Reiny Posted July 15, 2014 Share Posted July 15, 2014 How often do these blasted things give up the ghost? I have owned my Defender since 2003 and have changed lift pumps in June 2003, August 2004, March 2011 (record-breaker!), March 2013 and yesterday! I know that they're a common failing point but I for crying out loud, failing after just over a year is excessive. I have always replaced them with Delphi pumps (that's the only brand I can find on the local market). Has anyone else experienced such frequent failures? Quote Link to comment Share on other sites More sharing options...
reb78 Posted July 15, 2014 Share Posted July 15, 2014 Mine kind of decline with time. I keep looking at replacing mine with electric, but the list of more important things keeps getting added to. I have another reason as I want to out a dual filter SVO system on and if I fit two electric lift pumps, then I can get these to switch with the relevant tank and keep them in the correct order in the fuel lines I.e. Before the filter. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted July 15, 2014 Share Posted July 15, 2014 I've not changed any, had tdi's for about 7 years now... Quote Link to comment Share on other sites More sharing options...
reb78 Posted July 15, 2014 Share Posted July 15, 2014 Seems hit and miss to me. Some seem to last, others don't. I've tried Delphi and no name ones and couldn't find a difference myself. Quote Link to comment Share on other sites More sharing options...
The Badger Posted July 15, 2014 Share Posted July 15, 2014 I changed mine to a electric one, left the old one in place and put a loop of hose from input to output. It had not failed, but was not sure it would deliver the fuel needed for some mods / tweaks I did. I mean yes it would, but thought to see what the different would be and so far it's great.Used one of these - Facet Posi-Flow Electric Fuel Pump 7.0-10.0 psi (with filter/hose union) Quote Link to comment Share on other sites More sharing options...
tuko Posted July 15, 2014 Share Posted July 15, 2014 On our Disco I'm forever changing the lift pump to. In 8 years of ownership, I just changed the 4th last month, also using Delphi. Quote Link to comment Share on other sites More sharing options...
reb78 Posted July 15, 2014 Share Posted July 15, 2014 I changed mine to a electric one, left the old one in place and put a loop of hose from input to output. It had not failed, but was not sure it would deliver the fuel needed for some mods / tweaks I did. I mean yes it would, but thought to see what the different would be and so far it's great. Used one of these - Facet Posi-Flow Electric Fuel Pump 7.0-10.0 psi (with filter/hose union) Interesting. Have you got a link? Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 15, 2014 Share Posted July 15, 2014 What are the symptoms of lift pump failure? Quote Link to comment Share on other sites More sharing options...
Reiny Posted July 15, 2014 Author Share Posted July 15, 2014 In my case it's always the same. Almost total power failure. Revs won't go above approx 1200 rpm. It will start and idle perfectly but will not rev. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted July 15, 2014 Share Posted July 15, 2014 Cheers, that's quite an obvious symptom to spot Quote Link to comment Share on other sites More sharing options...
Souster Posted July 15, 2014 Share Posted July 15, 2014 Are the symptoms allways the same? Or does it depend on how efficient the injection pump is? Quote Link to comment Share on other sites More sharing options...
Souster Posted July 15, 2014 Share Posted July 15, 2014 Are the symptoms allways the same, for all vehicles? Or does it depend on how efficient the injection pump is? Quote Link to comment Share on other sites More sharing options...
ballcock Posted July 15, 2014 Share Posted July 15, 2014 When mine failed the ring on the bottom of the draw shaft had broken off so wasn't pumping at all but the engine ran well but had poor acceleration, but could still make 80 on the open road. Quote Link to comment Share on other sites More sharing options...
tuko Posted July 15, 2014 Share Posted July 15, 2014 In my case it's total lack of fuel being delivered, the Disco simply dies! I've been told that the modern diesel fuels don't have enough lubricants for the rubber diaphragms in the lift pumps. Who knows if it's the problem but having to replace the lift pump so often is wearing thin. Todd. Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted July 16, 2014 Share Posted July 16, 2014 Back on my first 300tdi 90 15 years ago it would loose power only at full throttle on the motorway- would seem to starve and then surge. We used it for a year before we changed the lift pump as we never used it on the motorway and it was fine in everyday use. That was the original lift pump failing. I've also had another original pump on another 300tdi fail - it worked 100% but the truck always smelt of diesel when parked and on inspection the lift pump was leaking fuel. Last one I've had a cheap pattern one totally fail - the operating arm snapped off! I have replaced all mine with delphi as they seem to be the only branded pump easily available. The additional filter in the top of them is handy too. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted July 16, 2014 Share Posted July 16, 2014 Hmm...you've got me wondering about mine now..... On the subject, anyone ever fitted a 300 lift pump to a 200 block? Fittings are much nicer on the 300 Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted July 16, 2014 Share Posted July 16, 2014 They don't fit the block - tried that once many years ago Quote Link to comment Share on other sites More sharing options...
ejparrott Posted July 16, 2014 Share Posted July 16, 2014 hmm....perhaps a custom mount plate would do the trick..... Quote Link to comment Share on other sites More sharing options...
Tetsu0san Posted July 16, 2014 Share Posted July 16, 2014 Could you have another underlying issue, like a fuel blockage somewhere? If you have a restriction the pump will have to work hard all the time to deliver fuel to the injector pump. Also, do you change your fuel filter often? Check in the tank for bits that might cause a restriction in the fuel delivery, maybe blow through the pipework with a compressor. Quote Link to comment Share on other sites More sharing options...
The Badger Posted July 17, 2014 Share Posted July 17, 2014 Sorry, here is the link http://www.fuelpumpsonline.co.uk/facet-posi-flow-pumps-1819-c.asp I bolted this to the underside of the air cleaner bracket, ideally I should have out a simple inline fuel filter before it, but never did and it's still all good. Quote Link to comment Share on other sites More sharing options...
