Baz2236 Posted January 4, 2013 Share Posted January 4, 2013 Hi I have a disco 200 fitted in my 90 Everytime I go wading usually over the bonnet a day or so later the starter wont kick in. I turn the key and nothing today I got round it by rocking the car back and forth in gear and the it turn over straight away. Early when it happened I just flicked the key a few times and it started. This is the 3rd starter it was working fine before it went swimming at the weekend. Any idea how to make them a little more water friendly or how to fix this starter. This and The other starters were fine until they get in deep water and then theg stop working. I am sure when I done the conversion I could not fit the wading plug but I cant remember. Where is the bell housing wading plug. I have a NAD flywheel housing mounted to my disco block. Any ideas because I am stuck apart from dont take it swimming. Baz Quote Link to comment Share on other sites More sharing options...
western Posted January 4, 2013 Share Posted January 4, 2013 your wading plug hole should be on the flywheel housing lower forward facing, possibly hiding behind the sump. Quote Link to comment Share on other sites More sharing options...
Baz2236 Posted January 4, 2013 Author Share Posted January 4, 2013 Can you get to it with engine and box in place. Would this stop my problems with my starters Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 4, 2013 Share Posted January 4, 2013 Its the lower most point of the gearbox bell housing and yes, you can get to it with it all in place. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 4, 2013 Share Posted January 4, 2013 Would this stop my problems with my starters Unfortunately not, though it will help prevent water contamination of the clutch - and the wading plug in the timing chest at the front of the engine does a similar job for the timing belt. I'm not sure there's much you can do to waterproof a starter motor, I'd guess that the "proper" ones (ie. more expensive branded ones) have better sealed solenoids, connections etc. but at the end of the day immersing it in water is not going to do it any favours. Not going wading is the best option. Quote Link to comment Share on other sites More sharing options...
western Posted January 4, 2013 Share Posted January 4, 2013 your wading plug hole should be on the flywheel housing lower forward facing, possibly hiding behind the sump. see items 1 n/a diesel flywheel housing & 4 wading plug in http://www.numcat.ru/landrover/p/31/53050/ Quote Link to comment Share on other sites More sharing options...
Baz2236 Posted January 6, 2013 Author Share Posted January 6, 2013 I cant get to the wading plug on the flywheel housing because the engine block is in the way there about 5mm gap between. other people must have a proper getting the wading plug in on a tdi conversion.Baz Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted January 6, 2013 Share Posted January 6, 2013 It goes on the bottom of the flywheel housing, you should be able to see it when you crawl underneath. Quote Link to comment Share on other sites More sharing options...
western Posted January 6, 2013 Share Posted January 6, 2013 It goes on the bottom of the flywheel housing, you should be able to see it when you crawl underneath. no it doesn't check the parts diagram link, on n/a & TD diesel flywheel wading plug fits from the front face of the housing, the Tdi wading plug goes in from bottom face --- he does NOT have a tdi flywheel housing on the engine. Quote Link to comment Share on other sites More sharing options...
mcc1979ian Posted January 6, 2013 Share Posted January 6, 2013 Ah my mistake i thought we were talking TDi. Quote Link to comment Share on other sites More sharing options...
western Posted January 6, 2013 Share Posted January 6, 2013 I cant get to the wading plug on the flywheel housing because thr engine block is in thr way there about 5mm gap between. other people must have a proper getting the wading plug in on a tdi conversion.Baz others stick with the Tdi flywheel housing, on which the plug goes in from the bottom. Disco 200tdi flywheel housing & wading plug item 4 in http://www.numcat.ru/landrover/p/32/45527/ compare it with the n/a & TD diesel in the other earlier link. Quote Link to comment Share on other sites More sharing options...
Baz2236 Posted January 6, 2013 Author Share Posted January 6, 2013 For some reason I thought I had to change the housing when I did the conversion to a 200 Can I use a 200 flywheel casing then and it will all mate to my gearbox ok. I did have the housing somewhere. Quote Link to comment Share on other sites More sharing options...
western Posted January 6, 2013 Share Posted January 6, 2013 Yes, there maybe some drilling to do before mating up to gearbox, lots of info on how to fit a Disco 200tdi to LT77 in 90/110 in our tech archive. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 7, 2013 Share Posted January 7, 2013 Yes yes and thrice yes Baz but don't forget to do the bolts through the flywheel housing into the ladder frame. A trawl of the 200 conversion threads should explain all. HTH Mo Quote Link to comment Share on other sites More sharing options...
TSD Posted January 8, 2013 Share Posted January 8, 2013 I'm not sure there's much you can do to waterproof a starter motor, I'd guess that the "proper" ones (ie. more expensive branded ones) have better sealed solenoids, connections etc. but at the end of the day immersing it in water is not going to do it any favours. Bosch 'Gen Parts' solenoid, compared to Bosch 'OEM' solenoids... Quote Link to comment Share on other sites More sharing options...
