Kierran.M.110
Early to late 110 axle swap
9 posts in this topic
Hi not sure if this has been talked about before or not but I have an defender 110 with the drum braked Salisbury axle which has blown the diff and halfshafts due to excessive play I think. My question is are the newer 110 axles with the smaller diff housing size and disk brakes the same ratio as my old Salisbury, as I would like the higher clearance for off road.
Cheers.
Share this post
Link to post
Yes, straight swap and the ratio is the same - 3.54:1
You'll need a longer prop from a later vehicle also as the diff nose is shorter.
Share this post
Link to post
Yeh I knew I'd need a later prop as well but someone said to me they was different ratios so I thought I'd ask here and check
Share this post
Link to post
same ratio in all 90/110's. so as retro says straight swap with longer prop.
Share this post
Link to post
I too am looking for said prop, but you can buy new ones sometime for less than second hand, try lrdirect, they had i think a hardy spicer one
Share this post
Link to post
If you cannot find one I have a drum salisbury cluttering up my garage floor. It has new bearings and seals in the hubs. No half shafts, brakes or diff cover.
Share this post
Link to post
I recently changed the prop on my 110 and working on the basis that if I bought second hand I would want to change the UJs for items of a known quality I came to the conclusion that it wasn't worth messing about with breakers and bought new Hardy Spicer from RST online, good service, next day delivery and reasonable price.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
