landroversforever Posted January 20, 2013 Share Posted January 20, 2013 What is needed to get keys from Land Rover for my 90? Is it as simple as giving them the Reg number and the number on the top of the barrel? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
jbs Posted January 20, 2013 Share Posted January 20, 2013 Ross, It'd probably be cheaper to get replacement locks-and ignition barrel than going to land rover directly Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 20, 2013 Author Share Posted January 20, 2013 Yeah I thought it might be, but it may be worth exploring the idea . Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted January 20, 2013 Share Posted January 20, 2013 Just hotwire it, feed all the ignition wires to the horn and put a switch somewhere else for starting it. You can change the door locks easily enough and if someone uses a screwdriver to start it you might notice. Of course, if they've got the bonnet up then they'll probably just take it anyway. Quote Link to comment Share on other sites More sharing options...
western Posted January 20, 2013 Share Posted January 20, 2013 not found the lost ones then ? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 20, 2013 Author Share Posted January 20, 2013 Afraid not Ralph Quote Link to comment Share on other sites More sharing options...
pete3000 Posted January 21, 2013 Share Posted January 21, 2013 wouldn't waste your time at LR dealers, they can only give you keys for the vehicle the day it left the factory. Much cheaper and easier to do the job yourself with a 3 or 5 barrel set. Found this out the expensive way on the P38, £165 for a non refundable replacement key, which didn't work mechanically or electrically. To be fair though they did offer to offset the cost (£165) against a new set of locks becm and rf receiver a bargain at over £1000.....plus fitting.....not Quote Link to comment Share on other sites More sharing options...
elbekko Posted January 21, 2013 Share Posted January 21, 2013 I can get a cheap (I think it was sub-£20) key for my P38 on chassis number from LR no problem, it's just the key though, no fob. Quote Link to comment Share on other sites More sharing options...
Guest Posted January 21, 2013 Share Posted January 21, 2013 Ross, As above it is cheaper to change the locks, than even speak to the main dealer. Plenty on eBay Jason. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 21, 2013 Author Share Posted January 21, 2013 Thought it probably would be. Jason, is that kind going to fit my 90? I'd assumed that the early ones the doors and ignition are always different keys? Mine currently has doors from a 200tdi and what I can only assume is the original ignition. The ignition is two parts, the bit with the barrel and then a separate switch on the back which is held to the barrel with two small screws. Quote Link to comment Share on other sites More sharing options...
Guest Posted January 21, 2013 Share Posted January 21, 2013 No Idea Ross, The same seller is selling all sorts from 2.25/2.5L NA Diesel upwards I bet they would know what you needed. Jason. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted January 21, 2013 Share Posted January 21, 2013 Ross I believe you are correct. Pre Td5 the door and ignition barrels had different keys, the door key being shorter. The way I read this is that the vendor has had a special combination of locks made up that all take the same key, which on the face of it is a good idea. This either means the ignition lock is now using a shorter (read less secure) key, or they have got door locks that can accomodate a longer than standard key. How many levers does a standard 200 tdi era door lock have? I'm seeing 5 in this photo. If I was buying a kit to replace an iginition barrel I would expect to see a set of security bolts included. If you buy a barrel from LR it comes with the clamp part too, but you don't really need that unless you broke it getting the old one off! Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted January 21, 2013 Share Posted January 21, 2013 Ross I believe you are correct. Pre Td5 the door and ignition barrels had different keys, the door key being shorter. The way I read this is that the vendor has had a special combination of locks made up that all take the same key, which on the face of it is a good idea. This either means the ignition lock is now using a shorter (read less secure) key, or they have got door locks that can accomodate a longer than standard key. How many levers does a standard 200 tdi era door lock have? I'm seeing 5 in this photo. If I was buying a kit to replace an iginition barrel I would expect to see a set of security bolts included. If you buy a barrel from LR it comes with the clamp part too, but you don't really need that unless you broke it getting the old one off! The standard pre 2002 barrels have 5 levers and the post 2002 have 9 or 10. Theoretically you could still have the long key for the ignition (keeping maximum security )and then just use the end of this key for the doors thus having one key and the same level of security as before. Before I changed my locks the ignition key would open the doors as they were knackered, however that does mean the key warding matched making the use of one key a possibility if you were to have the right wafers in the door barrels. Quote Link to comment Share on other sites More sharing options...
