battery cut off
white90
  • 1 month later...
Dragging this thread back to the top.......
I'm in the process of fitting a FIA approved switch like Tonys, but for a 3.5 v8 EFI. The wiring diagram shows feeds required to go from the additional poles on the back of the switch (which I presume is a relay) to the coil and ignition switch. Anyone got any any ideas which poles on the coil and ignition to connect to???? I preseme they should be specific???
  • 1 year later...
I'm fitting a simple cut off switch on the positive lead between battery and winch. I see most people go for the passenger footwell. Would there be any issue running the cable behind the dash and mounting the switch lets say next to the cigar lighter?
Im no auto electrician so I'm probably missing something obvious thats wrong with this plan.
Any comments appreciated.
Dan
