Mutley Posted December 6, 2017 Share Posted December 6, 2017 Ok so i am doing another oil change on the 90 300tdi as i like to do it about every 8 months ( dont do alot of mileage). Question is what to use to flush the last of the oil through/out?.... preferably cheap, is good and wont harm the engine. Cheers Andy Quote Link to comment Share on other sites More sharing options...
Gazzar Posted December 6, 2017 Share Posted December 6, 2017 Cheap engine oil? Quote Link to comment Share on other sites More sharing options...
crwoody Posted December 6, 2017 Share Posted December 6, 2017 Personally I've never bothered, just get the engine up to temperature, bit of a run and then drain it straight away, leave it for a while to finish dripping. Otherwise add a couple of litres of diesel to the engine oil to thin it, run it for long enough to ensure it's well mixed in before draining. Quote Link to comment Share on other sites More sharing options...
western Posted December 6, 2017 Share Posted December 6, 2017 I wouldn't bother, get engine nice & hot then drain the oil. Quote Link to comment Share on other sites More sharing options...
Mutley Posted December 6, 2017 Author Share Posted December 6, 2017 Ok guys will go with warm engine. I have always done it from cold, on the assumption that the oil has drained to the sump?..... Always willing to learn Cheers Andy Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 6, 2017 Share Posted December 6, 2017 If you warm it up on a drive then by the time you get your tools out on return it will long be fully drained down to the sump. Flows out much easier when warm, just watch for burns if it’s really hot. I generally let it drain while I grease the props, unless it’s windy and I have to cut short the dribble to save it going everywhere. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted December 7, 2017 Share Posted December 7, 2017 10 hours ago, Retroanaconda said: I generally let it drain while I grease the props, unless it’s windy and I have to cut short the dribble to save it going everywhere. Might be an idea to talk to your GP about the dribbling, James 😉 Mo Quote Link to comment Share on other sites More sharing options...
Mutley Posted December 8, 2017 Author Share Posted December 8, 2017 On 07/12/2017 at 8:26 AM, Mo Murphy said: Might be an idea to talk to your GP about the dribbling, James 😉 Mo Apparently it's an age thing 😂😂😂 Quote Link to comment Share on other sites More sharing options...
muddy Posted December 8, 2017 Share Posted December 8, 2017 I like to get red hot and then leave to drain overnight. Although I cannot stop my 300blackeneing new oil I think there's a tin of boot polish in the sump. Quote Link to comment Share on other sites More sharing options...
western Posted December 8, 2017 Share Posted December 8, 2017 My recently rebuilt 200Tdi is turning its oil black its only been in for just under 1000 miles, I don't think there is any way to prevent diesel engines making their lube oil black. Quote Link to comment Share on other sites More sharing options...
Tanuki Posted December 8, 2017 Share Posted December 8, 2017 (edited) When faced with an engine that's a bit claggy and the history-of-oil-changes is unknown, I've lobbed a litre of ATF [it's got lots of detergency] into the filler then taken it for an "Italian Tune-up". Which basically means lots of full-throttle-and-revving-it-to-the-limiter-before-changing-up stuff. You want to get the engine really-stinking-hot [and if it won't handle screaming at 60MPH-in-3rd foot-to-the-floor and hard on the revlimiter for a 5-mile blast down the local dual-carriageway it's an engine-with-other-issues anyway]. Then drive home and drain the oil. Watch out - it should be 90 Centigrade-plus-plus when it comes out. But it'll bring out with it any accumulated grot/varnish/black-crud. My 90TD5 turns its oil black after about 3000 miles. I'm happy to run to 12,000/1-year as the service-interval. EGR-disable/bypass helps prevent the oil going prematurely black. Edited December 8, 2017 by Tanuki Quote Link to comment Share on other sites More sharing options...
Mutley Posted December 8, 2017 Author Share Posted December 8, 2017 I try and do an oil change at least every 8 months, i dont do alot of mileage bout 4000 a year tops. But oil is always black, and has been in every motor that i've done an oil change, just took it as the norm. Or is that not the case ie if alls good in there it should retain some of its colour? Motor runs sweet enough Quote Link to comment Share on other sites More sharing options...
Mutley Posted December 9, 2017 Author Share Posted December 9, 2017 Tanuki you have bigger furrier ones than me!.... Not sure i could give my motor that much grief!?! And if anything else IS going on in there i would like to know a little more subtly 😉😁 Quote Link to comment Share on other sites More sharing options...
