CwazyWabbit Posted November 25, 2013 Share Posted November 25, 2013 Try putting a gear puller on to it now...... Quote Link to comment Share on other sites More sharing options...
Eightpot Posted November 25, 2013 Author Share Posted November 25, 2013 Hurray! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 25, 2013 Share Posted November 25, 2013 Amazing... how long had it been stood? Was there any clutch drag? Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 25, 2013 Share Posted November 25, 2013 I reckon you'll grease the splines of every clutch you ever fit after that fight! (not that you fitted that one) So new clutch and new bell housing now ...... and a cup of tea Quote Link to comment Share on other sites More sharing options...
Eightpot Posted November 25, 2013 Author Share Posted November 25, 2013 Been stood a year or two, I've only got it on/off a trailer and round the workshop, but the clutch seemed fine. Only had to get the engine out to fix a leaky rear oil seal. Looks like it might be a very old clutch though, so had while to fuse itself together. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted November 25, 2013 Share Posted November 25, 2013 Amazing ! And well done. How big a hole did you drill to be able to get to the bolts ? I'm presuming fairly large unless your day job is micro surgeon ... Quote Link to comment Share on other sites More sharing options...
Eightpot Posted November 25, 2013 Author Share Posted November 25, 2013 Not that big a hole actually - I just measured the diameter of the bolt hole spacing on a spare clutch plate, then marked that distance out on the bellhousing. I think a 17mm hole was ample to get a slim socket through. Just a matter of turning the crank till a bolt lined up and five mins later job done! Much harder getting the pigging clutch plate of though! Quote Link to comment Share on other sites More sharing options...
discomikey Posted November 25, 2013 Share Posted November 25, 2013 Goodness! i didnt have that problem even when splitting the engine/gearbox from a TE20 that had spent 25 years in a hedge!!! never heard of this before either! Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted November 25, 2013 Share Posted November 25, 2013 Yes that is quite amazing! Lesson learned I suppose, lube up on assembly. But the environment in there must really have been salty and/or wet for a long period for such corrosion. Not a common problem in Spain I don't think! Quote Link to comment Share on other sites More sharing options...
ballcock Posted November 27, 2013 Share Posted November 27, 2013 Not that big a hole actually - I just measured the diameter of the bolt hole spacing on a spare clutch plate, then marked that distance out on the bellhousing. I think a 17mm hole was ample to get a slim socket through. Just a matter of turning the crank till a bolt lined up and five mins later job done! Much harder getting the pigging clutch plate of though! Glad to hear my suggestion worked. Not the thing you want to do too often. Thankfully only the cost of a new clutch kit then. Quote Link to comment Share on other sites More sharing options...
