4.0 V8 + R380 gearbox
Hello,
Does anyone knows if you can fit a Range Rover 4.0V8 to a Defender 300Tdi R380 gearbox?
if it is possible were can I find adaptor plates and clutches for this set-up?
many thanks for the information!
Regards
Alain
I looked into this ages ago, the input shaft is about the right length to use with a 300-series (ie R380) Discovery V8 bellhousing, but the spigot bearing on the TDI is larger, so you'll need to lash something up like a very thin bronze bush.
Ideally you'd have the box rebuilt with the V8 pinion shaft, but ofcourse thats quite expensive.
Standard clutch i believe should work fine from memory.
When I put a R380 from a tdi behind a V8 Ashcroft changed the input shaft for the princely sum of £75.
As previously mentioned there is a standard Land Rover bell housing that will do the job of mating a V8 to the R380
Ok thanks for the update!
You use a V8 flywheel from a manual V8?
yes, the flywheel from pretty much any manual V8 will do the job. I have no idea which type I have fitted at the moment, it came from a scrapyard for a couple of pounds
I am interested in converting my auto chaser to manual. Has anyone done a 6-speed conversion with a supra gearbox?
I think you have the wrong forum old chap - this isn't a Toyota car forum...
