Steve 110 Posted December 6, 2012 Share Posted December 6, 2012 Hi, The previous owner of my 110 thought that the inside of the panels would rust so applied uneven coats of hammerite inside (please, don't go there ). I would appreciate advice on removing that scruffy carp paint from the roof and side panels (it's a hardtop and multi coloured inside!) as I'm planning to insulate the whole lot this summer. It's half peeling off and don't fancy wasting expensive self adhesive materials for it to peel off a week later !!! I haven't got the luxury of a driveway (might be able to borrow a drive in shed!), would the old paint stripper (decapant in french, gluppy stuff and pretty messy/toxic) stuff do the job with the roof in place or should I go convertible for a few days? Cheers Quote Link to comment Share on other sites More sharing options...
western Posted December 6, 2012 Share Posted December 6, 2012 nitromors paint stripper should do the job, Quote Link to comment Share on other sites More sharing options...
ajh Posted December 6, 2012 Share Posted December 6, 2012 If oil based, biodiesel will apparently cause that to soften... (guess what I need to re-paint, hint it's right below the FIP. ) If it's xylene based you can often use acetone to wipe it off pretty easily. Quote Link to comment Share on other sites More sharing options...
Big.Mike Posted December 6, 2012 Share Posted December 6, 2012 nitromors paint stripper should do the job, I'll second this, we removed hammerite from some water tanks using this and it worked a treat. Need a well ventilated area though! Btw, what insulation are you going to use? Cheers, Mike Quote Link to comment Share on other sites More sharing options...
Eightpot Posted December 6, 2012 Share Posted December 6, 2012 abrasive poly discs like these will quickly remove paint, hammerite, rust etc without cutting the metal. Just used one to de-hammerite a range rover engine bay and it took about 30 mins. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted December 7, 2012 Share Posted December 7, 2012 If you have the patience old brake fluid will remove most paint Quote Link to comment Share on other sites More sharing options...
Steve 110 Posted December 7, 2012 Author Share Posted December 7, 2012 I'll second this, we removed hammerite from some water tanks using this and it worked a treat. Need a well ventilated area though! Btw, what insulation are you going to use? Cheers, Mike I'm going to line the roof with the egg shell style mats from noise killer, tested it at billing a couple of years back and it was quite impressive. The rest will probably be done with fatmat, or the noise killer 110 hardtop kit. I'll source some nitromors then ! Looking forward to do the roof... Thanks for your advice Quote Link to comment Share on other sites More sharing options...
del Posted December 7, 2012 Share Posted December 7, 2012 the new nitromors isnt as good as the old stuff, the fun police have removed the chemical that made it bubble up and remove the paint qiuckly , still does the same job but slower -and is better for the enviroment woohoo!!! Quote Link to comment Share on other sites More sharing options...
bluehaze Posted December 10, 2012 Share Posted December 10, 2012 If you're intent on insulating why bother stripping the hammerite off? At least you know that it is well protected and if you use spray on evo stick glue it bonds well with the hammerite. I used the aluminium bubble insulation stuff from B&Q. Quote Link to comment Share on other sites More sharing options...
PaddyMac Posted January 7, 2013 Share Posted January 7, 2013 I agree with bluehaze, why bother putting yourself to extra hassle because once you start to strip the paint it will only look worse unless it is compleately done. I would leave it and add the insulation over it. And I would finish off the interior with a wolf insulation kit. The wolf kit covers every thing anyway and you will never see the paint wheather you strip it or not. I myself put closed cell Aluminum Foil Bubble sheets directly to the sides of the back and then covered that again by sticking up a MILITARY LAND ROVER WOLF TUM RAD-HAZ kit over that. Theres loads on flea-bay at the moment or I bought mine from Craddocks. In the coldest winters here in Ireland I have never regreted it. Quote Link to comment Share on other sites More sharing options...
