Ruurd Posted November 23, 2011 Share Posted November 23, 2011 Yes call me an idiot I know diddly about cars and am going to do a rebuild of sorts and the first thing necessary is axle stands., So. What rating and what minimum and maximum height should I get? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 23, 2011 Share Posted November 23, 2011 I have a pair of these: http://www.machinemart.co.uk/shop/product/details/cax-6tbc-6-ton-axle-stands Tall enough to support at the chassis if I need to as well . Quote Link to comment Share on other sites More sharing options...
Ruurd Posted November 23, 2011 Author Share Posted November 23, 2011 Tall enough to support at the chassis if I need to as well . What are they? 6 ton a pair and max height 600 mm? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 23, 2011 Share Posted November 23, 2011 yeah, 6 ton a pair and 400-615mm high Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 23, 2011 Share Posted November 23, 2011 I have the same stands (well different brand but obviously same production line) definitely recommended very well made Quote Link to comment Share on other sites More sharing options...
western Posted November 23, 2011 Share Posted November 23, 2011 IIRC mine are 3tonne each minimum as well & have a good extension. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 23, 2011 Share Posted November 23, 2011 If you're new to this then I'd suggest: - Get a tape measure and measure the distance under the car where you're likely to put an axle stand, and add at least 3" to that. - Look in the manual to see how much your 110 weighs (~2ton) but since this is safety critical and the cheap/low-rated stands are usually horrid you probably want to buy something that's 3t plus if only for the nicer quality. Quote Link to comment Share on other sites More sharing options...
Boro Posted November 23, 2011 Share Posted November 23, 2011 I have a couple of sets of those stands above and rate them, the nice thing about the 6 ton stands is the larger footprint making them a lot more stable than the lower capacity stands Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 23, 2011 Share Posted November 23, 2011 Most axle stands are 2 or 3 ton rated. You have to bear in mind that you will never put the entire weight of the vehicle on just one axle stand. If you want to support the entire weight of the vehicle on axle stands, then 4 x 2-ton axle stands will be plenty. Don't just jack one corner of the vehicle to max and then put a stand under it, then go to the other side to do the same as the first stand may well tilt and possibly fall over. Les. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 23, 2011 Share Posted November 23, 2011 Out of curiosity Les how do you go about putting a vehicle on stands to avoid tilting? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 23, 2011 Share Posted November 23, 2011 I have a disco bottle jack which I use (sometimes spaced with some large chunks of wood). I lift as close to the centre of the axle as I can get and then stick a stand each side Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 24, 2011 Share Posted November 24, 2011 I jack under the diff. The short side of the axle will raise higher than the other side, but not that much. Two axle stands either end of the axle, then jack the long side up higher by putting the jack under the radius arm and raise the stand on that side to get the vehicle level. Les. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 24, 2011 Share Posted November 24, 2011 Cheers for that Les and Ross Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 24, 2011 Share Posted November 24, 2011 It doesn't go up completely straight, but I then get a helper to lean on the upside gently to level the axle out Quote Link to comment Share on other sites More sharing options...
Maverik Posted November 24, 2011 Share Posted November 24, 2011 I've got a pair of Halfords own axle stands, non of this fancy ratchet type stuff, they're simple tubes with a cross pin to lock in position, rated at 3t each, they're nice and sturdy. Personally would't get anything less than 3t SWL per leg. these are good as you can take the top tube out and use it as a wee extension bar for a shifter or such like. Quote Link to comment Share on other sites More sharing options...
SPendrey Posted November 24, 2011 Share Posted November 24, 2011 I've got a pair of Halfords own axle stands, non of this fancy ratchet type stuff, they're simple tubes with a cross pin to lock in position, rated at 3t each, they're nice and sturdy. Personally would't get anything less than 3t SWL per leg. these are good as you can take the top tube out and use it as a wee extension bar for a shifter or such like. ...but not while the car is on the stand, or it might suddenly become unstable! :-) Quote Link to comment Share on other sites More sharing options...
