Anderzander Posted December 18, 2015 Share Posted December 18, 2015 I've just fitted a RR LT230 to my Td5 and the transducer won't fit the drive - the plastic drive is a little too big. Reading around everyone seems to say they just plug in - though I've found one thread with someone saying the same happened to them. No resolution listed for it though. Any suggestions? Do I file down the plastic drive (carefully) or can I pop the drive out and replace it? Quote Link to comment Share on other sites More sharing options...
tacr2man Posted December 18, 2015 Share Posted December 18, 2015 Two options . I just filed down the transducer spigot evenly on each face to keep centralised , its working fine for several years. The other option would be get the td5 version of the drive gear , they just slide fit , there is an O ring on the sleeve . ps the drive ratio might need changing depending on the tyre size any way Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 18, 2015 Author Share Posted December 18, 2015 That's helpful thank you. How do you get them out ? Just lever them up from the groove ? Quote Link to comment Share on other sites More sharing options...
western Posted December 18, 2015 Share Posted December 18, 2015 the speedo drive gear housing can be levered out carefully [don't bust the alloy flange] Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 18, 2015 Author Share Posted December 18, 2015 Are the flanges fragile ? Quote Link to comment Share on other sites More sharing options...
western Posted December 18, 2015 Share Posted December 18, 2015 it's a alloy housing so just prise it out with care, don't be to BFH brutal or you'll be buying a new housing photo here http://www.johnrichardssurplus.co.uk/land-rover-lt230-lt85-transfer-box-speedometer-drive-housing-frc3286.html Quote Link to comment Share on other sites More sharing options...
dailysleaze Posted December 18, 2015 Share Posted December 18, 2015 Here's a photo of the difference between a Discovery (left) and a Defender one. I presume the RR would be similar to the Disco... You can swap these pretty easily. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 18, 2015 Author Share Posted December 18, 2015 Thanks everyone - I'll have a go tomorrow and report back. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted December 18, 2015 Share Posted December 18, 2015 Should be able to swap with the one from your old t/box Use penetrating fluid liberally and gradually get the whole thing to spin in the hole and then start to lever it up slowly, ideally while still spinning the whole unit. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 18, 2015 Share Posted December 18, 2015 And is really really much easier if you remove the handbrake back plate because it may well be very very stuck and you'll need all the room you can get ? Good luck Mo Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 19, 2015 Author Share Posted December 19, 2015 I always seem to make hard work of setting up drum hand brakes ....... Which was part of the reason I went for an x-brake on the last one..... Quote Link to comment Share on other sites More sharing options...
oneandtwo Posted December 19, 2015 Share Posted December 19, 2015 The housings are not alloy, they are steel so you can and may have to get brutal if required! Quote Link to comment Share on other sites More sharing options...
Anderzander Posted December 19, 2015 Author Share Posted December 19, 2015 Old one out - made a start on the one on the car, tried leaving the drum on - but. It clearly needs to come off. Rain has stopped play for today though. I'll see if I can get some time on it tomorrow. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 19, 2015 Share Posted December 19, 2015 Leave the cable attached Stephen, and just unbolt the back plate and leave it hanging. No adjustment necessary then ? Mo Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 23, 2016 Author Share Posted January 23, 2016 I can't be accused of rushing things ... But I've finally got back to this - swapped it with the one from my old LT230. Getting it to spin, as Neil said, was definitely the key to getting them out. Pulling the hand brake off, as Mo suggested, was also definitely the way to go. Thanks Chaps. Quote Link to comment Share on other sites More sharing options...
