PGM316 Posted December 13, 2011 Share Posted December 13, 2011 Sorry if this has been covered already... Does anyone have a good recomendation for some fitted rubber mats? The Landrover ones being £70 and some other now Landrover ones about £50, just seems expensive. The ones I have are a bit worn, but have a foam underside, so keep the floor nice and damp! cheers Paul Quote Link to comment Share on other sites More sharing options...
Lars L Posted December 13, 2011 Share Posted December 13, 2011 I've bought two sets of these (scroll down a bit): http://www.mailorder4x4.com/acatalog/Online_Catalogue_Interior_628.html Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 13, 2011 Share Posted December 13, 2011 Genuine Land Rover ones in mine. Yes they cost a bit, but they fit perfectly and do a lot of soundproofing on top of the other stuff I have underneath then. Quote Link to comment Share on other sites More sharing options...
PGM316 Posted December 13, 2011 Author Share Posted December 13, 2011 Oh retro I don't deal well with multiple options! They look ok on Lars link and very cheap, do they fit well? Cheers both Quote Link to comment Share on other sites More sharing options...
Lars L Posted December 13, 2011 Share Posted December 13, 2011 Yes, they fit quite OK. Quote Link to comment Share on other sites More sharing options...
Steve King Posted December 13, 2011 Share Posted December 13, 2011 Well just to add to the options - if you want loose fitting mats as well there are some with raised edges that contain the leaks and drips from boots! My brother bought me a set a while ago and I can't seem to find them now (the ones advertised as "Mudmats" are not the same. Anyway when I switched from a 300 TDI Defender to a TD5 my wife was away looking after my Mother and i am pleased to report that the mats came up a treat in the dishwasher!!!!! :hysterical: Quote Link to comment Share on other sites More sharing options...
dantd5 Posted December 13, 2011 Share Posted December 13, 2011 Dishwasher????? I´d be skinned alive if SWMBo sees any trace of landy part in the house... Quote Link to comment Share on other sites More sharing options...
PGM316 Posted December 15, 2011 Author Share Posted December 15, 2011 I've bought two sets of these (scroll down a bit): http://www.mailorder...terior_628.html I looked at these, they have a foam bottom, downside of these with a Defender with all their leaks is that it'll hold dampness. Quote Link to comment Share on other sites More sharing options...
Mutley Posted December 15, 2011 Share Posted December 15, 2011 Is it not worth buying a sheet of rubber matting and cutting to shape? I did this for the back of the 90, as the wife has a horse noticed that the stable mats where ideal, grooved channels underneath and small bobbles on top, come in various thicknesses (10mm and 18mm) and 4'x6' sheets. I got a 10mm sheet and cut it to size, helps with sound proofing, will NEVER wear out! And a damn sight cheaper than a LR one! Quote Link to comment Share on other sites More sharing options...
Lars L Posted December 15, 2011 Share Posted December 15, 2011 I looked at these, they have a foam bottom, downside of these with a Defender with all their leaks is that it'll hold dampness. They have foam, but it doesn't soak up any water. They of course trap water like any other rubber mat. Quote Link to comment Share on other sites More sharing options...
Mutz Posted December 15, 2011 Share Posted December 15, 2011 Is it not worth buying a sheet of rubber matting and cutting to shape? I did this for the back of the 90, as the wife has a horse noticed that the stable mats where ideal, grooved channels underneath and small bobbles on top, come in various thicknesses (10mm and 18mm) and 4'x6' sheets. I got a 10mm sheet and cut it to size, helps with sound proofing, will NEVER wear out! And a damn sight cheaper than a LR one! But where does one get them from and how much? Quote Link to comment Share on other sites More sharing options...
bernie Posted December 15, 2011 Share Posted December 15, 2011 I agree with stable matting, i have these thoughout my station wagon 110, i have the 18mm with ridges underneath to let the water escape, and excellent soudproofing. Quote Link to comment Share on other sites More sharing options...
potato head Posted December 15, 2011 Share Posted December 15, 2011 But where does one get them from and how much? Look to the bay of e, that's where I found mine - stable mats Admittedly they are easy to work with and do cut down the noise but it will not act as a puddle maker as the water just rolls of the edge of the mat. Quote Link to comment Share on other sites More sharing options...
Mutley Posted December 15, 2011 Share Posted December 15, 2011 Ebay or Google search should get 1 sheet for about 30 quid depending on thickness, if you find some one supplying local saves on postage too. Minimum thickness 10-11mm it dont come any thinner. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted December 19, 2011 Share Posted December 19, 2011 Just beware with stable mats you dont get the epdm ones which are much stiffer and lighter - equally don't go stupid on rubber thickness, it weighs a ton. N Quote Link to comment Share on other sites More sharing options...
ZeroDelta Posted December 19, 2011 Share Posted December 19, 2011 I got a set of genuine front mats form eBay for £29 in an almost new condition. If you are desperate the are probably the best, but f you wait you can always get a bargain on eBay. I would have to agree with Retroanaconda as the genuine mats are the best and really do help with sound proofing. Quote Link to comment Share on other sites More sharing options...
Mutley Posted December 19, 2011 Share Posted December 19, 2011 Ok regards genuine mats i beleive the part no. STC50172 fits upto 2007.....What is the difference between the mats after 2007? Personaly i like the look of this pattern......But this comes up as Pre 2007 and also for 2007 on? This one not like so much but comes up pre 2007 as well as the one above? Any help in this matter Cheers Mutley Quote Link to comment Share on other sites More sharing options...
RustyNissanPrairie Posted December 19, 2011 Share Posted December 19, 2011 I have some I bought off ebay a few years ago - they look similar underneath to the stuff Mutley posted but the top surface has small rough chippings, they were pre cut, thick heavy rubber, good sound proofer. Just make sure the footwells are properly dry and slather them in waxoyl, let it dry then put the matts in-no problems. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 19, 2011 Share Posted December 19, 2011 Mats change with gearbox changes. You have mats for 2.5N/A, TD, 200Tdi (ie. LT77 vehicles), mats for 300Tdi vehicles with R380s, mats for Td5 vehicles with R380s, and I think even ones for V8s with LT85s! Just put your VIN into Microcat etc. and it should tell you what you need Quote Link to comment Share on other sites More sharing options...
Mutley Posted December 19, 2011 Share Posted December 19, 2011 Thanks Retro, now where do i find this Microcat thingy? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 19, 2011 Share Posted December 19, 2011 Here PS. Windows only, no Macs Quote Link to comment Share on other sites More sharing options...
