reb78 Posted March 15, 2013 Share Posted March 15, 2013 I seemed to have a pretty constant diesel stain on the side of the 110 around and beneath the filler cap. I bought a new cap and it is still happening. Its only when the tank is full, but i thought the new cap would solve the issue. Any idea on what the problem might be? Quote Link to comment Share on other sites More sharing options...
madrooster Posted March 15, 2013 Share Posted March 15, 2013 i have the exact issue with my 130 and had the breather checked and all looks OK, so not sure re this either, so any other ideas would be good to try and solve this issue Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 15, 2013 Author Share Posted March 15, 2013 I thought the old cap wasnt sealing well enough, hence the new one which feels tighter, but the diesel stain is still there. It never used to do this. The tank vents any pressure through the cap, but it shouldnt leak. Quote Link to comment Share on other sites More sharing options...
jad Posted March 15, 2013 Share Posted March 15, 2013 When mine leaked a change of cap sorted it. Was it a new cap you tried? Jad Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 15, 2013 Author Share Posted March 15, 2013 Yep. New cap from lrspares. It was in one of their boxes, so not entirely sure on the actual make. Quote Link to comment Share on other sites More sharing options...
western Posted March 15, 2013 Share Posted March 15, 2013 my 110 does the same. Quote Link to comment Share on other sites More sharing options...
dantastic Posted March 16, 2013 Share Posted March 16, 2013 Same here. Bought a new cap off of ebay the other day. Hopefully it will fix it. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted March 16, 2013 Share Posted March 16, 2013 had this on my 110 a new filler neck was the cure. Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 16, 2013 Author Share Posted March 16, 2013 What do you think the problem with the old neck was David? I had wondered if it was wear on the inside of the rim meaning the tabs on the cap can't pull the cap down tight enough. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted March 16, 2013 Share Posted March 16, 2013 It wasnt a issue with the cap, that got changed and made no difference. I think the issue on mine was that the brazing that holds the outer most part of the filler neck onto the long tube that goes towards the tank was giving up. Sadly the side of the 110 is plastered in fuel due to the wind and my poor aim with 20 litre veg oil drums. Quote Link to comment Share on other sites More sharing options...
Fatboy Posted March 16, 2013 Share Posted March 16, 2013 I'm in the process of rebuilding a 110, under close examination the filler neck had quite a few pin holes in it from corrosion. Mind you, most are behind the panel but I've bought a new one. Quote Link to comment Share on other sites More sharing options...
Litch Posted March 16, 2013 Share Posted March 16, 2013 If a new cap & seal haven't fixed it then I would suggest the neck is damaged in some way. Is it bent at all from the filler nozzle going in? Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 16, 2013 Author Share Posted March 16, 2013 I guess its time to ask Ralph for the filler neck part number 1989 110 csw. Quote Link to comment Share on other sites More sharing options...
Yostumpy Posted March 16, 2013 Share Posted March 16, 2013 Sadly the side of the 110 is plastered in fuel due to the wind and my poor aim with 20 litre veg oil drums. :hysterical: Quote Link to comment Share on other sites More sharing options...
western Posted March 16, 2013 Share Posted March 16, 2013 I guess its time to ask Ralph for the filler neck part number 1989 110 csw. http://www.brit-car.co.uk/product.php?xProd=131358 = item 1 in http://www.numcat.ru/landrover/p/31/53507/ Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 16, 2013 Author Share Posted March 16, 2013 http://www.brit-car.co.uk/product.php?xProd=131358 £250!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted March 16, 2013 Share Posted March 16, 2013 mine was 25 quid Richard from AMD. Quote Link to comment Share on other sites More sharing options...
reb78 Posted March 16, 2013 Author Share Posted March 16, 2013 Thanks I know where i'll be purchasing one from then. Nearly had a heart attack when I saw that (combined with this shocking game of rugby it was almost too much!) Quote Link to comment Share on other sites More sharing options...
western Posted March 16, 2013 Share Posted March 16, 2013 £250!!!!!!!!!!!! you only asked for the part number, my filler neck will be staying in place. Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted March 16, 2013 Share Posted March 16, 2013 combined with this shocking game of rugby it was almost too much! that is never to be mentioned of this forum again!! Quote Link to comment Share on other sites More sharing options...
