is what the GPS sender uses. https://www.lspeedo.com/pdf/vdo-gps-installation.pdf That is the only use I can think of for any higher rate than what you already have. Quote Link to comment Share on other sites More sharing options...
TSD Posted December 1, 2017 Share Posted December 1, 2017 As far as I'm aware, the limit for the Td5 speedo would be 65535, as the calibration word appears to be 16bit. GPS is technically not road legal in the UK as the primary speedo - at least it will not pass IVA testing. I did think about a device that continually recalibrates the speedo based on gps, but that would be too silly even for me Quote Link to comment Share on other sites More sharing options...
TSD Posted December 2, 2017 Share Posted December 2, 2017 OK, just to answer the final question, the maximum rate for the sender on the Td5 speedo is 60000. The checksum routine as described appears to work for all values 2000 - 60000. I have a simple programming script for a raspberry pi available if anyone needs it - send me a PM. If you have a working raspberry pi setup (of any version) and you can solder 6 small wires, that's all you need. (You do need to crowbar the speedo open as described previously in this thread) First customer gets the job of writing better instructions ! Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted December 2, 2017 Share Posted December 2, 2017 That's excellent work TSD and if people don't think they are up to soldering the 6 wires on they can purchase one of these instead https://www.ebay.co.uk/itm/272804727748 Quote Link to comment Share on other sites More sharing options...
doezel Posted May 14, 2020 Share Posted May 14, 2020 Thanks for this topic! I am now clocking 100.000 km extra to my "new" TD5 tacho which will replace my old analog tacho. instead of the pic I use an arduino with this code and also the ULN2803. This gives me the highest speed (1km added every 1.5 seconds) int ledPin = 6; void setup() { // put your setup code here, to run once: pinMode(ledPin, OUTPUT); } void loop() { // put your main code here, to run repeatedly: digitalWrite(ledPin, HIGH); delayMicroseconds(400); digitalWrite(ledPin, LOW); delayMicroseconds(400); } 1 Quote Link to comment Share on other sites More sharing options...
Dan87GT Posted May 27, 2020 Share Posted May 27, 2020 Hello.....just wondering if anyone is offering a mileage run-up service for my replacement TD5 speedometer?.....thank you!...Dan Quote Link to comment Share on other sites More sharing options...
western Posted May 27, 2020 Share Posted May 27, 2020 I sent mine to https://digidash.co.uk/ before this thread existed. Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 27, 2020 Share Posted May 27, 2020 2 hours ago, Dan87GT said: Hello.....just wondering if anyone is offering a mileage run-up service for my replacement TD5 speedometer?.....thank you!...Dan Pop CwazyWabbit a PM (few posts above) he should be able to sort you out. Quote Link to comment Share on other sites More sharing options...
doezel Posted June 4, 2020 Share Posted June 4, 2020 (edited) soooooohhhhh.... I forgot to check the runup of kilometers on my odometer... now it shows 20.000km too much 🙂 So i ordered an usb-programmer and a suitable clamp from my uncle Ali in China. When that arrives I hope to be able to set the distance back to the desired value. Also made a little app to change the desired value to a hex-array: Edited June 4, 2020 by doezel 3 Quote Link to comment Share on other sites More sharing options...
doezel Posted July 4, 2020 Share Posted July 4, 2020 (edited) Hi! I now have a working programmer for the 93S46 chip.(an EZP2019 from my Chinese uncle Ali) Only issue I have now is this: I used the alghorithm written down by @MrKev. But for some reason it doen't work in kilometers. For example: ffff ffff ffff ffff ffff ffff ffff ffff shows 1.0KM, so that's good. MrKevs example of 197672 (CFBC CFBC CFBC CFBC CFBD CFBD CFBD CFBD ) shows 271105KM. (factor 1.3715 too much) When I program 255000 (C1BD C1BD C1BD C1BD C1BE C1BE C1BE C1BE ) my meter shows 267233KM. (factor 1,0480 too much) When I program 666666 (5D3C 5D3C 5D3C 5D3C 5D3C 5D3D 5D3D 5D3D ) my meter shows 801301KM. (factor 1,2020 too much) So it's not a straight miles to kilometers conversion issue. Any idea what I'm missing here? Edited July 4, 2020 by doezel added image Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 4, 2020 Share Posted July 4, 2020 Hi, Looking back through my emails I programmed up a KPH speedo for Ray in Australia with 0xB29A 0xB29A 0xB29A 0xB29A 0xB29B 0xB29B 0xB29B 0xB29B Which gave a reading of 317001, this follows MrKevs algorithm. I'm a little perplexed as to how you have had different results. Is it possible you've accidentally changed some of the other values in the serial eeprom? Does the needle still work when it's receiving an input? EDIT: There should be a dump of the serial eeprom from a KPH speed earlier on in this thread that you could use for reference. EDIT2: Here's the link to the post with a KPH eeprom dump, it's the second dump in the post Quote Link to comment Share on other sites More sharing options...
MrKev Posted July 4, 2020 Share Posted July 4, 2020 Can you post a link to your code? Quote Link to comment Share on other sites More sharing options...
Popular Post CwazyWabbit Posted July 4, 2020 Popular Post Share Posted July 4, 2020 As a side note, I'm surprised to see it is 9 years since we did this 😕 5 1 Quote Link to comment Share on other sites More sharing options...
western Posted July 4, 2020 Share Posted July 4, 2020 Good work takes time & there has been lots of research & effort by those involved Top job all. CW have you had any result with making the Td5 speedo red alarm light work in retrofitted vehicles ? Quote Link to comment Share on other sites More sharing options...
