davie Posted September 21, 2015 Share Posted September 21, 2015 So recently in last week or so i noticed front driver wheel had an awful lot of brake dust on it, like huge amounts, so today i got wheel off, pads out and pumped brake pedal a bit to bring pistons out. hoping i could clean up with brake cleaner and then grease etc to make slide nice - cue some swear words!! outside set moved in and out ok, inside set took a lot to pump out a lil, then wouldnt retract! Got garage to pop in new pistons and seals in a hurry as i need car in morning. so my question is whats recommended kit for seals and pistons to rebuild the rest - can anyone point me in right direction please. Garage also used a red grease called rubberlube in rebuild before sticking in pistons, dont want to buy a huge tub of this - any ideas on other solutions or a small tin that wont break bank. i did try a google search and the amount of options was huge so looking for ways to narrow down. 2003 td5 defender csw so vented on front, solid on rear. thanks Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 21, 2015 Share Posted September 21, 2015 This is the stuff, not really expensive at all: http://www.ebay.co.uk/itm/Morris-Lubricants-Red-Rubber-Grease-500g-/181872496782?hash=item2a5872108e Being Morris it will be good... well worth it for protection against the elements. Quote Link to comment Share on other sites More sharing options...
davie Posted September 21, 2015 Author Share Posted September 21, 2015 thats perfect for the job and my budget! just need ideas on piston and seal kits now. kind of hoping when i take other 3 apart its better news but since i am meant to be saving for tyres i bet all will need rebuilt! Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted September 21, 2015 Share Posted September 21, 2015 Stainless pistons are available quite easily, no direct experience of any of them though. Do NOT buy britpart seal retainers, they do NOT fit/work. Quote Link to comment Share on other sites More sharing options...
davie Posted September 21, 2015 Author Share Posted September 21, 2015 oh dont worry there will never be anything britpart fited - thats just not happening. Quote Link to comment Share on other sites More sharing options...
Peaklander Posted September 22, 2015 Share Posted September 22, 2015 You can get shoe polish sized tins of red grease too. It goes a very long way!! I got mine on eBay. Quote Link to comment Share on other sites More sharing options...
muddychris300tdi Posted September 22, 2015 Share Posted September 22, 2015 Are you planning on rebuilding all 4 calipers. I thought about rebuilding all mine on my 130 for about 2 seconds and decided it was much less hassle to just put 4 New calipers on. Quote Link to comment Share on other sites More sharing options...
ejparrott Posted September 22, 2015 Share Posted September 22, 2015 I've rebuilt callipers, should be able to find the thread on here. I used Bearmach bits, and made a tool for fitting the retaining rings which was easy Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted September 22, 2015 Share Posted September 22, 2015 I've just done a front set for the mother in laws disco and used bearmach pistons and seals with no issues so far Quote Link to comment Share on other sites More sharing options...
Fatboy Posted September 22, 2015 Share Posted September 22, 2015 Davie, I've rebuilt quite a few and also made a tool for fitting the seal retainers out of a poly waste pipe crossover.. (Rough as rats but did the job). To be honest, when you price up the cost of new stainless callipers, and good quality seal kits, you are only a few pounds shy of the cost of replacement callipers from the likes of LRDirect. (The part number below probably isn't correct, I just picked it for illustration). Quote Link to comment Share on other sites More sharing options...
ejparrott Posted September 22, 2015 Share Posted September 22, 2015 Cost of replacement callipers, but not with stainless pistons Quote Link to comment Share on other sites More sharing options...
Fatboy Posted September 22, 2015 Share Posted September 22, 2015 Indeed... Quote Link to comment Share on other sites More sharing options...
davie Posted September 22, 2015 Author Share Posted September 22, 2015 hey donald, I do want to be using stainless. I plan to look at the remaining three calipers as i reckon if one was poor rest may not be perfect. Figured better to have kits here first so we can crack on with it. Hoping to do once for a long time kind of job, then next on the list is a pressure wash underneath then a mountian of waxoil - if it ever dries up! Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 24, 2015 Share Posted September 24, 2015 I have done two of my vehicles with Zeus Engineering's stainless pistons. They are truly excellent, and any disc braked LRs I have in the future will get more of the same. They provided genuine seals and retainers in the first kit, but Britpart on the second. The seals are fine, but as said, the retainers don't fit. Try to save the originals as you remove them, or buy new genuine retainers. Make sure the seal seats are scrupulously clean, with not a hint of dirt or rust, and lightly file the outer edge of the seal retainer before fitting so that they don't pick up on the lip. Quote Link to comment Share on other sites More sharing options...
henk Posted September 24, 2015 Share Posted September 24, 2015 Bought mine from Paddock and is 316 grade ss. You should take the lochead seal kits, they fit perfect and very easy to install Quote Link to comment Share on other sites More sharing options...
davie Posted September 24, 2015 Author Share Posted September 24, 2015 cheers for info, will get looking into these options over weekend. funny how holidays always seem to get busy... Quote Link to comment Share on other sites More sharing options...
