white90 Posted August 26, 2009 Share Posted August 26, 2009 As good or better than Sumo (bent to buggery) bars? Quote Link to comment Share on other sites More sharing options...
freeagent Posted August 27, 2009 Share Posted August 27, 2009 As good or better than Sumo (bent to buggery) bars? I had a Britpart one which only bent when i got properly hung-up on a tree stump... the Bearmch ones look pretty much the same... I reckon it should be OK... Quote Link to comment Share on other sites More sharing options...
Orange Posted August 27, 2009 Share Posted August 27, 2009 No problems with mine so far, Tony. I have both the drag link and tie-rod and have fitted greasable TREs. They have been moved around onto/off of various vehicles and are now withstanding the abuse that I am giving them on the Challenger Series... Quote Link to comment Share on other sites More sharing options...
SteveG Posted August 27, 2009 Share Posted August 27, 2009 Fine on mine too, IIRC they were bought off gigglepin stand at a show. Cheers Steve Quote Link to comment Share on other sites More sharing options...
white90 Posted August 27, 2009 Author Share Posted August 27, 2009 Thanks All I have ordered a set. to replace this: PS a QT guard to sort/replace as well. Quote Link to comment Share on other sites More sharing options...
white90 Posted August 27, 2009 Author Share Posted August 27, 2009 Don't want another Southdown one options and what have you got/could recommend. as I do not want to be spending on track rods again any time soon. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 27, 2009 Share Posted August 27, 2009 Blimey! That's going some Tony considering the track rod should have been restrained in the middle by the steering guard! Did it rip the bolts out of the diff nose or shear them off? Quote Link to comment Share on other sites More sharing options...
white90 Posted August 27, 2009 Author Share Posted August 27, 2009 Charles all bolts in place and removed fine to get the piece of cheese QT guard off. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 27, 2009 Share Posted August 27, 2009 I think a lot of the challenge lot rave about Gwyn Lewis' protector Tony. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted August 27, 2009 Share Posted August 27, 2009 Hmm, food for thought as I have two on mine....... Thinking about it, the guard doesn't have much stopping it from twisting does it. I might have a think about modifying mine to counter this problem....... Quote Link to comment Share on other sites More sharing options...
ciderman Posted August 27, 2009 Share Posted August 27, 2009 Yep , thats the one The Gwyn Lewis is faultless in operation , No more bent track bars , The only con against it is that its difficult to change or remove the TRE from the swivel but if you cut the remaining thread from the taper end it will come apart a lot easier Quote Link to comment Share on other sites More sharing options...
ciderman Posted August 27, 2009 Share Posted August 27, 2009 I had a simular affair with my front QT gaurd , Now replaced by a Gwyn Lewis track rod protector and a cheapy clamp on diff gaurd thats now welded in place .The QT gaurds are ideal on the rear as they offer a slide over protection Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted August 27, 2009 Share Posted August 27, 2009 Only con against it is that its difficult to change or remove the TRE from the swivel but if you cut the remaining thread from the taper end it will come apart a lot easier If I lock the wheel around so the track rod end is nearest the guard mine will come out with the guard on no problem! The guard is one of the best bits of kit ive bought. Used to bent the track rod all the time before I got it but its a thing of the past now. Quote Link to comment Share on other sites More sharing options...
landkeeper Posted August 27, 2009 Share Posted August 27, 2009 lad on the devon 4x4 site selling such a thing Quote Link to comment Share on other sites More sharing options...
white90 Posted August 27, 2009 Author Share Posted August 27, 2009 What have you done about the Diff protection on the front Jase/Steve? Quote Link to comment Share on other sites More sharing options...
ciderman Posted August 27, 2009 Share Posted August 27, 2009 Tony , Currently have a cheapy clamp on diff cover ,But its welded on. Works a treat Quote Link to comment Share on other sites More sharing options...
white90 Posted August 27, 2009 Author Share Posted August 27, 2009 Ideal thanks I won't be fitting a third QT one as they are IMHO carp the Sumo bar is unbelievably hard to try to straighten so I could drive to the garage so I gave up and ordered the new ones. I'll look out for a clamp on diff gaurd now as well. Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted August 27, 2009 Share Posted August 27, 2009 I think a lot of the challenge lot rave about Gwyn Lewis' protector Tony. i was thinking about getting one of these but didn't know how much drag it was going to give me Quote Link to comment Share on other sites More sharing options...
ciderman Posted August 27, 2009 Share Posted August 27, 2009 Im looking to make up a drag link out of spring steel so it is more resistant to bending , but then is it moving the problem elseware ?? Quote Link to comment Share on other sites More sharing options...
ciderman Posted August 27, 2009 Share Posted August 27, 2009 i was thinking about getting one of these but didn't know how much drag it was going to give me They only protrude about 30mm below the axle on the Nearside , you wouldnt even notice it , they also have a built in leading edge to assist in sliding over obstacles . Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted August 27, 2009 Share Posted August 27, 2009 One more thing to add to my wish list Quote Link to comment Share on other sites More sharing options...
white90 Posted August 27, 2009 Author Share Posted August 27, 2009 Bulk purchase perhaps? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted August 27, 2009 Share Posted August 27, 2009 http://forums.lr4x4.com/index.php?showtopic=41338&view=findpost&p=390570 Had the complete 90 front end rock jamed and winched over it It was scratched though I do have to admit, but hey its just a rock, the WTF bar was as new Buy one TC Nige Quote Link to comment Share on other sites More sharing options...
ciderman Posted August 27, 2009 Share Posted August 27, 2009 I think you will find that Gwyns prices are very reasonable and realistic . And its been tried , tested and made properly Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted August 28, 2009 Share Posted August 28, 2009 Looks similar to the track rod guard OEC sell, which worked fine for me. I'm currently selling mine, as it happens... Quote Link to comment Share on other sites More sharing options...
