Guest Posted December 16, 2012 Share Posted December 16, 2012 Jack, Let me know if you need a hand, I have access to a trailer if you need to go and pick up a Disco. Jason. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 16, 2012 Share Posted December 16, 2012 I converted a disco 200 to defender spec using a scrap lump Diablo. A scrap lump just like yours funnily enough ! Mo Quote Link to comment Share on other sites More sharing options...
western Posted December 16, 2012 Share Posted December 16, 2012 And the defender and disco ones are the same? cylinder head & block & internal components. oil filter head are all the same, you'll have to swap the manifolds/turbo & complete timming case.so it becomes a Defender spec 200tdi. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 16, 2012 Share Posted December 16, 2012 ... and the injection pump brackets, injector pipes, alternator and ps pump brackets, ps pump, dipstick and tube, and you'll probably need the crank pulley too. HTH Mo Quote Link to comment Share on other sites More sharing options...
Diablo Posted December 16, 2012 Author Share Posted December 16, 2012 Christ... the credit card and turner engineering starts becoming tempting! Many thanks for the offer Jason. A fun Christmas I'm going to have.... Quote Link to comment Share on other sites More sharing options...
crclifford Posted December 16, 2012 Share Posted December 16, 2012 Jack, Sorry to hear your engine has gone. When my first replacement went, like that, it turned out the oil switch was faulty. I would check your oil switch and replace if needed. Unfortunately I've sold the cottage and won't be over your way again otherwise I would give you a hand. Good luck with sourcing a replacement and getti it fitted. Chris Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 16, 2012 Share Posted December 16, 2012 wow, thats a big old hole, impressive it still ran after that happend to it. Mav Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted December 16, 2012 Share Posted December 16, 2012 that's a big hole, any of the conrods missing ? Possibly, it's very hard to see without using a camera. How would you tell, short of dropping the sump? And what would cause this? I don't think you need to drop the sump, this picture of yours shows the bearing surface of the crankshaft where the conrod should be connected ..... It looks sort of blue where it has got very hot and the rust starting to bloom on the crankshaft makes me think you have probably smashed the cylinder wall letting coolant into the engine as well...... Anyway if you can see the bearing surface the conrod has gone The cause of that will be lack of oil .... which probably got caused by a knackered turbo ....... ........ Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 16, 2012 Share Posted December 16, 2012 Yes I would imagine that the conrod (#3 or #4 I would say from the relative location of the starter solenoid) is on the road somewhere! Certainly explains the rough running, 3 cylinders never sounds good Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted December 16, 2012 Share Posted December 16, 2012 I had a sports bike engine do that on the motorway after an oil blockage. It left the crankshaft blue and actually melted through the conrod end cap ..... I still have the bits of conrod and piston somewhere. Quote Link to comment Share on other sites More sharing options...
western Posted December 16, 2012 Share Posted December 16, 2012 certainly looks like a rod or the lower part of the bigend cap has succesfully escaped. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted December 17, 2012 Share Posted December 17, 2012 Many many years ago I had the big end cap escape from an Austin A40 engine. BANG, bang, tinkle, tinkle I stopped and a passer by picked up the big end cap passing it to me saying "This fell off your car, is it important? " Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 17, 2012 Share Posted December 17, 2012 "This fell off your car, is it important? " Hahaha i remember doing something similar but the driver of the car said to me "is that important" as i handed her half a cv joint and half shaft after one her wishbone ball joints had given way, Impressive the lady managed to stop the car in a straight line with her front nearside wheel wedged perpedicularly into the wheel arch/wing. We had a catapillar big high speed diesel throw a rod a few months ago. Quote Link to comment Share on other sites More sharing options...
Diablo Posted December 17, 2012 Author Share Posted December 17, 2012 Bet that made a fair old bang! Is the disco turbo the same? Or will I still need to recon mine, assuming I get a disco lump and convert it to a defender style one? I'm also finding it hard to convince myself it's a good idea to buy an engine, be it from ebay or a breaker, without seeing it running in a vehicle. Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted December 17, 2012 Share Posted December 17, 2012 @Maverik Those pictures look familiar. Is that the Havilla engine room? I am working offshore though thankfully not with Cats! Quote Link to comment Share on other sites More sharing options...
crclifford Posted December 17, 2012 Share Posted December 17, 2012 Bet that made a fair old bang! Is the disco turbo the same? Or will I still need to recon mine, assuming I get a disco lump and convert it to a defender style one? I'm also finding it hard to convince myself it's a good idea to buy an engine, be it from ebay or a breaker, without seeing it running in a vehicle. Jack, No difference in the turbos, as far as I know. The only difference is their location/orientation on the engine. The disco one is very tight to to the inner wing, as its lower than the defender one. This is off the top of my head, so I am willing to stand corrected. Chris Quote Link to comment Share on other sites More sharing options...
Diablo Posted December 18, 2012 Author Share Posted December 18, 2012 I knew about the different location, hence I wasn't sure. It's mainly that on some parts websites, it states the part number, ETC8751, as for the Defender. Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 19, 2012 Share Posted December 19, 2012 If my devious plan goes ahead, I'll be able to tell you if there is a difference first hand, I'd like to say no difference, but I'm not a 100% sure. Mav Quote Link to comment Share on other sites More sharing options...
